Supercharger problem!(Fuel Issue resolved!!!)
I installed supercharger last night and on the first run it was fine. the car took off like crazy. then the next time I start it , its starts right up and idled fine. I drove normal to gas station and started to notice some hesitation. I filled her up and then it would not alllow me to hit vtec. it has gotten progressivly worse and now every time i give her more that slight throttle she starts to choke . It almost like it hits an RPM wall. It just starts to die and I have no power. This was a brand new fuel pressure regulator and was crushed accordingly. I even replaced spark plugs again and no dice. when I pulled to Densos out this morning, the outer rim was black, so I now I am getting enough fuel! PLEASE HELP!!!
yes, I tried using octane booster and did not work. I just got off the phone with comptech and they are sending me new plugs and a new acm! well see tomorrow what happens!
Regions Leader
Regions Leader
Originally Posted by 05TLTony
Hope it works out for you bro.
You've been having bad engine problems lately. Keep us posted on the situation.
yeah man doesnt look like luck has been on your side, I hope you get all this figured out.
Well last night, I changed out my plugs and now I am not hiting the 3k rpm wall. it happens around 5 in 1st 4k in 2nd and up!! I am going to go to acura and have them check it out I think. I was having a similar problem about 2 months ago and it went away!
I have no clue whats going on!
Regions Leader
Regions Leader
Im going to forward this to my mechanic buddy at my dealer, maybe I could get some answers for you...... not sure how much experience they have with the S/C but its worth a shot...
Thanks.
I am thinking in the range of a bad coil or fowled spark plugs. I dunno how the plugs could be fowled already but you never now! thanks in advance!
I us noticed one other thing. this hesitation and problem gets much worse the longer I drive the car. If I drive it and it heats up it starts to get worse!
I have narrowed it down to be either a leak in the EGR valve gasket or a problem with my fuel system. I am not sure. it goes into acura next monday and well see what happens.
i was gonna say didn't you have this same problem b4 the S/C? last time sounded like Sunoco was the culprit. acura also said it was bad gas right? heat related eh?.....faulty computer? any CEL? good luck.
Originally Posted by ttliang
it's like ur computer is cutting fuel. is the "choke" rpm consistent right b4 Vtec? does it only happen when you WOT? can you slip thru to the higer rpm if you accel. gently?
I can slip through RPMS is I hit throttle very gently!
it could be the drive-by-wire sensor. can you rev it up freely from the engine bay?
that don't make any sense???
no load (not in gear) - you can rev no problem whatsoever.
can't be fuel system, can't it? you shouldn't be able to even rev up when parked if that's the case. what else monitor your speed/RPM/throttle position while providing fuel? ECU is the only think i can think of...if not one particular sensor. however any sensor failures/absence should trigger CEL and you have none (CEL).
it's not the rev limiter cuz you can slip to higer rpm.
it's not the pedal position sensor since you rev-ed it up at idle. it's got to be the ECU right?
is it fuel pump not providing enough fuel when the load is present? i've had a half broken (weak) FP creating similar situation when it's hot.
just trying to help. i don't think you want to deal with ecu or FP yourself anyway. just guessing. not saying for sure.
Well i went to the dealer yesterday to visit my friend. he was able to find a vaccum leak which had nothing to do with my install. the new gasket that I put on the intake manifold cover was leaking. I tightened it down and it has gotten sig. better. I ordered a new gasket and we will see if that corrects the problem!
Originally Posted by dan.....k
Good Luck. Hopefully you won't have any more problems.
Well I will let you know later today when my new gasket comes it! but I can tell you that this is definately the problem.
Originally Posted by bonesmuggler
Still odd that it didn't throw any codes, makes you wonder how the comptech acm is "tricking" the ecu...
The Boss
^ I am not surprised at all my friend. Acura dealership usually don't have guys who are familiar with Superchargers. However, we have a guy here named "John" that's been dealing with S/C for awhile. Call Sussman Acura and look for the Tech "john". Also pm Ryan to any further problems. I'll be you Ryan knows more about your problem than any of those Acura techs.
They have pretty much narrowed it down to have nothing to do with the S/C or the install. The seem to think that it is definately my fuel system. The tech thinks that I have a weak fuel pump. He said that the problem that occured before was most likely this and it didnt really surface until I needed the extra pressure from it. now it has pretty much bit the dust they beleive. I am waiting to hear from them today! they said that if it had to do with S/c it would not be happening at idle!
