Rear mount turbo - Type S
Old 01-23-2015, 07:37 PM
  #201
DomGSR-T's Avatar
Originally Posted by RD_04TL
If it's a known fact that the ring land is a weak spot what can be done as a preventative measure to avoid this kind of catastrophic failtures?
Tuning is all that is needed to avoid failures
Old 01-23-2015, 07:54 PM
  #202
RD_04TL's Avatar
I agree that tuning is a most for anyone making serious mods, but IMO for a daily driver project there are way too many variables to rely only in the tune.
Old 01-23-2015, 08:50 PM
  #203
DomGSR-T's Avatar
True! and with cheap quality gas available in north America people are playing with fire on high compression engine relying on watermeth to compensate fully which is dangerous. I rather have a 400whp engine that last 5 years+ then a 450 whp for 2-3 months...
Old 01-24-2015, 05:25 AM
  #204
screaminz28's Avatar
One hypothesis on the board here is that it's not that the ring land is too weak, but rather that the end gap is too small and that the rings expand, closing the gap completely and then breaking the ring land.
I don't know if I would disassemble a motor to change the ring end gap alone, but I would DEFINITELY do it if I were already in the motor.
yungone501 (01-24-2015)
Old 01-24-2015, 06:26 AM
  #205
KN_TL's Avatar
End gap was the reason for my ringland failure. One ring was seized in the groove and the ends were together.
Old 01-24-2015, 11:13 AM
  #206
J-series addict
yungone501's Avatar
Piston failure that was caused by ring gap clearances is easy to detect by looking for shiny surfaces where the ends butt. Also, the cylinder walls will typically be scuffed all the way to the height of where the top ring rests at TDC. In my experience, this occurs with almost all j-series ran under boost or spray and running stock ring gap clearances. Most people assume the ring lands crack due to the pistons weakness but truth is stock bottom ends can handle absurd amounts of power. Though it's not necessary for the rings to be gapped more, it does make it more forgiving under higher temps brought on by detonation. So yes, it's almost ALL in the tune.
DomGSR-T (01-24-2015)
Old 01-24-2015, 01:26 PM
  #207
KN_TL's Avatar
[QUOTE=yungone501;15310844 So yes, it's almost ALL in the tune.[/QUOTE]
How much does your tune vary with temperature and humidity variances?
Old 01-24-2015, 02:20 PM
  #208
RD_04TL's Avatar
I agree that tuning is one of the most important mods you can get (if not the most important) but to rely only on the tune on a daily driver you would have to get a mild tune to stay on the safe side. When I'm spending the money on tuning my car I like to make sure I have the supporting mods to safeguard my engine and get the best out of it. I'm not relying on this mods but they are there in the case something unexpectedly change
Old 01-24-2015, 04:08 PM
  #209
Since we don't have pics in maddog's instance, we can only assume that the ring ends did not touch, or the walls would most likely be scuffed. If they are just dropping in new pistons, that must not be the case.
Robert, you state that it's not necessary for the rings to be gapped more, if you were building a motor for someone with all stock components, would you leave the gap at stock levels and leave it to the tune, or would you increase the gap to allow for more forgiveness? I guess my thinking was, don't do it n an assembled motor, but while you're in there...
Old 01-24-2015, 04:17 PM
  #210
J-series addict
yungone501's Avatar
IMO, anyone running beyond a "mild" tune on their dd would be asking for problems. Going to the edge of detonation is just simply not acceptable for anything other than a race purposed vehicle. With so many ever-changing variables that will affect the tune itself, you shouldn't be willing to sacrifice your engines safety/reliability on gaining an additional 20hp. Instead, you sacrifice that bit of power for safety.
Fail safes are good for unexpected failures or issues and I support the use of them 100%. However, they are just that: safety in the case of failure. They should never be used as a primary means of controlling or manipulating tables in the ECM (as you've mentioned). An example would be using a knock detection system such as a Vampire to ride the edge of detonation by observing knock on cylinder(s) and then making necessary timing adjustments. This approach can seem VERY alluring to someone looking to achieve maximum engine power. But if this "fail safe" fails, then guess what happens? People that become too greedy with power eventually learn things the hard way...just as I did.
I basically take the same approach as I explained to RD_04TL above but will make necessary adjustments after major seasonal changes. Also, I try and tune on the absolute driest day possible when doing these seasonal adjustments because moisture in the air takes up space in the air/fuel mixture. This will typically create a great safety margin for days with greater humidity levels as the space it takes up is in place of air which creates a richening affect.
