/!\ and VSA lights after replacing sensor, how to turn off
Old Sep 19, 2012 | 06:44 PM
Macoyle's Avatar
So I had a bad front right abs sensor that was throwing the abs, vsa and (!). Light on. Switched out the sensor with a new one and the (!) light is still on and the vsa light came on after about 1/4 mile...great. So I called the dealership since I just had the codes read there and they said they wanna charge me another $50 to re read the codes...great
Thanks in advance
Mike
This started after I swapped out the suspension, so no impact or anything, brake fluid is good, maybe a little high if anything, checked the wires under the rear seat, no damage...
Old Sep 27, 2012 | 05:41 PM
Macoyle's Avatar
ok well I had the codes read by honda for $49, its an 84-1 sensor logic code. from searching around it looks like I have to have it calibrated?
does anyone know of a place around south houston that does it cheaper than 129 plus tax at the acura dealership in league city? The honda place said they couldn't do anything with it
Old Sep 28, 2012 | 08:58 PM
Macoyle's Avatar
Bump...please help me out
Old Sep 29, 2012 | 10:06 AM
Fulani has a TL's Avatar
Did you distance the sensor correctly and make sure there is no metal dust/fragments or anything in between?
https://acurazine.com/forums/3g-tl-2004-2008-93/wheel-speed-sensor-service-manual-please-3g-garage-d-034-a-566185/
Based on this the front sensor needs a gap of 0.5 - 1.2mm and the rear needs a gap of 0.4-1.1mm.
Old Sep 29, 2012 | 12:29 PM
Macoyle's Avatar
I made sure everything was clean but didn't check the gaps, it only bolts in one way and there is no reason those encoders would have moved or shifted positions
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
wusty23jd
Sep 24, 2015 11:41 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
