Not sure how to explain this...
So I'm out driving to meet some friends and I start to smell burning rubber and hear a strange sound. So I pull over right away and get out and see this...
![](http://i953.photobucket.com/albums/ae11/ravinpatel90/IMAG0256.jpg)
![](http://i953.photobucket.com/albums/ae11/ravinpatel90/IMAG0255.jpg)
I was lucky that the majority of the tire was still intact and the rim never hit the ground. I had removed my spare tire and replaced it with an air compressor but again I was lucky that my buddies IS 350 spare has the same bolt pattern as mine so I was able to drive home. Its parked now and a new tire is on the way.
![](http://i953.photobucket.com/albums/ae11/ravinpatel90/IMAG0257.jpg)
![](http://i953.photobucket.com/albums/ae11/ravinpatel90/IMAG0261.jpg)
jimmy954 (08-29-2011)
Ravin what the fuck dude?!?!?!?!
BANNED
wow man...you must have a horseshoe stuck up your ass. glad nothing serious happened.
what specs are your wheels/tires? making me nervous over here since I'm stretching.
damn man what a close call!
19x10 +24 235/35R19 There's ur problem right there. A 235 tire is supposed to fit on a 8.5 rim. You put it on a 10 inch rim which is supposed to use 275 size tire...
BANNED
ive been around alot of stretch tires too, its just one of those freak accidents. but 235 on 10inch is a pushing it
Registered 3.5L Member
Just waiting for JTS97Z28 to chime in.....
CLtotheTL32 (08-29-2011)
Stretched tires at its best. And why you would remove your spare tire I dont know. They are there for a reason lol Ive said it before and i'll say it again, stretching tires is about as unsafe as it gets as far as doing exactly what your not supposed to do to wheels/tires. Glad to see everything worked out alright and the car didnt lose control or anything crazy.
James
James
The following 4 users liked this post by JTS97Z28:
That setup didn't seem very safe at all.
ehh thats not that bad of a stretch ive seen worse i think your air pressure got low and it lost its seat in the bead... plus nexxen dont stretch very well
scary stuff! glad you caught it before it escalated. thinking i might go pick up a couple lexus spares.. theyre stylish
keep it clean
'That's what she said!'
![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
I have a 225/40 on a 9" wheel, no problems. I live in NYC with some of the worse streets you can find and I've been fine. Just keep the right tire pressure as some others have mentioned. And IMO, your tire choice could've been an issue as well. I wouldn't really be confident stretching a Nexen tire.
Received 6,470 Likes
Boy, Lexus sure makes a classy lookin' spare!
problem has been stated, but ill confirm it since ive been running a 235/35 on a ten (not a big stretch) for years as well...this is what happens when you do not have enough air in your tire and it debeads..
9.5+10.5 22m=Hella Flush
Stretched tire or not but I really do think this was caused by really low tire pressure like less than 15psi. I had the same issue and my tires partially came off the wheel and this happened on my oem wheels running 235.
