XLR8 Engine Torque Damper: '04-'08 TL Manual
Old 03-28-2016, 03:51 PM
  #281
rockstar143's Avatar
Received 19,916 Likes on 14,458 Posts
another thing is that the oem cats, are VERY robust and can probably support the engine on their own...and most people swapping motor mounts are probably so modified that they have some form of high flow/pcd cat that isn't built as obese (weight savings) so we end up creating the issue with that perfect scenario...more power, less support, then hard mounts.
I think the ETD with firm mounts will be a good set up to save the exhaust.
Old 04-16-2016, 05:28 PM
  #282
evarela25's Avatar
Hey guys, just installed my ETD but confused on the bushings where exactly do they go ?
treal512 (04-16-2017)
Old 04-17-2016, 09:40 AM
  #283
Don't they go outside? Or on the inside of the piston? Or are those just a different hardness set than the ones that are already inside.
Old 04-17-2016, 03:04 PM
  #284
evarela25's Avatar
I read over the thread again and I guess they go inside somehow to adjust the stiffness, I installed it and drove around no problems but I didn't know I needed to use the 2 washers on the oem bolts to the bracket.
Old 04-12-2018, 04:04 PM
  #285
jagz's Avatar
I'm replacing engine and transmission mounts from Acura TL type-S 6 MT. Do I need to get a new engine shock along with the engine Torque Damper ?
Old 04-12-2018, 08:10 PM
  #286
jagz's Avatar
Please recommend a shop around Bay area(Sunnyvale) where I can get this done ?
Old 06-05-2018, 02:37 PM
  #287
AT_AT_888's Avatar
The shock and the damper are the same thing. You're replacing the stock black engine "shock," or damper, with the new silver NRG damper (aka shock).
Old 06-26-2018, 01:00 PM
  #288
AT_AT_888's Avatar
If you reference this picture from the original product thread, one of those bushings goes on the outiside of the lower joint. This is how I installed mine and it looked correct.
Thread - https://goo.gl/tiBxVs
Old 06-26-2018, 01:49 PM
  #289
AT_AT_888's Avatar
^^^ I assume the second (black) bushing is just an extra in case this one wears out? Or maybe it can be used inside the damper for a softer setting? I am unclear, but I like how the car drives now so I'm not worried about it.
Old 09-08-2018, 09:09 AM
  #290
fishinmagician's Avatar
Do I have to remove anything to get to this? I can't even see where the stock damper sits
Old 11-17-2018, 06:14 PM
  #291
Nevermind, I got it. for some reason I thought I had to work from the top. Went underneath the car and It's easy to access, you just need an 18" long ratchet.To adjust the damper, do I tighten the fisheye bolt or the bigger bolt in the body of the part?
Old 11-19-2018, 08:26 AM
  #292
AT_AT_888's Avatar
Ideally you want them both adjusted somewhat equally. You don't want one screwed in all the way while the other is hanging on by a couple of threads. Like in this picture -
Old 11-19-2018, 09:06 AM
  #293
That is how I have it. Thanks.
Old 03-04-2020, 11:23 AM
  #294
Infanity's Avatar
Hey guys I just purchased this. What do i need to explain to the guy that will be installing this?
I read for loctite but loctite what exactly?
Old 03-05-2020, 09:53 PM
  #295
probably the threads and where the bolts will sit once you get it dialed in.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
jamestheunderdog
07-19-2016 07:58 PM
ExcelerateRep
12-11-2015 12:58 PM
sockr1
10-01-2015 01:31 AM
09-14-2015 03:16 PM
Quick Reply: XLR8 Engine Torque Damper: '04-'08 TL Manual
