Upgraded brakes?
8th Gear
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Ey guys sorry if im reposting a thread but finally got the money dept of defense owes me.
Looking for some slotted/drilled rotors to put on the TL and not break my bank to much. Change the pads as well to ceramic as well. Obv dont to cheap out on brakes . Looking for some recommendations on brands/websites. Thanks for the help guys.
pearlUA7 (11-28-2012)
i dont know why other than I have been new to things before..
What are you after? exactly? and how would you prioritize?
Looks? stopping power? do you drive like you stole it? very aggressive or occasionally aggressive? or just spirited?
What also is the cost limit you have?
what 1black said is correct though, there is a lot of info out there and a lot of opinions.. I would say once you kind of know what you want the search would be much easier
Former Sponsor
http://store.excelerateperformance.c...s/g-63863.aspx
The packages include Powerslot/STOPTECH performance rotors and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The Powerslot slotted rotors for the front of most Acuras also have a Power Alloy composition and a curved vane construction, which helps reduce heat in the brake system. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
However we can substitute ceramic pads for you if you'd like. PM me for more info.
Rich
https://acurazine.com/forums/showthr...809114&page=37
THese guys doing the group buy right now on the 6spd and TL-S.
But even for regular TL still pretty cheap.
TL-S
If you're looking for PERFORMANCE, then Excelerate does have good package
If you just want less dust and good looks for a daily driver, then Brakemotive kits are 1/2 the price. I think somewhere around:
150$ for regular brakes (automatic transmission)
225$ for Brembo (if you have 6MT or a Type-S)
and those prices are including shipping for 4 sets of pads and 4 rotors, front and rear. Its a great deal.
AcuraIntegTL (12-20-2012)
I suggest you research the differences between slotted/drilled and plain rotors. Very little documented proof that slotted/drilled provides any better performance than plain rotors. A big brake kit makes more sense as rotor surface area increases and you have more/bigger pistons on the calipers. If you find any decent information on rotors, post a link here.
I've posted a ton of information on brakes on here with a ton of my own data with different pads, rotors, calipers, stopping distances with various BBKs on my car, etc. Its out there you just have to look.
Get a bbk if you are wanting the best performance. Drilled and slotted rotors are pretty much for looks only. Look at the F1 brakes, they are plain rotors.
F1 brakes aren't drilled because they're carbon. I've posted the white paper results as well as my own on drilled vs slotted vs blank. For performance blank and slotted is the way to go. Again, the research has been done and is on this site.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
