Throttle Body?
.43g at 900+fps
i have one. go to
www.kingmotorsports.com
no one makes a throttle body but you can have it bored out. be warned, your vsa may not work afterwards.
.43g at 900+fps
i have a posting on here explaining it... to make a long story short, the vsa disables itself for some reason after the service... the vsa is built into the tb, so if you like your vsa, don't do it. i don't like the vsa so it's actually a plus.
Not your moms TL.
ok..I went to street and performance today. They used my 07 tls to prototype a helix...their version of the TB spacer...He said he thinks that th 03-04 v6 accord TB would bolt and plug up to our intake manifold, and has a 1/4" bigger bore for more wide open throttle power....I looked all day for one in some salvage yards and even went to the honda delership but i could not find one anywhere to measure and compare....does anyone else know anything about this or have one to measure? The TL TB measures around a 2.5" bore...and he says the 03-04 accord v6 should be around 2.75".....
Better things to spend money on
And it depends on where in the power band you want more action
Thats what I was thinking, what areas or if any have you seen power increases? How much did you have it bored, as far as the accord part, I wouldnt be suprised if it fits because i have heard of other parts from the accord coupe fitting the TL...
.43g at 900+fps
i wouldn't put any accord parts into my tl. unless it shares the same part number. and i haven't felt any power loss to my vehicle either. i can easily keep up with and accelerate with mildly modified g35s. i've already put it to the test.
.43g at 900+fps
well, the tl would be considered a better performance car to begin with. why would you downgrade? i know there are interchangeable parts, like they both have the same cams. i know the gaskets sets are the same too. but i would highly doubt that the accord tb would be larger than the tls. i used to put b18a/b/c tb on d16 sohc vtec manifolds and match port them. that was awesome. it sure beats 400 for an aftermarket tb. but the accord with a smaller displacement engine would most likely have the same size if not smaller tb
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
