ROTORA Rear Big Brake Kit
Hey guys ROTORA is about to release their rear Big Brake Kits for the Acura CL and TL and to start it off right I wanted to offer some special pricing. Firstly, the rear Big Brake Kits will consist of a 2-piece 13" rotor (choice of slotted only or cross drilled and slotted) with a 2-piston caliper (choice of red or sky blue metallic), stainless steel brake lines, and street/sport pads. The e-brake is still functional. List on these kits is $1695. I will be selling this first wave at $1400 shipped. If you are interested PM me. And of course if you need a front BBK PM me too.
tehLEGOman
Received 1,982 Likes
Josh Thanks for the heads up on the release for the rears...
It was good to meet you in person at SEMA IAS in April.
Oderint dum metuant.
Are the rear BBK available with 4 piston calipers or just 2? Also i know u said they were 13inch rotors, i have the front BBK i cant remember the size but is the rear the same size as the front? thanks
Travis
Travis
Travis
Travis
Originally Posted by Excelerate
Yes you can get a rear BBK with a 4-piston caliper. It's another $300. More than likely you have a 13" rotor in the front. ROTORA does offer a front BBK with a 14" rotor but more than likely you have the 330mm disc, not the 355mm.
yea i think i have the 330 in front...i think im gonna get the rear bbk but inorder to upgrade to the 355 rotors in the front can i just swap the rotors ur would i need to chhange the entire setup? thanks
Travis
Travis
Travis
I don't think that this would be possible. I assume the calipers are the same but the bracket would be different b/c the larger rotor would need the caliper relocated further away than it is now. Also, since the caliper is further away now then the SS lines would need to be longer. Again I have not confirmed this with ROTORA but this would be my assertion. If you want to get the rear BBK PM me so we can work out payment and I can get you on my stocking order coming in from ROTORA in the next 2-3 weeks.
Originally Posted by MichaelBenz
Yep....both front and rear matching set... 4 piston calipers and 2 peice rotors. Cant wait to get em on when they get here!!
What sucks i have to get rid of my exhistingbrembos im not feeling that at all. i wouls need 6 pistons for the front if im going to give up the 4pistons in the front. it's an easy upgrade if you do not have the brembos. i hoping some one makes a rotor for that set up. what color did you order?
How may I help you.....?
CTS-V Import Slayer
Received 3,763 Likes
dang so when is rotora gonna release a rear kit for the tsx cause then I will probably finally get my brakes.
If you already have the front Brembo 4 piston brakes as I do, do you think it makes more sence to get the 2 piston rotora kit for the rear instead of the 4 piston since it wouldn't match?
i dont think you are going to see much of a difference between 2/4 piston rear caliper w/ your brembo fronts. remember braking is biased to the front, so balancing it with an equal 4-piston WILL improve breaking, but noticeably better than the 2 pistoN? i dont think so.
CTS-V Import Slayer
The difference between the 2 and 4 piston too won't be huge but the difference will be there. You will have more of a caliper and more pistons and better response b/c now you have 4 smaller pistons putting equal pressure on the pad whereas you only had 2 before. Again, the difference won't be monumental but it will be there.
Noob question... how does upgrading the front bbk on a AT TL affect normal and emergency braking?
Having a bbk does the car know how much braking force is needed in the front as opposed to the rears? .... compared to when it was stock?
The brake master cylinder along with the proportioning valve control the amount of pressure exerted by the brakes in the front and rear. The front BBK is set up in accordance to the stock master cylinder. The kits are "balanced" so that the rears do not lock up although if you exert enough pedal pressure the rears will, with any kit, lock up.
The Boss
nanos
11-12-2015 08:41 PM
nuldabz
09-03-2015 05:49 PM
