Removal of Bank 1 catalytic converter heat shield
Old Sep 15, 2015 | 04:05 AM
WDPanda's Avatar
What's the easiest way to do this?
It is rattling -_-'
Old Sep 15, 2015 | 07:01 AM
<p>I find that we scare ourselves into big tasks.</p><p>once you get started, it's simple. but you have to start somewhere.</p><p>I suggest taking out the things that are obviously in the way. coolant reservoir, fans, etc,</p><p>&nbsp;</p><p>&nbsp;</p><p>once things are out of the way, your main job will be a lot less scarier. IMHO&nbsp;</p>
Old Sep 16, 2015 | 09:02 AM
WDPanda's Avatar
That would be the cat on bank 2. The one I'm dealing with is Bank 1 which is wedged between the firewall. 1 bolt is visible to the shield from underneath next to the j-pipe. I can get my hands on the cat from the top through the strut bar. Is there any engine mount removal technique before I sit there trying to do the impossible? Can they be cut off? I just need to remove it whether it comes out in pieces or not. It's in a tight spot.
Old Sep 16, 2015 | 10:06 AM
<p>
Originally Posted by WDPanda
&nbsp;Can they be cut off? I just need to remove it whether it comes out in pieces or not. It's in a tight spot.
</p><p>&nbsp;</p><p>I feel like you sort of answered your own question there bud.. &nbsp;If you don't care if it comes out in pieces or not.. why not just get a dremel in there and go to town!?</p>
Old Sep 28, 2015 | 07:39 PM
WDPanda's Avatar
Spoke to a couple of shops and they all recommended leaving the heat shield on. It is located in a tight spot close to the firewall. Took a 6 inch diameter hose clamp and wrapped it around. No more noise.
The heat shield can also be removed but there is no room for a dremmel or any other cutting tool, not sure how that would work. The top 2 nuts can be accessed after removing the strut bar. The bottom has one that is easily visible and the other in a tricky spot. Worst case that could be drilled out, no dremmel would fit without making a mess of things.
Old Sep 27, 2017 | 08:44 AM
wusty23jd's Avatar
I think I am having the same issue WDPanda. Would you be able to post a picture of what your heat shield looks like with the clamp on it? This sounds like too easy of a fix lol. I want to make sure I'm looking at the same thing.
Old Sep 28, 2017 | 11:54 PM
thisaznboi88's Avatar
You could always do a wire tie to keep it from rattling
Old Oct 4, 2017 | 05:43 PM
WDPanda's Avatar
I sold that car since posting. Its a simple 6 inch or two 3 inch hose clamps to hold it agaisnt each other. An air ratchet will make your life easy.
cycdaniel
Dec 17, 2019 10:58 AM
Aug 15, 2019 12:58 PM
01CLOwner
Oct 9, 2015 01:07 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
jpm3071
NY/NJ
Sep 7, 2015 08:25 AM