Old 01-24-2015, 04:32 PM
  #211
J-series addict
yungone501's Avatar
If you're already in the motor to a point that enabled re-gapping the rings easily, definitely so. Also wouldn't be a bad idea to do if you know the budget for the car will be too low for proper fuel systems, running fail safes, using a experienced tuner, etc...
Old 01-25-2015, 07:35 AM
  #212
6spd-GERCO's Avatar
I know the tune and failed ringlands have been talked about but I think something was up prior to the turbo install. The dyno numbers where on the low side from the baseline. Didn't seem like the motor was 100% healthy.
Old 01-25-2015, 01:21 PM
  #213
vietxquangstah's Avatar
What makes you say that the numbers were on the low side? 220-230 WHP sounds about right for a automatic TL-S. The auto TL-S makes about the same WHP as a 6-spd base model 3.2L.
A 6 speed TL-S puts down 240-250ish WHP.
Old 01-25-2015, 04:03 PM
  #214
6spd-GERCO's Avatar
An auto TL-S with PCD's should put down over 223 whp. I put down 230 whp everything stock minus a catback, 04 6MT. It seems low to me.
Old 01-25-2015, 09:26 PM
  #215
I put down 230whp with pcds, rv6 j-pipe, atlp quads, cai, flashpro tuned.
automatic base model
I wish I made 230 stock
Old 02-05-2015, 05:04 PM
  #216
maddogtheta's Avatar
Update
Well, I had the replacement stock pistons installed with the water/meth system. It was on the dyno getting re-tuned for the water/meth, it was on its last run on the dyno and another piston cracked
I'm ready for the I told you so's. Anyways SpeedFactory is getting some Arias custom pistons ordered. I am paying for them to get expedited so they should be done in a couple of weeks instead of 4. I'm also looking into some stronger rods now while the pistons are pulled again...
Oh well, I always planned on building the engine at some point, I just didn't think it would be so soon.
On the bright side, before the piston cracked again, the TL was making 393whp and 370 torque.
Old 02-05-2015, 06:00 PM
  #217
3.5 psi
gnuts's Avatar
That sucks. Are you paying for all this labor?
Old 02-05-2015, 07:14 PM
  #218
thisaznboi88's Avatar
damn that sucks...
See there a reason why we said to with forge aftermarket. Maybe they are tuning the car way to aggressively.?
Old 02-05-2015, 07:30 PM
