XLR8 Engine Torque Damper: '04-'08 TL Manual
1 Attachment(s)
Attachment 53957
The XLR8 Performance Engine Torque Damper is designed to reduce engine movement and therefore improve handling and traction. This will help reduce wheel hop, improve cornering and stability, and help the engine stay planted during quick shifts and launches. This kit includes everything needed to install the kit: damper, bracket, hardware, and additional bushings. http://d5otzd52uv6zz.cloudfront.net/...a4a744-420.jpg http://store.excelerateperformance.c.../i-300876.aspx |
Here is the review from the member who tested it for us:
Everything bolted up as I predicted, the installed was a success. The damper is length adjustable. It comes at shortest length in the box and needs to be extended for this installation. (Shown in pics) I test drove the car pretty hard for 2 days after install; several trips and various road conditions each day (crappy pavement, slippery rainy weather, curvy mountain roads...) * I tested a quick 0-60 onto a highway, the car felt perfectly solid the whole time, no longer felt like mounts were broken. * I no longer need to baby my shifts while cruising to make them feel smoothe. * Downshifting feel has also improved, rev matching has become super smoothe and easier to perform. * Shifting while taking a corner feels much much more stable due to virtually no engine movement. * Quick shifting at high rpm's now won't give passengers whip-lash. I absolutely felt a difference with this damper vs my stock one. Moving from a complete stop now feels like it should, the car does exactly what you want it to do (take off smoothly). Getting out of first used to be a nightmare (especially up a hill), the rocking of the engine made the entire car kinda bounce a bit as if it had hydrolics up front. I actually tried to replicate that hydrolics bounce feel by pumping the gas at a low speed, but now it isn't possible (a good thing of course). Any time the clutch is engaged or the instant the gas pedal is floored you will feel a huge difference before and after. I can now drive comfortably in traffic using 1st gear alone. Engine used to rock back and forth making it exremely annoying to stop and go multiple times. All in all, the car feels way better than ever, I'd even say better than when the 3G was new! I think it's ready for a Azine thread/full release! Feel free to use my review/pics to get it started. |
4 Attachment(s)
Here are some pics related to the kit and for installation purposes. Keep in mind we included a shorter bolt so you do not need to use the poly bushing as a spacer like shown in the picture. The bushing is for the firmness of the ETD itself.
Attachment 53953 Attachment 53954 Attachment 53955 Attachment 53956 |
Manual Transmission TL
http://www.acuraoemparts.com/delray/...14sep4_b47.gif Automatic Transmission TL http://www.acuraautomotiveparts.org/...p401_b4701.png I'm trying to study these pictures to figure out what bracket is needed to make the ETD work for the AT TL. I believe it's illustration #4 in the first pic. However, I haven't tested it on a AT TL so I'm not sure yet of what part is needed. The pics are a bit confusing. |
Think this will preserve those 65 durometer engine mounts a little longer... I sure don't wanna pull the SC again to replace them.
Originally Posted by Kennedy
(Post 11748217)
Im confused bc if i buy the 75a motor mount wouldnt it also eliminate wheel hop, improve tractions, and stop engine movement? why would i need this extra? i have a MT too
2nd gen fitment? id like to order one if possible. i have cash in hand!
Originally Posted by Excelerate
(Post 11748125)
http://www.acuraautomotiveparts.org/...p401_b4701.png I'm trying to study these pictures to figure out what bracket is needed to make the ETD work for the AT TL. I believe it's illustration #4 in the first pic. However, I haven't tested it on a AT TL so I'm not sure yet of what part is needed. The pics are a bit confusing. I had inACCURATE help me out, and he verified this in person a while back. |
when this comes out for automatics I will def want to pick one up
Originally Posted by salu8819
(Post 11748577)
It's similar to installing a j-pipe. The idea of the j-pipe is to increase hp/tq and exhaust flow; would that preclude you from installing a high flow third cat b/c you already installed the j-pipe? No, you would install both pieces to improve exhaust flow. So you would buy both the ETD and the mounts if you want to reduce engine movement as much as possible. |
Originally Posted by HQTL6SPD
(Post 11748707)
Pic below is from a 6MT http://pic80.picturetrail.com/VOL836.../382886045.jpg Pic below is from a 6MT http://pic80.picturetrail.com/VOL836.../382886051.jpg Hole #3 is there on the 5AT. Hole #1 and #2 is NOT there on the 5AT. There is not even a raised boss in that location. I got under the car to get a good look. I checked the schematics and I see that the 6MT and 5AT do have different engine brackets. So, that explains it there. The engine bracket for the 5AT is lacking the holes, whereas the seperate part number for the 6MT does have the holes. 50610-SEP-A10 BRACKET, RR. ENGINE MOUNTING (MT) 50610-SDB-A01 BRACKET, RR. ENGINE MOUNTING http://pic80.picturetrail.com/VOL836.../375082119.jpg http://pic80.picturetrail.com/VOL836.../375077633.jpg |
Ok thank you Inaccurate. So will they only need the one bracket or two?
Inaccurate, thanks for showing it all in detail. :cool:
(Post 11749298)
excelerate will this fit my accord? i have 2003 v6 accord sedan auto, but now with tl 6-speed tranny in it.
Just to be correct this damper replaces the stock damper on manual transmissions
I CANT WAIT TO GET THIS ON MY 5at TRANNY
(Post 11749206)
Well the mounts don't eliminate wheel hop; they reduce it significantly.
