VSA vs. Racelogic traction control ???
Would the Racelogic traction control system offer any performance advantage over the stock VSA in a 2006 TL 5A/T?? Is there much difference in the way they function? Would this be an easy install?
Thanks,
aarmd
Thanks,
aarmd
Just learn how to drive the car right. You can run rings around a computer with practice. Ask any pro driver or driving instructor and they will tell you the same. It's an auto 258hp FWD car for God's sake.
So I take it that you drive with the VSA turned off??
I actually asked this question with safety, not speed, in mind.
Does anyone have experience with the Racelogic system??
aarmd
aarmd
Im not sure which "stock" 5AT car your talking about but im pretty sure that most will agree that the Type S has a boat load of traction issues! under hard acceleration the car just spins with VSA off and with it on you cant get anywhere near a decent launch with out the VSA cutting throttle.
Splitting the torque front and rear on an AWD car is fine.
ABS and stability control only hinder performance on a racetrack with a good driver.
I just did $10,000 worth of damage to my TL because of an ABS induced brake failure on a washboard road.
This stuff is fine for when my girlfriend drives my car but if I were the only one that was driving, it would be without ABS and stability control.
If everyone was forced to take a real driving course as in learning proper braking and skid control, these electronic gadgets wouldn't be on cars. They are nothing more than a band-aid for people that can't drive.
With that said, I'm glad cars have these features for 99% of the people out there.
practicing nihilist
That's what the pedal on the right is for. If you know your car, you know how much pedal to give it and how quickly to feed it full throttle. It's 280hp, it's not hard to hold down. The TL is not some burnout monster that will light the tires on accident. I test drove both the manual and auto Type S when I was thinking about getting a new one and with the auto version I could give it full throttle in first gear with no spinning. If I purposely stomped it to the floor from a dead stop, it spun a little but what do you expect?
concur. I grew up with front wheel drive imports (mostly VW's) and the gas was always to the floor. Now, it wasn't always the smartest way, but you learned a cars limit pretty quickly.
These days I scoff at those STI's blowing by me on the highway but I prefer to drive with the VSA off.
'03 ABP YA4-S 6MT
Why is it that all the hardcore dragracers, especially the Vette guys go much faster without traction control on?
Why is it that in my own measured tests, I have stopped my TL quicker with no ABS than with it over and over again on the same road in the same spot on the same day.
Stability control for cornering is still open. I don't necessarily think it hurts performance as long as it doesn't interfere with placing the car on the track using throttle. It really depends on how intrusive it is.
One thing is for sure, the TL's traction control is very conservative, pulling massive amounts of throttle and then putting it back in way too slow. Not a bad thing since it's designed to stop wheelspin, not cut a great 60' time at the track.
It's ABS hinders braking performance in good conditions although after installing DOT 5.1 (thinner) brake fluid it seems to keep it more on the "edge" of lockup.
It's not RWD so the stability control doesn't bother me.
I'll say again, these electronic gadgets are great for people who can't drive. I feel better knowing they are there for when the girlfriend drives the car.
If you do lock a tire, you back off the pedal a little and get back on it. Even if you stomp the pedal to the floor hard and lock all 4 tires, you again let off the brakes and do whatever steering corrections are necessary. It's easy.
'03 ABP YA4-S 6MT
F1 technology being compared to street car technology. I don't watch F1 so I have no idea if the rear kicks out more or not and I'm sure you haven't tallied up the numbers before and after traction control.
I agree with pretty much all of that. One thing to point out is most people think ABS reduces stopping distances. I know why it was designed, for the people who stomp the brakes as hard as they can and turn the wheel as quick as they can at the same time. So my argument stands that it's a band-aid for poor driving skill. And again, I admit it's great for the general population.
I disagree about modern ABS not stopping in shorter distances, at least on high traction surfaces, such as a dry paved road. ABS has been around since 78, and it has improved dramatically in those 30 years. It will tend to increase stopping distances in icy or wet conditions, and gravel roads.
I think you tend to underestimate today's technology and overestimate your own capabilities, as well as lend too much credence to your anecdotal tests.
Unfortunately, as with most situations where capabilities are overestimated, if anything negative were to happen, it would be due to circumstances beyond your control, and not due to either lack of skill, or not having ABS.
You have this backwards, ABS will hinder dry braking performance assuming a good driver but has the potential to help wet braking performance.
Saying I'm overestimating my driving skill is based on what, your opinion? I've driven a 10 second car for nearly half my life, many times on street tire and for many years my daily driver with no accidents, spins, or close calls. And this is without electronic band-aids like ABS and stability control. I must be doing something right. Your entire post is based in assumption.
Jamus22
06-11-2023 10:08 AM
adreano17
09-29-2015 08:48 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