  #219
UTAH TSX's Avatar
Piss thats all I can say, sorry to hear this
Old 02-05-2015, 08:47 PM
  #220
Was it being tuned WITH the meth, or without, and preparing to add it?
Either way, sorry to hear man.
Old 02-05-2015, 09:09 PM
  #221
The water/meth injector was installed and running.
Thanks for the sympathy. It's definitely annoying, but I was mentally prepared for this eventuality, after all I am putting more stress on engine components that weren't made for it.
Honestly the worst thing is not being able to drive the car. I miss the turbo goodness so much...
On the plus side I'm going to have forged pistons, water/meth injection and possibly aftermarket rods so I'm going to turn up the boost a little bit
Old 02-05-2015, 09:17 PM
  #222
UTAH TSX's Avatar
This me talking to Vit (our tuner) he says nodata:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxQTEhUUEhQWFhUXFxcYGBgYGBcYGBgYGRcXFxUVGh caHCggGBolHBQXITEhJSkrLi4uFx8zODMsNygtLiwBCgoKDg0O GxAQGywcHx8tLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLC wsKywsLCwsLDc3LCw3LDc3LCw3LP/AABEIAOEA4QMBIgACEQEDEQH/xAAcAAACAgMBAQAAAAAAAAAAAAAEBQMGAAIHAQj/xABPEAABAwIEAgYGBAkICQUBAAABAgMRAAQFEiExQVEGEyJhcY EHFDKRobEjwdHwFTNCUmJykrPhJTVzdKKyw/EWNkNTVGOCk9Nkg4W00ib/xAAaAQACAwEBAAAAAAAAAAAAAAACAwEEBQAG/8QAJBEAAgMAAgICAwEBAQAAAAAAAAECAxESIQQxE0EUIlEFMnH/2gAMAwEAAhEDEQA/AK46qoC7UilTQF1WXCPIBsOXASVKMACabWfRC/dQHG7VWQgEZ1obUQRPsKMjzilfReHL6zbXqlVw3IOxiVD4pFdl 6YYo4zd4ahC8iHrhSXAI7SQ2SAZ4SatVUJLWco6cauG1MqWh9C mloGZSVDXLvmBBhQ03Bpuno1fKAUmzeIIBH4rUHb/aVY/TgygqsSmCpbi2NI9lwt789RPvrpirhLa2mTusKCfBtIn5ij+CB PE4Ayw6t3qEMrU9mWktjJmBR7YMqjTxqRmxfau0MLt3Q8sZkN/R5lJ7UqBz5YGU8attixk6SrTrqtbg8HLZok/tZvdV06Q4Nmv7C6A1bW42r9VbSyD+0kD/AKqj8eAcXx7RQutKFllxlbTgSlWVzLOVRUArsqI3Qr3UN6q862 Xm7Z9TYCiFjq4ISSFHVwGOyeFOem7YOKOTwtbb95c089GwzYe6 2dSh66R5KUVpH7Lgpaog5OJZ+aaSkiiYVaPXDYdt7Z51tROVae rgwYMZlg7g8Kjwlpy5CyxbvOBCsiynqxlWBJQcyxqJ4TXTfRja dVhdokjXqgT4qJP10N6N7PqWbsxGa+vFH/pdKQfcmi/Dq/hP5lhz7DrK4eCizavrCFrbUR1Wi0GFp1cGxobG8KdSEh+3caK8 2UryalIkgZVE7V0D0OO57N5Z/Lu7hX7S5+uqdi+KXVy6hF3Kerce6odQtud0D6QmF9mDpzoJ+PX XFtIlXTtfFlUw7o9d3Gc29u44EKyqKSjQwDHaUOBFNkdEcQG9k 972v/JVl6M3L9q6gNrT1VxcNBxJRKpUEtnKvNpokcDVp9IuPXFom2Fu pAU64tKitGcQGyoQJGsimw4zgmVrK8lhyW2wG7dZD7dq6popKg