XLR8 J-Pipe V1 w/ Hi-Flow Cat & XLR8 CatBack vs XLR8 J-Pipe V2 w/o Cat & XLR8 Exhaust
Hello all, I am new here and I am trying to get some feedback/input on weather to do the XLR8 J-Pipe that keeps the cat (not to attract unwanted attention from the wrong ppl) add a hi-flow cat and throw on the XLR8 CatBack Exhaust or just do the XLR8 J-Pipe V2 delete the third cat and put the exhaust on? Any and all info would be greatly appreciated..........BTW I have a 3G (05) TL 5AT w/ NAVI
There is a dyno test on a J30 that had the XLR8 v1 and a high flow cat. The XLR8 v2 made an additional 10 hp and 9 lb-ft of torque. No visual inspection here, just check for codes so I went with the v2. No problems passing yearly emission/safety inspections.
Former Sponsor
I would definitely recommend the V2 j-pipe combo with our XLR8 exhaust. The third cat isn't monitored and won't trigger a CEL when eliminated. It should pass visual inspection in most states since you've still retained the factory pre-cats.
Here is the thread about it: http://honda-tech.com/showthread.php?t=3023862
I have the XLR8 Quad exhaust and XLR8 V2 J-pipe, Get the V2, the second cat is there only for making the car an "ultra low emmision vehicle." It wont add any rasp and sounds like sex
I really really hate to be "that guy", but I remember seeing a comment in one of the many exhaust/j-pipe threads about which j-pipe made power where in the RPM range.
I for the life of me cannot find that now. Comparing the big three (RV6, XLR8 and ATLP), which j-pipe made power where in the rpm range. I remember one was good for low rpm, one was good for high rpm (aka racing) and one was somewhere in the middle.
Can anyone help??
Can anyone help??
Delete the 3rd cat. It's useless, unless you're an environmentalist.
I believe RV6 made the most low end power, ATLP the most top end, and XLR8 in the middle. Correct me if wrong, going off memory here. Don't recall which made the most HP vs TQ. But I also remember something about our crazy ECU constantly adjusting things on the dyno, thus making that test subjective?
Honestly, I think the biggest difference and the question you want to ask yourself is to keep the 3rd cat or not to keep the 3rd cat? I say get rid of it, especially if you're looking for performance.
on the street, where the pipe makes the gain(low mid high) is negligible.
our car is made to make peak power in vtec.
so, as long as you accelerate to 4k RPM and beyond you'll feel the jpipe's gains and edge out any stock TL's.
When people do multiple mods at once ; ie. PCD's & j-pipe....
Outcome : " Bro I gained a healthy amount of torque at 2.5k RPM up ..... "
I say .....
Each and every Mod will perform differently on your car.
Also each j-pipe adds "power" differently.
The rv6 v3 j-pipe adds power vs stock only in the low-mid range.
It actually loses on top end ! I lost 6whp & 12wtq. Peak Power !
The Atlp v2 gains power vs stock on upper RPM's only.
The xlr8 v2 is supposed to be a balance, due to its design. I've seen it gain low, mid and top end. I will be doing a b4/after Dyno.
Now if you take :
Tl a ) stock makes 210whp
Tl b) PCD's makes 226whp ( gained 16whp )
Tl c ) PCD's & rv6 v3 j-pipe 220whp ( bro I gained a healthy amount of power )
I see it time and time again ppl add multiple bolt-ons at once and then say "wow" I see gains. You would be shocked if you actually installed these mods 1by1 and gathered there results.
And I would suggest getting XLr8 v2 j-pipe !
^breaux, calm down. stop splitting hairs.
that's all you're doing.
we can put both under the microscope.
both pipes will make power.
the xlr8 is designed and molded After the Rv6.....
both make power, son.
I've had both. First the XLR8 and now the RV6 one. I did notice a slight loss in the top end with the RV6, but I gained in the low and mid range, and the car still pulls harder than stock up high. I do miss the pull up top with XLR8 sometimes, but now I don't have to rev it up past 4k to feel it anymore, the car just pulls hard across the whole band, and that satisfies me more in a daily driver. Both companies make great quality products IMO, you really can't go wrong with either one.
IMO, choose the J-pipe according to your exhaust choice. If you want to keep it a single exhaust, go with the XLR8 J-pipe. If you want a dual exhaust, go with the RV6 J-pipe. My $0.02.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
