where the hell do i mount boost gauge
2006 TL-S.C. 6mt
seeing the pillar air bags, where did you guys mount your boost gauges on the supacharged ones??? i cant figure out a good place if you have pix would be nice too
321 whp SAE
not quite... the a pillar only moves out a bit for the airbag to deploy. it doesn't blow off. i've seen the side air bags deployed and am confident it doesn't interfere.. if you are nervous, put it in front of the instrument cluster on the plastic shroud that covers the steering column. good luck
2006 TL-S.C. 6mt
yeah i should have it mounted today, they mounting kit that came with the gauge only allows the gauge to be mounted from the back, not from the side like i see with your gauges
tehLEGOman
Received 1,983 Likes
What brand boost guage did you buy? I'll be asking the same question once I get one.
Ryan Christopher
Fiberglass one of the vents on the upper console in the middle of the car. Why do you need all the vents? The car will still cool/heat using the rest of the vents.
CTS-V Import Slayer
Originally Posted by MichaelBenz
I mounted my boost and AFR guage on the steering column with carbon fiber gauge cups on the back.
OK, here are some pics...the top two are NOT my car...but somebody elses on here that my design in the third pic is copied after. Not a good one on the third pic I know...but its pretty much the same as the first two...only I didnt make a mounting plate, but just mounted them directly to the column itself. If you compare the two designs...basically the first two pics show his design and they are offset to the right and left a bit more as on my design on the third pic...they are a bit tighter to the column themselves. I tried to get em to hug some of the other gauge hubs more or less...so I could see everything...even these two gauges without a problem...but honestly...I dont know about the first design..but I have to wrench my head around a bit to see the info display screen...but honestly..never paid attention to it anyway...so no big deal.
![](https://i68.photobucket.com/albums/i14/michaelbenz/Gauges.jpg)
![](https://i68.photobucket.com/albums/i14/michaelbenz/Gauges2.jpg)
![](https://i68.photobucket.com/albums/i14/michaelbenz/DSC00051.jpg)
Received 3,791 Likes
^^^^ eehhhh its function but looks tacky in my opinion. need to find a cleaner place to install them.
CTS-V Import Slayer
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Ryan Christopher
I do understand your opinion....but rather than be the typical "armchair quarterback" Acurazine is famous for.... why dont you come up with better solutions rather than nothing more than more or less..."honoring" us with your opinion? Solutions are WAY more helpful that just reining down on us with your opinions. Thanks for your opinion anyway....its people like this that keep the pool of new options and ideas presented here on AZ semi-limited as nobody wants to "show and tell" new ideas anymore. ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
CTS-V Import Slayer
Originally Posted by Black_05_TL_6SP
Sorry, just havent had the time to do the fiberglass work to get them in the center console vents. I have an extra piece already, just haven't had any time to work on it. Hope to play with it some this summer. Really busy with the strut bar and the other work I have going on!!! Jason
Wow, don't know how I missed this one. After debating this topic for a while, I finally decided to mount the gauge in the most discrete location I could think of... near the ignition switch, right below the speedometer. I know some ppl may think it's a bad location, but I can see it clearly, and best thing is, no one else can
I'll snap a few pics once it's daylight over here.
