Supercharger Guys Read
Old Aug 4, 2006 | 07:37 AM
BustedJack's Avatar
The Boss
Question for you guys who also have the Comptech Superchargers.
When the weather is warm, and humidity is high. Do you experience hard shifting and a big of a lag when you go into boost? I noticed that alot.
Discuss
Old Aug 4, 2006 | 07:44 AM
blktl1's Avatar
Discuss
i really cant posotively answer yuor question as I have only been boosted when it is extremely hot outside. any way it is known that your boosted motor will suffer from heat. your car will not be as responsive nor as powerful.
Old Aug 4, 2006 | 08:26 AM
bklynpanman's Avatar
321 whp SAE
yes, happens when it's hot.. the water/methanol injection helps a bit, bringing down the IAT.. wait until winter.. night and day.. especially Brett. 2nd gear up top, it's hard to keep the wheels from spinning when it's cold
Old Aug 4, 2006 | 08:41 AM
blktl1's Avatar
Yeah even this morning when it got into the 70's i could feel it pulling much harder than the last couple of days int he 100's
Old Aug 4, 2006 | 09:34 AM
Excelerate's Avatar
Former Sponsor
You car will be a totally different beast in the fall/winter. When it is more humid and hot there is less oxygen molecules in the air. Colder/denser air has more oxygen molecules packed in side and therefore you make more power. It's the worst. My car used to be able spin the tires throughout all of 2nd gear (in the spring) but the heat is killing it so now it only breaks loose once in a while. Basically you have more hot air going in with your intake charge now, so less power.
Old Aug 4, 2006 | 12:45 PM
blktl1's Avatar
hey jack,
I just found this. It should expain your loss of power.
Fact: For every 3.3 °C (5° F) rise in intake temperature, air density drops 1%. The hotter the air, the less fuel the computer injects to compensate for reduced oxygen.
Old Aug 4, 2006 | 12:47 PM
BustedJack's Avatar
The Boss
whoa nice find Brett! Yeah I noticed that yesterday when it was 110 degrees.
thanks for all the response. Just want to make sure I'm not the only one. I guess that goes the same with Turbo cars. As Josh's accord is Turbo rather than S/C'd.
Old Aug 4, 2006 | 04:07 PM
Pro Street's Avatar
Would you expect the same for a non SC TL?
Old Aug 4, 2006 | 05:21 PM
Atrain's Avatar
Smile Not exactly...
First of all, the hotter the air, the less density, this is true. So the less oxygen present and the less spark available.
Any supercharged car with or without an intercooler will create tons of hot discharge air. Thermodynamics law...compress air is heated. So if the ambient temp is 100 degrees F. and you are running 5-psi of boost with your Eaton M62 blower (no intercooler also) then you can bet that the ACT's entering the cylinder heads are around 200-220 degrees F.
Spin the Eaton M62 faster for more boost and you'll lower it's efficiency and guess what...make more heat.
So will you make less power from less air flow? Not exactly. Air is a limiting factor in power production. What determines power output of any gasoline engine is how efficiently it burns fuel. If the air is denser (cooler) you can pack more oxygen in the same area as before (if were hot). Then you can add fuel to create the proper A/F ratio and poof...more power.
Also as the heat rises, so does the cylinder pressures and the higher the cylinder pressure, the less spark available to ignite the combustion mixture.
Generally, you'll see more boost pressure on your gage in the winter then in the summer just for the cool dense air. What you guys need to do is mount a sensor after the supercharger outlet so you can monitor the air charge temperatures. Then have a good tuner modify the factory program to pull timing as the ACT's climb.
I did this with my Eaton supercharged 4.6L T-Bird. I used an ACT sensor after the supercharger and intercooler to monitor the ACT's. Then the tune was set to pull timing as the ACT's reached a critical temp.
A-Train
Old Aug 4, 2006 | 06:50 PM
BustedJack's Avatar
The Boss
This is a "Supercharged TL" discuss
OculiAquilae
Nov 19, 2018 02:24 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
kuzdu
Sep 10, 2015 08:42 PM
simplyjayyy
2G TSX Performance Parts & Modifications
Sep 2, 2015 12:57 PM