uW4yiZOq54Go2Oj92pgXCbZwslHWBctxkic0Z527q670HEYE3/AFd3/ErTBB//ADrf9R/wzTFVFehfE5NhvRq8uGkus2ri21iUqBbgjaYKweFRYxg9zbAG5 t3WkkgBSgkpk7AqSSAfGuv+jdahgluUe0GVlMCde1l0461Djjr jvR5xV2IeVaZlgjKQ7Ep7PBWYJ051PxxOw5F+Aro25uk27ht8h c6wZIyCZXGaYgE7VjOCXCrY3QYWbcJUouAojKiQpUZs0CDwrt3 o3YC8GtUK1SpjKodxzA/A0lGGG36O3TBGrTN4jXklboSfMQa5wRGHJre2UpaENoK1rVlQk RJUQSAJIGwNMLzo5doU22u1cSt0lLaSW+0UpKlAQuNAONb9Ez/KNj/WE/u110P0xYi5brw95kpDiHXiCpOYfio1EidDzoI1xa7OSOenoPiH Cyd97X/kpRiuGu27nV3DSmnMoXlVlnKSpIV2SRuhQ8q+gOjGMOv4Y3cry 9aplSzAhMjNHZnbQaTXAMYx16+cTcXBQVlpCOwnIAkFSxpJky4 dfCpcIpHNIDCRWZRyrbLyr0IpeIhGsjlWVvkrKjCRk4+AKVrcJ qBrMTrTBlscaKFSiEohvQwfyjZE/wDEJ/uqrp/paw4XL2GsFQT1r7ic2XNllveJE1ycvltaHGzC21pWk8MySCJ7j EeBrpTXpSsnQ0u6tXOuaOZMJS4EriCpC5EeYpyZLWCe/wDR6LO9w0B7retukyC2EwGodMdo75YrqGJYc6u8tn0qT1bIeC0 mcxLgSBHDTL8a5Tc+kEv4jb3S7dfUWwdDbYKC4VOJCS4okhIOk QDoOOtT436QVO31ncNtXCGWOs61orQC7nEJ7KV5VRH5Vdyj/QdLPidpl6SWjnBy1c96JHyUKuNriQXdPsGMzSWlgfouBUH9pCq 5lfdP23by1uU2r46hLyVAlrMoOBIEQuN0zrFRo6XrTii78MOdU thLKmSpvrJScyV+1lgHTfiaF2Q/oahJ+hv0uj8KOTubW2j/ALlzNM/RgYN62Dp16HI/XZbB+LdU7FcdN1dLuUNLbBZabCVlMyhTpJ7JIiHB7qO6N9IFWb 7yyw46l1DYGQoBCkFcznUOChtVSN0V5D7+i1KiXxrovK7j1VeH WoOjhcb/AGLdxfzSPfRN6n1a0ulk6AXL0/rZ3PrrnfSTpG5c3VncIYdbTaqKyhSm5cKikEApUQIRn3jemfSH pqbq2etkWj6FOoLedRZygK0UTCydieFWnfX/AFCVRZvoO9C7WWwUjk8sHxyomq1ddIXL55AdXbp6lx4JQgnrD2 lN9oFR4JnQUx6MdIlWKHWjavO5nluBTamssKiBClgzpXmOYwLk slNmtjq3esUtXU9odW4iBkUSTKxVe62EqmlL6HVVSjZriQbP2q edywf7dPPSm3K7Af8AOc/cqqpl5QeacCSvqnkLyiASlKpIEmJimHS/HlXimB6u6x1K1qJcU2ZlsoEZFk/lUrxLIqnGxl9cpW7hZ+hf8yIH/Ie+blRYMqOjrf8AUP8ACNVnop0u9UbVavNKdYleRSMpKQslSm1 IJEplRgg8YiisZ6Sh+29Ts7dTLCkBtS1wkIa2UhCASSSBGsATx q4roKO6VXTPlmD/ANGzhTgluobpYWR4jMRS7HD69gAuXx9KLf1jskhPWI7XszBBKd jzpbhPTAW1n6obV5RCXEBaVNZO0V5TqsGIUOFCWXSJX4I/B/qrpX6spjrMzXV5ikjN7c5deVT80M9kfDPfRauiWK+r4DbvmIQ0 gnlBdhXwJpv6QCPwXfRt6s8f7BrnDuNKTg34NLDmfqeq62W+rn NOb2s0R3VNc9OS7hqrJbDqnVW5YU6C3kKsmQOe3mg7nSu+aH9I +Gf8Kr0SH8o2J/8AUI/uLq9+nOctlH+8d/diqtaOdS9bvBBV1LqXClOUKICVAgZiB+VTXph0kF8WIYca6ouE 9YWzOZISIyKOtJhfFw3Rj8aSeYXToL/MbP8AVl/JdcCsUfRo/UT/AHRXU8D6bC3sU2htXlKS2pvMktZSVZoIlYMdrlVLt7QJbQkgSE pB8gB9VRdfFR6Ij40pdPoTVIlVMnLMcqXusHhSoXJgS8eSPMwr KhyGsp3JC/hme2iKJeUANDQBuQKjLxVTw9wkdcJrGWzvXjYo231pcpYLlPTL NyJopxU1GG6nZYJNVZyR1dbnLAmyVlk91MraxkgqMihmGQBIo5 