It's similar to installing a j-pipe. The idea of the j-pipe is to increase hp/tq and exhaust flow; would that preclude you from installing a high flow third cat b/c you already installed the j-pipe? No, you would install both pieces to improve exhaust flow. So you would buy both the ETD and the mounts if you want to reduce engine movement as much as possible. Thanx for the explanation I understand. Great products!! |
Originally Posted by melvin2816
(Post 11749784)
dope!!....ill be getting this soon :thumbsup:
How hard is this to install? Also, did the tester car have the aftermarket engine mounts already installed too?
(Post 11749937)
The main job of the ETD is to reduce initial shock of the engine when it rocks back (under acceleration, fast shifting....) The two work great as a team. While a stiff mount does its job well, running it alone back there still means its doing the job of two components. With all the stress it has to deal with from this heavy engine, it will inevitably start to feel the abuse after time. The ETD absorbs a large amount of torque that transfers from the engine under sudden movement or acceleration. The ETD can significantly increase the life and performance of your mount just by absorbing/dispersing that shock. Anyone who does a before and after should notice a difference with a test drive. Possibly even from a start-up, I know I did. |
Originally Posted by tenzingsherpa
(Post 11749363)
(Post 11749784)
(Post 11750013)
Yup, its a direct replacement. :thumbsup:
im gonna look today if i can install this dampner. i checked the accord auto shematics and as far as auto accords it seems like it wont fit. However, 04accordcpe has had an engine swap to a j32 from a 3rd gen tl, and i wonder if he needed to change his rear engine bracket to a 3rd gen rear engine bracket to bolt on the tl engine? if not, it seems like all the 7th gen needs is the 3rd gen tl 6-speed rear engine bracket. :) hopefully this will work for accords too!!!
Originally Posted by jerome736
(Post 11750128)
how hard is this to install? Also, did the tester car have the aftermarket engine mounts already installed too?
(Post 11750131)
Just to add to what Excelerate responded:
The main job of the ETD is to reduce initial shock of the engine when it rocks back (under acceleration, fast shifting....) The two work great as a team. While a stiff mount does its job well, running it alone back there still means its doing the job of two components. With all the stress it has to deal with from this heavy engine, it will inevitably start to feel the abuse after time. The ETD absorbs a large amount of torque that transfers from the engine under sudden movement or acceleration. The ETD can significantly increase the life and performance of your mount just by absorbing/dispersing that shock. Anyone who does a before and after should notice a difference with a test drive. Possib ly even from a start-up, I know I did. |
YUP automatic 7th gen v6 accords don't have the two threaded holes either, so im assuming since the 5at is same in tl & accords then all the 7th gens need are the 3rd gen manual tl part #4 for the ETD to fit.
(Post 11750128)
(Post 11750478)
great info thank you. Is there a way I can check to see if my damper is worn out or isn't functioning properly. Bc my mount is already ripped so I'm feelIng alot of the wheel hop from that. Don't want to buy this torque damper if mine is still in good condition
Oem damper is just like suspension shocks (gas-filled), so it will wear after time/abuse. If you have ripped mounts and wheel-hop, stock damper will definitely be worn. And with the OEM, you'll need to re-purchase the entire assembly every time its worn vs. 2 small bushings.
(Post 11750722)
-But Its only half of the solution. I never looked at the subframe bracket for the Accord. You'll have to check to see if it has the #3 threaded hole right under the rear engine mount (shown below). I couldn't figure that one out on the parts website.. http://pic80.picturetrail.com/VOL836.../382886051.jpg |
Forgive me if this is a stupid question. Is the torque damper held on to the bracket only by the cotter pin?
1 Attachment(s)
kinda looks like the cc auto nrg damper kit, which ive had in my car for 3 years now. its for the 2nd, 3rd gen TL and 6th, 7th gen accord, both auto and MT. it also fits in the same spot at the rear of the engine, which is the best place for it. it helps keep the engine from rocking back and pulling up on the front mount.
Attachment 53948 |
Originally Posted by illstrategy
(Post 11751210)
This product looks great but I am going to wait for some more feedback from fellow aziners that have this product in their ride.
Nicely done excelerate |
so, yay or nay for the at's?
(Post 11750987)
I crossed the parts with honda's parts website. Looks like all 7G Accords share the same engine bracket as the AT 3G TL. So you would need the same bracket for the MT.
I got to be honest. The price seems quite high. Any other NRG kit is selling for $90-$100. Whether it be on ebay or any other online performance store.
If it was an Ingall's Damper, then $150 would make sense. But it is an NRG damper. And I don't think it would be fair to pay $50-$60 more just because XLR8 is the only company with a damper for the TL. I was going to get one right away when I first heard about it, but the price has discouraged me from pulling the trigger. And now I am on the fence about it. |
Originally Posted by NCTL05
(Post 11752680)
XLR8 has the bracket made from scratch by a machine shop. Machine shops can get very pricey for small quantity production. Just cuz of the shop labor alone, this is a very very generous price. I was actually very surprised to see it this low! So with all of the packaging, parts, & labor required, I highly doubt that at this price the marginal gains for him are extraordinary...:2cents: |
(Post 11752680)
Well... I do want one.:ponder: Maybe I'll scape together some :2cents::2cents::2cents::2cents: soon.
Ordered.:tomato:Can't Wait!:ecstatic:
