2007-08 base VS type-s kit comparison
Hi.
I was trying to search pictures, but no luck.
Can anyone post pictures for 07-08 base TL with regular underbody kit and a-spec kit?
I would like to compare between 2 of them.
Please help me out.
Thanks.
Please help me out.
Thanks.
thank you for photos, so if I get 07 base model, and I can still put a-spec kit like 04-06 model? It looks like same a-spec kit that goes with 04-06 model for 2nd car. Is that right?
Bone stock tl-s
no, if you get the 07 base it will only fit the 07 base tl, it is shaped differently around the fog light area. the 04-06 does not have fogs so it is different. if you have a type-s the base will only fit if you have it customized like i did. otherwise it will not fit either, fog light area is slightly different between base 07 and type-s 07.
Dude, you are my inspiration for the whole going with an Aspec front lip...Your wdp looks killer with it. Id pay you to do mine so that it would fit my 07 type s front bumper...
Damn I SOOOOOOOO wish the the 07/08 Type S A-Spec kit looked like the base A-Spec. Im not sure if I like the dramatic "fighter" kit look of the Type S A-spec kit. Only if they made the Type S kit like the 07/08 kit and not require any modifications.
May i ask, since ive decided to use the 07 type s front bumper on my conversion, what sort of custom mods are you talking to fit that base aspec front? Just the foglamp fitting right?
Received 6,470 Likes
Minkl is basically correct (with the drawing). The foglights on the Type S "point out" at the edges and the fogs on the Base TL foglights curve in. I had a side by side comparison a long time ago-I can't remember where it is though.
front lip question
ok so to my opinion i think the 07 base aspec front lip will still fit an 04 base with no fogs. am i correct? or will there need to be a little modifications?
I can never tell the diff btwn 07 base TL fog lights vs 07 Type s Fog lights. I was wondering if anyone here installed the type s aspec lip for the rear bumper and the base TL lip for the front bumper. I like the 07 basel TL lip over the type S aspec lip. But the aspec type s lip for the rear looks hot as well. Would it look odd combining both the front base lip and rear type s lip?
That's exactly what I have on my 05.
07-08 base A-spec front, w/ 07-08 TL-S A-spec rear w/ ATLP quad exhaust.
07-08 fog housings are the same, but the outer black shroud/ black grille shape is different between the base/TL-S.
post some pics. i want to see it from distance. Does it match or does it look kind of off?
mrkingstonvi
02-22-2016 01:53 PM
handsom-hustla
11-13-2015 05:04 PM
MrHeeltoe
79
10-14-2015 08:47 AM
