StopTech Brakes
Old Apr 17, 2014 | 08:46 PM
motor_moose's Avatar
StopTech Brakes
I bought the BrakeMotive kit last year. And I can tell you first hand there is a reason why they are the price at what they are. Anyways I am college student and the spring semester is whining down. And I am just trying to get idea for a new brakes for my 05 Acura TL. I like the look of the Drill and/or Slotted rotters but isn't necessary. I am looking at the StopTech kit threw XLR8, but haven't had much luck on finding a lot of reviews. From what I can tell some people rave about the AutoZone C-Max and others like BrakeMotive. I understand AutoZone gives lifetime warranty, but I am not to worried about warranty if the brake pads will last a couple years... Just a little back ground I don't race or think the TL is a race car. Just my DD. So I just want some people opinions on the StopTech compared to any other brand.
Old Apr 17, 2014 | 08:49 PM
*Through* Sorry that bother me after rereading what I posted.
Old Apr 17, 2014 | 08:56 PM
Slpr04UA6's Avatar
-------Tim-------
Check out this link. Don't know if you have an Auto TL or not, but check my post #15.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/brakes-budget-906219/
Also, you can edit your original post up to 15min (I believe).
Old Apr 17, 2014 | 09:18 PM
https://acurazine.com/forums/showthread.php?t=906219
I did just finish reading through that post before making this post. But I didn't notice much comments about the StopTech. Price isn't such a problem for me as long as it is good quality. I hate to under pay and get another BrakeMotive deal.
Old Apr 17, 2014 | 09:21 PM
Slpr04UA6's Avatar
-------Tim-------
Centric makes Stoptech.
This is the only small issue I have with the brake pads causing a slight imprint in the rotor after washing. Vibration I have had goes away mostly after another break in procedure or repeated stops.
https://acurazine.com/forums/3g-tl-problems-fixes-114/stoptech-street-brembo-pad-imprint-after-washing-%5Bpic%5D-894180/
Old Apr 17, 2014 | 11:21 PM
csmeance's Avatar
Racingbrake rotors, PERIOD.
I have 190K on the TL right now and I've had the same rotors on since at least 100K miles. I put them on around 50K or 60K miles if I remember correctly. I've used only factory pads (mix or aspec and regular) and the stopping power is pretty incredible to me. I've done numerous stops from 120 to 40 with them on local strips and they have done amazingly well with very little fade and a ton of bite. Pads make a huge difference! If you put a hard pad on a soft rotor it'll eat through it and vice versa. I've found Acura OEM pads & The A-Spec pads to be very gentle on the Racing Brake rotors. I did have the rear rotors refinished (took off very little and well within service limit) at 170K with the 3rd set of rear pads on these rear rotors. However I've been through only 1 set of front pads! I'll get to this later!
2 piece rotors are more expensive and the only benefit is cheaper replacements for the wearable part over time and the reduction of spinning weight. The latter helps improve performance slightly and I highly doubt you'll notice it in everyday driving. Maybe in 1-5% of the sporty driving you will ever do, probably like 50% of the driving you'd do in a rental car
Slotted front rotors are a good decision in my opinion. Slotting help improves the bite and helps keep the pad and rotor clean. On the rears you'll be eating through pads every 20-100K depending on how you drive. I wouldn't recommend it and I'd go with racing brake solid or drilled blanks to match the fronts (no slots on rear).
Drilling is more for aesthetics, weight reduction and and as well to help vent the disk a bit better. Cheaper rotors have the holes drilled in and not cast into the blank! This creates weak spots; the holes need to be cast and then finished via a drill and then balanced! This ensures rotor strength and ensures you won't get vibrations! If you want to add the drilled holes option then you will have really no noticeable difference in braking in everyday driving in my opinion. You'll notice their benefit in maybe 1-5% of your driving and they won't chew through your pads like slots. However you'll be prone to more brake fade as the holes reduce mass, allowing the rotor to heat up faster. This only matters under severe conditions such as racing but sometimes all of us can push the limits of what things were designed for.
I'd talk to Mr. Heeltoe or Excelerate on here and look into their brake packages as well. I put the heeltoe ones on my TL.
Old Apr 18, 2014 | 10:36 AM
NvrDwn's Avatar
Don't ever buy drilled rotors.. Even very expensive brake rotors Crack, porsche comes to mind. If you want something aesthetic go Slotted, but they don't provide any performance boost over a good set of blanks.
Old Apr 21, 2014 | 06:32 PM
Excelerate's Avatar
Former Sponsor
We've got hundreds of our XLR8 STOPTECH Acurazine Brake Packages on AZ members' vehicles. We've had hundreds of positive reviews on them. STOPTECH makes a great product. It is very durable and performs well. We stand by their product because it's a great product at a very reasonable price. You do get you what you pay for.
Old Apr 22, 2014 | 04:23 PM
I have look threw your Acurazine Brake Pakages and they seem like a good deal. So I probably will be messaging you in about month so I can get rid of these noise brakes I have.
Old Apr 24, 2014 | 06:36 PM
Excelerate's Avatar
Former Sponsor
Sounds good. Feel free to contact us with any questions.
Old Apr 25, 2014 | 06:08 AM
MrG22's Avatar
I'll vouch for this. I have the the xlr8 blank rotors and pads front and rear. I had my cousin pick them up for me from the shop along with some brake fluid and haven't had a single issue since putting them on in October. Grabs and stops just as good as OEM.
Old Apr 25, 2014 | 07:59 PM
TLhotrod's Avatar
4th Gear
I put Powerstop drilled/slotted rotors with ceramic pads on all 4 wheels for $285 from Autoanything (free shipping) and they are excellent. The rotors are still bright silver in appearance. Highly recommended.
http://www.autoanything.com/brakes/61A5870A0A0.aspx
Old Jan 30, 2017 | 12:47 PM
Perdomes's Avatar
Power Stop Z23 Brake Kit - Rotors & Pads - FREE SHIPPING!
I know you posted this a while ago, but how have they been treating you? Did you get different brakes by now?
Old Feb 6, 2017 | 01:13 PM
ExcelerateRep's Avatar
Former Sponsor
Anyone else who's looking to go the StopTech route feel free to check them out online below: StopTech kits pass a demanding series of tests that range from performance and durability, to proper fitment and ease of installation; all making for a true quality brake kit.
PM me for quotes!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
