Unsure upgrades...
One last go.. Can anyone confirm the 3.7MDX manifold being a direct bolt on for my 3.2 base also?... I found it at a slightly less expensive price... Is there anything different between a 3.7 SH-AWD manifold and 3.7 MDX upper intake manifold?
I'm sure the manifold will bolt on but the question is will the ZDX or TL-SHAWD throttle body also bolt on?
My '12 accord manifold is identical to the ZDX manifold except a few things..
- No vacuum line for the engine mounts
- Smaller than the ZDX/TL-SHAWD manifold
- Smaller throttle body opening
Will the MDX manifold fit? I'm sure it will since people use the MDX spacer. Will you be able to bolt up the 3.7L TB if you go that route? I don't know.
So here a few updates.... I did go with the MDX upoer intake manifold which is infact pretty light...
Got it from the junkyard. $120 shipped
Totally forgot about top plate lmao.. So now its sitting in trunk
Also grabbed the zdx throttlebody another $120 shipped.. 30k miles on it... Waiting on the tubing for 4" UBI intake kit and top plate to install... Would def do before and after dynos if folks wanna see the difference... Pitch in for at least half they dyno n im sure i can find a dyno day around or just go dyno on my next day off...
elduderino
Jun 2, 2005 07:53 PM
