Supercharging the TL
#802
Former Whyner
#803
18psi
My MID says I averaged around 36mpg for about 500 miles LOL. Pre-turbo on a weekly basis, I was lucky if I saw 23mpg to a tank.
After crunching the numbers, Im getting about 30-40 miles less per tank post-turbo. I dont really beat on the car either. Some days I dont even seen any boost
#809
yes paul is working on that additional piggyback; i've been waiting patiently. didn't know bmeyer was working on one as well. when i was running the fic without the ability to control the closed loop functions, the car would drive fine for awhile, but goes into limp mode. back then i didn't have the scanner to erase the code, so a flat bed had to be called. the same thing happened a few weeks later, so i got fed up and disconnected the fic and ran the acm. not the greatest thing, but at least the car doesn't go into limp mode and stall. just have to keep the 'spirited' drives to a minimum
#811
2) i would assume that would work. but for the people that installed the s/c as instructed by the manual, the battery is located right below the s/c. unless the person has girly hands, good luck trying to get down there with a handtool and disconnect the battery. that's why relocating the battery to the trunk is a smart idea...of course, hind sight is 20/20
now i got a scanner sitting the trunk, but i am just running the acm without the knock sensor wire. it runs really good (touch wood) while in closed loop. during the 'spirited' drives, it behaves just like everyone else without the fic (hence no tune)...running rich, surge..etc. but over 90% of my driving is in closed loop...so running without the fic doesn't bother me that much. that's why i said 'i am waiting patiently'
#813
^^ yea...it was freaky. a lot of bystanders gave the 'wtf' look
now i got the fic, modified harness, and the rsx-s injectors sitting there doing f-all. hopefully this closed-loop solution comes out soon, otherwise i have this thing sitting in the engine for show, but 'no go'. 110% poser
#814
347hp/300tq @ 4psi
are you sure its the FI/c causing it to go into limp mode? did you make sure the map sensor wires that were spliced for the ACM were tight? i know i had a problem, when the quick dissconnects that i installed when i ran the ACM for a brief time, while the harness was getting repaired werent making good contact...
ive been running successfully tuned with the FI/c with ZERO issues going on over a year now. the ONLY trouble i have is a stumble from closed to open loop between 1/2-3/4 throttle (just like the ACM) but cruising speeds and WOT is absolutley perfect
#815
I had a freak issue once while cruising down the freeway and it felt like the accelerator pedal came completely unhooked. All the warning lights came on and I had maybe 2% throttle control. I was lucky that I could idle it into a Home Depot to pick up some huge zip-ties to wire the S/C bypass valve open and completely remove the F/IC.
The code it threw was something like throttle position sensor malfunction. I can't remember exactly.
I remember it was abnormally hot that day (~100+). I'm guessing the F/IC either got too hot, or a plug came unhooked just enough to cause it.
#816
as for the sensor wire, i also used quick connects. i made sure everything was crimped down, and verified the connection with the continuity test.
Did you ever check your fault codes?
#817
For the SC guys who buried their battery, I think you can pop the top off the under hood fuse box and disconnect the front lead which comes from the battery. The other end from the battery goes to the starter and I don't think it goes anywhere else.
It'll only need a philips screwdriver.
#818
runnin a little boost
If I remember correctly the front post on my set up was the positive side, if you van keep the tool from contacting any metal. Look at the ECU fuse or buy a cheap scanner. Mine was $85 and data logs. If you get a scanner that uses a computer it takes alot of the cost out of the picture. Summit should also have some cheap scanners, Costco was selling one for $30 it might be in the online store.
#819
Former Whyner
Howz everyone doing? Just thought Id update on this thread as it seems to be one of the many good SC'd threads out there.
Ok im about 14K miles post blower and I must say it still runs very well. I do have a problem though Looks like for the 2nd time oil is seeping out of the EGR cam seal (where the support bracket attaches too. I swear this thing is a PITA and it is getting worse (leaking oil) now because there is oil everwhere and its burning off and it stinks and smoke tends to show from my headlight at night.
Unfortunatly this is my daily driver and I cannot pull the blower till Saturday morning but just looking under there im very scared to think it might be something other than this damn seal. Ill post pics then.
Anyone have issues with this before? I mean its just a mount bracket right?... so i dont suppose i can throw the factor seal cap in and not support that section? I dont think it would be a good idea
#821
OMGWTF4THGENTL
#822
iWhine
THREAD REVIVAL!
I followed this thread so figured I would post this here as well since I started a thread in the problems and fixes section. I figured I would get more answers here.
The linky:
https://acurazine.com/forums/3g-tl-problems-fixes-114/supercharged-but-starting-problems-caused-869089/
Cliffs:
Recently S/C. Car turns over but doesn't always catch and start as quick as it did when pre S/C. New battery. New Plugs.
Anyone else have this issue when they were S/C?
The linky:
Cliffs:
#824
Superstressed
THREAD REVIVAL!
The linky:
https://acurazine.com/forums/showthread.php?t=869089
Cliffs:
The linky:
Cliffs:
#827
Superstressed
Are you speaking in reference to the ACM unit that comes with the the comptech S/C? Yes I am using the ACM. Did you ever solve the issue?[/quote]
No not the ACM Comptech supplied, the FIC which is made by AEM. The FIC is a piggyback computer that will allow you to adjust fuel and ignition parameters.
And no, the taking longer to start issue is still there.
