Stroke to 3.7?
J36Twingt28r's,nextgt30r
the only problem with the 3.7 build, cause i talked to him extensively about this, is that the 3.7 is strickly for N/A application only. the only way to us F/I for the 3.7 is to resleeve the block. the J36 however will give u basically the same power, it is like a 5-10 hp/torque difference and u can run safely 10lbs of boost on a j36. paul is the man to talk to.
AM To WDP In My Garage
with just the heads the gains aren't huge but they are noticeable, you have stiffer springs, tl's cams (suppose to be 2lbs lighter then the base 3.2 cams), and i think the valves might be a couple MM's bigger (Not positive though) but its definately worth it to me and im actually in the process of buying some type s heads to build that motor you gave me!!
mlody
12-04-2019 02:11 PM
09-17-2015 09:01 PM
