Installed UniqueStyleRacing Custom Engraved Pedals
Congrats! They look great!
I ended up getting the generic eBay version for my TL. I know my car is an Acura, I don't need my pedals to remind me
Feels normal, you really don't notice the new feel
I screwed the Dead Pedal over the Plastic Dead pedal. & for the Clutch & Brake Pedal I had to use a Titanium drill bit, to make the holes to put the screws in. And for the Gas Pedal, I had to take it off & line up the Pedal over the rubber pedal & drill through the Plastic & then screwed the Gas pedal ontop of the plastic one & put the gas pedal back together
Still haven't Vacum"d car... but will repost with clean carpet
U don't notice any thing different
They look awesome!
Its just the gas pedal is a little tricky. U gotta B up-side down in the car & B careful when you taking off the gas pedal to remove the spring behind it
Received 6,470 Likes
Twinz, I've merged many of your posts together. Just so you know, there is a multiple quote button on the far right of each post. Please give it a try, so you get used to it and use it often.
I installed mine last weekend; need to get my pics posted.
It's not too bad with the right drill bit and knowing ahead of time that you'll need to put some amount of padding between the new pedal cover and the pedal itself.
The thing that was the biggest pain to me was getting the nut onto the bolt behind the gas pedal. All that plastic on the back of the gas pedal gets in the way unless you have child-size fingers.
>On the Dead Pedal, I lined them up together & drilled through the plasctic Dead plate And then put the screws in.
>For the Clutch & Brake, I took off the rubber, then lined up the Custom pedals ova the pedals & used a marker to mark where to drill the hole's for the screws.
>The Gas Pedal to me wuz a little tricky. Had to take the pedal off & remember how to put the small spring back on that goes behind the Gas pedal. Once off Line up the Custom pedal ova da Gas pedal & make the holes, then screw it on over the gas pedal & put it back together & your done.. Took bout 5-10mins
wusty23jd
09-24-2015 11:41 AM
Iakonafuji
09-21-2015 02:39 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