#828
It's going to be something to do with the primative engine management that comes with the supercharger or the beginning of engine damage. What measures have you taken to ensure there's no knock? Knock gauge? Methanol injection?
If it's compression related, chances are it would have a misfire so you might be lucky there.
Make sure the bypass is open when it's cranking.
Make sure the fuel pump comes on to prime the system when you first turn the key on. When you first go to start it, turn the key to on, pause, start it. If it starts normally with the pause, it's probably a regulator assuming it runs normal at full throttle.
I agree with the others, go back to stock parameters, see how it starts, stay away from boost.
#830
iWhine S/C 6MT TL
Hi guys, I need some experts to chime in.
I don't have the ACM for my supercharger, I do have the AEM FIC with pnp harness. Is there anywhere to run the car without the ACM and get it tuned?
2nd off, If I decide to crush the fuel pressure regulator and use the AEM will it still be ok?
For those in NJ, who can do the programing, and what's exactly is needed to program an AEM?
#832
does the ct acm unit need to be tuned?
hey guys i just got the acm from ct engineering because i had aem fic with supercharger but the tuning shop didn't know how to tune it. so ct sent acm unit. does it need to be tuned or i can just hook it up and drive off with no problems.
#834
iWhine
delayed starting issue fixed...
Here's the thread again for reference and maybe more detail...
https://acurazine.com/forums/showthr...2#post14109272
#836
A J35A8 EG civic is in
I didn't want to start a whole new thread so I figured I'd revive this one since it has the knowledgeable people to help me out. I will be doing my S/C install tomorrow and needed a little advice.
So I spent the past couple weeks, maybe even month, reading thru this whole thread to get my understanding of the S/C down. Everybody always says that you shouldn't boost if you've never done it before, but I have to start somewhere right? lol. Well I've done my research via this thread and many other threads I've read regarding FI.
My setup will be (Base 3.2 Auto) CTSC (used kit that I bought), Hondata FlashPro, RV6 V3 PCDs and j-pipe, Greddy catback, custom CAI, A/F ratio and boost gauges, and that's about it for right now.
By the end of April I should have the 3x3 flush of Redline Type F ATF completed. In mid May I will add a knock monitor and RDX injectors. In June I will add a meth kit and trans cooler.
My Questions:
1. I should get 2 steps colder spark plugs right? Denso iK22? The kit did not include any and I would change them anyway since it is a used kit.
2. If using stock injectors, do I have to crush the FPR? I don't have the crush tool since I bought a used kit and I've read mixed opinions of it not being necessary.
3. Anything else you guys recommend adding or removing, or changing the order of in my time list for adding supporting mods?
Any and all help is greatly appreciated. Thanks in advance!
My Questions:
#837
I am not s/c'ed but from research...
-you must upgrade your plugs (two step colder) - i.e. NGK Iridiums BKR8EIX
-yes, but don't have to crush your FPR if you upgrade your injectors and/or upgrade fuel pump.
i would consider installing the tranny cooler before since the s/c will be in the way.
btw - who is doing the install and tuning your flashpro?
Goodluck, sounds like a fun build and you are well on your way with all the necessary material.
here is a more recent s/c build with all your answers:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/2012-supercharger-jr-ecu-build-841336/
sunny201 (04-10-2013)
#838
iWhine S/C 6MT TL
Sup bro! Enjoy it, while you can before temps get very hot outside. I will say it based installing the kit (I had to remove the kit and then reinstall it due to the warranty claim), it's a pretty straight forward install. Under hood temps are going to be pretty hot and I mean hot. Highly suggest you install a CAI and DON'T CONNECT the coolant lines back to the TB.
If your pushing more air you need more fuel, by crushing the regulator your going to have 10 PSI more fuel. If your installing this kit, you will need to AT LEAST crush the regulator. It won't hurt anything when you do injector upgrades. If you looking for long term you need to monitor knock and at least venture to meth kit. You will need to figure out what to do with the temps under the hood. That entire engine bay will be hot, the more you whine the hotter it gets.
I wouldn't use the old plugs unless they have very low miles. Usually from what I've been told they last approx 25K. I could be wrong. Exhaust mods are usually recommended to free up the flow. I have the ATLP J-pipe and comptech catback didn't feel the need to upgrade to precat deletes.
Keep in mind, like I said a million times, this was built and tested on a STOCK TL. Yes, the management system isn't the best but luckily now 07-08 have the flash pro (I believe the 06 as well) which will be better than the ACM. There are 2 versions to the ACM. I have the updated version that comptech did their very best to correct the surge. I will say over the winter season I surged 2-5x in the month and it being extremely minor. Now with temps rising, I may surge 2x every drive but still fairly minor.
The best way to go about this in the long term of things is full exhaust work, meth kit, tune, injectors and some other form to keep that intake manifold cooler. Like I said, this kit was put and tested for a STOCK CAR. Anything more than what you have is only a plus. Best of luck, enjoy it!
#840
08 TL & 12 ADV/ENT MDX
My Questions:
My Questions:
If your using FlashPro you dont have to Crush the FPR because you can control fuel trims with FlashPro and it will be adjusted while getting tuned. Just DONT boost past 0lbs while S/C'd and NOT tuned or Zip Tie the bypass valve open so boost will bleed out until you get it tuned Also with the FlashPro you dont have to run Colder Spark Plugs cause you can adjust timing to compensate for boosting I would recomend replacing the plugs with new ones and just go with factory spec. Pretty sure there will be other people that will say different then what i suggested but this info is from Doug the owner of Hondata himself. Good Luck!
