Resetting ECU?
Old May 1, 2008 | 08:56 PM
pwrdbykmfdm's Avatar
Resetting ECU?
i just want to clarify that resetting the ecu on a 08 tl is the same as most other cars- unplug the negative battery terminal on a cold engine for 10 min, plug it back in and let the car idle until the fan turns on, then shut it off.
ill be installing a CAI soon and will need to reset the ecu afterwards...or will i? have you all reset your ecu after engine mods?
Old May 1, 2008 | 09:10 PM
anx1300c's Avatar
No need to reset after CAI install.
Old May 2, 2008 | 04:45 PM
Bearcat94's Avatar
AZ Community Team
If you disconnect your battery cable, you'll have to enter Radio and Navi codes.
Make sure you have the Radio and Navi codes BEFORE you disconnect the battery.
Old May 3, 2008 | 07:06 PM
u sure because ill be getting more air so ill be needing my engine to increase fuel mixure. or is the stock amount of fuel fine or does it adjust automatically on the 08 tl?
Old May 3, 2008 | 07:24 PM
TylerT's Avatar
Turd Polisher
If you have the NAVI codes, resetting your ECU never hurts.
Old May 4, 2008 | 04:18 PM
1meand's Avatar
On another thread it was said, and I did it last time I needed to reset the ECU, to pull fuse number 8 and 19. That way you won't have to enter any codes for the radio or the nav. The fuses are located under the hood, in the corner closest to the driver. Flip over the cover to see the exact location of the fuse and there is a tool to remove the fuses in there too. It's also on page 329 of the owners manual.
Old May 6, 2008 | 04:48 PM
THTL's Avatar
pulling fuse number 8 and 19 are the same as unplugging the negative cable on the battery?
Old May 6, 2008 | 06:08 PM
1meand's Avatar
That's what someone else said to do to reset the ecu and it made sense to me. You are interupting the circuit by pulling the fuse, the same as cutting power to the circuit. Unless my thinking is way off, which has been known to happen sometimes.
I couldn't tell a difference between unhooking the battery and pulling the fuses, as far as the way the car acted after I did it.
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
