'04 Passenger AUTO window issue
I recently bought an 04 TL, and the seller told me the passenger window AUTO switch was messed up, and he showed me what he was talking about before I bought it. He hit the button AUTO up and down a few times to get the window to roll all the way up. He said the switch was $25 on ebay. One person here said the window needed to be reprogrammed. I looked in the owner's manual, and I didn't see anything about reprogramming the windows in this scenario.
When I hit AUTO down on the window, it goes all the way down, but when I hit AUTO up, it goes all the way up then goes halfway down. When I hit AUTO down and then manually roll all the way up, it will only roll up 98% of the way, leaving about an inch to go. I can manually pull up over the next few minutes, and it will BARELY go up a little more. I eventually have to get out of the car and pull the window up with my hands.
Is this an easy fix, or am I fucked?
https://acurazine.com/forums/3g-tl-problems-fixes-114/automatic-window-feature-not-working-758028/
I have the same problem too - just havn't bothered to fix it lol
There is a sensor which detects if something is in the way and prevents the window from closing so you don't squish your fingers. This is just a guess, but is it possible that there is some kind of dirt or spider web or something there triggering that sensor?
I tried to roll the window all the way down and hold the button for a couple seconds, then rolled it all the way up to hold it for a couple seconds........BUT, the window wouldn't roll all the way up!!! Only about half way!! I had to pull the window up with my hands while my dad pulled the switch up. WTF, this is seriously annoying
ill try the 2 second trick tomorrow morning.
It's your window regulator. Dealer robbed me $250. for a replacement. Works fine now.
https://acurazine.com/forums/showthr...5#post12785485
I got quoted at $250 for replacement.. but I believe I can do this myself..
is this the right part for the 2004 TL passenger window regulator? Does the motor come with this? It's the entire assembly, correct?
http://www.acuraoemparts.com/delray/jsp/shpcart.jsp
72210-SEP-305 REGULATOR,R FR 2004 TL 112.62 84.47 Qty
BUMP........... is this the correct part..? Passenger front window motor/regulator, entire assembly? Just want to make sure before I buy..
rockyboy
12-06-2022 02:29 PM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
asahrts
09-04-2015 05:55 PM
