'04 6 spd won't hit redline
Old 11-09-2011, 06:06 PM
ncardenas973's Avatar
whats going on people. i gotta problem here and i need sum imput. recently i noticed that my car wont rev up to redline. doesnt matter if the traction control is on or off. as soon as the engine hits about 5800 it feels like the rev limiter is hitting. any thoughts on what it might be?
Old 11-09-2011, 07:28 PM
runnin a little boost
Hi speed's Avatar
Is this when you are revving the engine or while driving in gear? I know the TL will not hit redline under no load or when revving the engine.
Old 11-10-2011, 04:47 PM
when in gear it happens sometimes in 1st everytime in 2nd n 3rd. when it happens the car jerks like i hit the rev limiter but then continue to rev up to the redline.
Old 11-10-2011, 10:25 PM
Hi speed's Avatar
Could be the engine is knocking at hi rpm and retarding timing, cutting power and making the engine reluctant to rev to redline.
Old 11-10-2011, 10:29 PM
Received 16,260 Likes on 11,971 Posts
Any Check engine lights?
what kind of gas are you using?
Old 11-11-2011, 07:27 PM
no, no engine checklight and i only run 93octane. i dont understand why it happens sumtimes in first and all the time in 2nd n 3rd.
Old 11-12-2011, 11:35 AM
**WhItE-aNgEl**'s Avatar
Any gasoline smell? Your car might be running to rich, to much gas coming out of the injectors can choke your car at high RPM. Had that same issue on my turbo 95 celica. I put supra injectors and since the car wasn't dyno or tuned yet, when I took it out of the shop it wouldn't rev more than 5,500 Rpms
Old 11-14-2011, 08:45 PM
saxonstsx's Avatar
it will do it in the higher gears because there is more load on the engine compared to first
have you checked your plugs?
08KBP_VA
10-22-2019 01:55 PM
DerrickW
11-15-2015 05:52 PM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
mars
09-28-2015 11:03 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: '04 6 spd won't hit redline
