UR Crank Pulley and Comptech S/C
Old Oct 26, 2005 | 03:22 PM
encrypted03's Avatar
Just wondering, since those who will be getting the S/C who will probably order the crank pulley, what belt would we need to use?
Old Oct 26, 2005 | 03:36 PM
blktl1's Avatar
I dunno but I also raised the question previously about whether the crank pulley will raise boost issues because the crank pulley makes your accessories spin slower and I dont know if the S/C will spin slower and you will lose boost. I am getting the S/C and I have the Pulley that I am putting on tomorrow.
Old Oct 26, 2005 | 04:04 PM
MugenR's Avatar
300whp 237wtrq
In order to raise boost you get smaller pulleys. just FYI
Old Oct 26, 2005 | 04:22 PM
blktl1's Avatar
That is on the S/c though. If you Get the aftermarket pulley by Ur then yor accessories will be spinning slower. I think that means the S/C pulley will spin slower so i dont know if thats a good way to go. Please correct me if im wrong.
Old Oct 26, 2005 | 06:47 PM
skyy406's Avatar
Resident auto maniac
The way you can tell if you accessories will spin slower is this. If the Ur pulley has a larger diamater than the stock pully- then the accessories WILL spin SLOWER. If its smaller then they will spin faster. Same concept with a Supercharger.
Old Oct 26, 2005 | 08:53 PM
invincible569's Avatar
Good questions. So what is the crank pulley size you can use when using the S/C?
Old Oct 27, 2005 | 04:49 AM
special-ed's Avatar
Iro Ridg .308
I believe you have it backwards. Since in your example, UR pulley=larger gear. Accessories=smaller gear. Larger gear makes smaller gear turn faster.
However, the UR pulleys are smaller in diameter thus UR pulley=smaller gear driving the larger accessory gears, thus accessories will run slower but not by much.
Old Nov 7, 2005 | 04:35 AM
00accordtyper's Avatar
You don't want to use the UR pulley with the SC. It will cause you to lose boost. Its a noticable amount of lose also. If you ask UR nice I'm sure they will make a stock diameter crank for the TL to use with the SC. They did it for us accord and second gen acura owners.
acuratl26
Apr 23, 2020 07:30 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
k6biv
Sep 22, 2015 02:06 PM