h3lWfbLX0bdVaisGDbKdhpU6Rzpb1+og/51Mpef2dFcR9lVHFss6MEtiQdINTG3A47E0ttVmCDuNR4ijUnj rsCfv4g0LT1LTtNswkePdWl+/skRNOOg3Ry0fs1OvWzLjhduO2ttKldl1YTqRwAFQdC+jVo7hKH nLZhbhbeJWppBXKVuBJzETIge6tiH+ZHE+RQl/oPcwX4eAcyyBpSe+uu0TvMj7+6rB6Iej1rc4W07cWzLrhW7K3G 0qUQFkAEkcBW+I4JYXWGuXlnbi3W2l0oKUhtWZlSkqCkoOVSSU nfgRtRL/MUdafYK87X2iuWlsVyAOIpndANJgbnlRlgylCQeYk+Ypa8C4s9 507hWPKxuX/hoe0D2drnVR7iQNB4UUloJTAoN+g+RyZPEEuRINKRa5VaU4f2m g24KqdGTSBlHTOp0rUpox1MDXyoIr5fGpi9J1I0IqJ0CpVNqiZ j6+4UC4yZjN41ahU5FadqR5cERS513wox5iageYjarkPHKsrQX N4Vle9XWVY+ED5QZ+1TXttbcqkuHAo0ws0jLQSscUUWD+ritUt xsKOUkViECeNIdvQVdTkyBtsnb40yt7cqA4GYNaZdoq14FYCJP 8ao234a1VPBCZNqRIiKgLZB1keVXm6sUqAygTNKrvAl7j391VV cPTEQQlQ7Kh56ViULChpB+ryo1eEHh9zQqWltq4wN6bzi10SmG 2jUnvpkxrpA00921eWIC0EjUkedRWzkSlR1qqm3NaFvRa/Rt/N5/pbr98uoPR//ADI3/RXH992ofR1ibaW3bNagl1LrqglUArQ6srQtP53tQY2IqW5UjC8 K6hbgUsNuobAgKccWVlISmZ3XXr4NOKaMKcXyaBfQef5GZ/Xe/eKoTEcasmMPds7FZeUtLqEpTmUQp1SitS1xCUgqMnugUZ6JFts 4YhtS0JKXXwQVAH8arnSTBgDbtieB8PaVVXzPK+CHL2P8aj5JY/o2aZUtI93u0rZq3De51NSXV2EDKjf5UIJ3USa8vrk239m3mdEi 3ZqBaaJacAMZcy+PJPdPOtXggak5jxjb30xRw7kLXu/2aFUROggUxcIOwqD1emp9HNaYlyaJw+wzGVa+RigX+zBFNsNup A4CCfHuqOxc0Gu2AIjKn5CkF8yASEgA8gPrNWe2Wk+1JPHlUrq AT2QPd9dWafI49FGyts584wv8w+6gHknYyKveIW+hkE+Z+GtVj EG0xoNRuCfdWpXdyRVlDBF1J51lEf8AT8aymfKB0JnUa0wslQI rxtIJ1qRtvtUmyWrsrxjrwZMNSNBPOsVbHfamWHoATrGtb3SE1 mSm9NiipKJBYKSCCedPUYiE7RFVlVqtsdYgEp4gcO+gF42E6kH uofgdr6GysUfZevwrl1VoPdRln0rZJCVLGugmuM4tjDriiCSNY jXTuoAL4ST57Vcq/wAvVrKk/Jj9H0YlLTmoIqM4R51wC36QP264Q4qBpBMifCuhdFunynYQowr 4GkX+BKvsmvyN6L83hISZSADQOL4QN06L3ra1xUkanWaIeWSBO sc+H21muSRajy0qmJWSHWx1qEqKT+UJ+dRt4a0ynM002lUbhIB 176aXqp0jTj40JdkdlI7p8qZHyJ5mssRhH2Q2mEsKla2myqd1J BPxooEyEt6cNNhUjpypCUiVGNeA7qJsrfLolJWrjGm/jQTslL29C/WPZq3YhOp3+FauJzbA6bd/2Uc7ZvEQQEj30M4+hHZB140jZaBy30LHkE9lPZHHgPFRqMFEar J8BE++p7zkghRPAET/ABpS4lQMEEHvEVdgtR29h5UAdCfvwreNKWIXBrdT8+XCp4haEv NFWg24ngPE0qTcFKoGoFT3NxIiYpHcvEK3Mb91WKoJrBNsuJcc OxCUmOHOjkYnCZJPlVHtMRgxrP1Uy9bzAgcuNDLx/wBhXMZYhjKToQYMwefdVPxW8JiPZM/5URmUJG4knwPOl9yiQJ4VfprSKF0ugXrTWVnV1lWCnyZO1R9kK FQRtR1onT+NKtfQ3x1skM0PEV6pRNQJUOdTNprNaNuPQ6wR2Tl O3GvbPAmTdLdKQUsNKXl4Z9kHygmosHBziOHCm2Guy9cNmJUwP mqfPUV1EmplbyV0c7w3o63c2lzeuPQsKJCZG/3FVBG9RXNwtlTjJmAsyJIG/EVPa3Y3CeHur01a6MpmXzCYBgySB41Dhyy2vTQjXx762uzMSY1 Bodt0Z0x4VFqTi0TBtSR2rDng4G1fnAH4U+xG6GUDiRp5b1Vui erTQ2j5c6Z3bkrOWTB0rx10UrGjdq7ijcKJ03BE+EcKgQJVMc4 rYKiYNbqRCUkHx8qjMHLolt0ysTVkw9AEKHuA38aqvXkQQNRsf rppa4mUpGcEUCTT0RY96LW60Fild5giOCRJpZ/pEngfhRtt0obVor/Pwp/UvaEZOHoUP4EnkfdQLmGqTOUyOR1+Bq7NYi0vYj5VKq0bVrAqV GS9ML5mvaOYutKBMZU89ffoah6vSa6HeYAk9pPymlT2C6RJPwj 31PJr2NjbFlKeRz0pFeswdZjhrVxxawCJ7Lh8Ck1Vr8J27XmPq q74z19AXNNAbagDRzK9ZpfprBnyP216l2rUo9lXl0HrOv1UqcW SdKPdfEUA2oDemQRTuf0aweVZUvWjnXlM7EGnVaj66d4c3InTv oDqs1MLFsDl4g1WvlsSx4vtBZt/vM1u2xyqRsQaKbcnas6TNpGYcvKsT9lT9IXRa3LFwBCSMi4k9l W5moH06inXqgu7csq3jRXhy76GqxRmJ8iHKPRzf0idHCpZumO0 leqo1jTRXgYqgEEcxXT1uv2Ci28kqb4A8u6fHakl9ZsOkqbV1Z O44e41v0X9YzJlApa3SdzNFWKBIJ3mmN3hCphCgrwH2UXgvR10 uJKhxptt0FF9hV1yckdK6PQm3Sr9GBz1olpQ176HCQlISnh869 SqJkV5ea2em7XDIm53op3UTECNPKltquSSan9YUBqTlqHEls0e XrHu+2lTuIqU5lB01+FTXLxAK+QPw4VV/X8oUv8AK2T4nuq9R4/JFK2zJDvGMbSynKNVxtyqqXePPCDnOvAGKZ9Muirlolp1xxK1O pzGOHHnVeQylaTM/XWvT4kEtZn2+TKUhnZdM3kHVwn9bX48KvPR/p+VFKV6ciNjXIHGRlB4Df37/KprN4oVCj2eB5UN3hQkujoXtPvs+lrHGJEzpRwugodoVx/orjxgNqO/y4GavFriGUEE+75152yqdU8ZoxUZrkifH2kBClJSlXdr8hXMcX fBPZA9590GuiXrgWmCe+RpMVz7pA0QqQNDueFX/E9i7HiFaXPfUqFE70OlYom0jMKvSKxq7qKHOlMn7XNsYoN63ip g0xFq7IM4rK26mspuCcY3DgAo/DXEnTLHf9xSplpZ4JPdI+qm1hYlO4Ouw0PxTVK6P69DKZcZIOd PKvLec0ipnmCBOWB30M2RPGs5pm7FprRwmCKlZcyKzJmO6h7ZU 7En3T/GmdvkI132naq80HqGjZZuQkOpBPf9dAP9ALUkkCCTP31qNdmpM hJ14EGtkvLG5M+NRHyJRWaJfjqT1C7FMJtrcQE5idIoG1aCTmV oToI2HKjb1ntFapUo8OA8KWOKJMmmxm5LtjoVKJI8/EDczNRFR3O591ag1rn1HzpiQ5tHoVrI7/hWztx2fL50OrfzrZfs6D786niJm+iDEXyGzCwTHHaueYlfHTxm r7et/Rq22+8VQr/D1KGZPDhWv4eZ2ZnkpnqMUW6RnUTlGgJnSp7i5CjI00pAUkHiK 269W01pp9FBoJKwEweZ+NRlUpA4/KoACTRLVmSoJTqo8tqhnDTA7pQE/mkR9lXuyxUKgzB0mkuH4aEMlsCVGJP6XOmjfRNeUFKoPHeszyl CT7L3jzklg1cxGBJ1HdzpJil8FAjKJ5/woe8YcaGVRB7+VKyo86CmvPQVktPEp50ZbpgjWhPOaJtzTpIUh l50NcJnjUrQmvHxA1+BpVa7wGa1AvUCvK3kcjWVY4sTxGLOKLm JAHJKUj6qmRdrJ0fUD3yPKdqGVYtJP4xE/pOf/lMU0wuyaWfaQY5LUR8qr2/quwaoOUhzaXT4R2lApI2IBH8aj65pZhSMiuaDv3gE/CmdvapAhJg+OlA3djKjmToOKdD9nyrO5ps24rFgG5aQZQvMPcf cdRTTDLvgqfvzFC+p6aKBTzJhXhz8j76MsmpISsROyhSbUM0bo GYdnYfL6q9RbHhp37imNlaluM4058PMj66es26Y0iPhSo+I5Ir y8ni+ikYgwQCVA6Cqm85KjXVMYtAttWXka5na4cpZIBAI56E02 qni8Y+m7mgOtSa3faUhRSoQaGecgTVpQ+gpvOzF863SZ0O1LWL sKV3CnVm3mHlQ2riBCXIEubWUkRXnR/CEOJUgHUbHjO3102dZlPHxrbom0EO92s0tXNLUzpQTKfj3Rfq1 Q4CjkoCUHlI3BqvvdH1R2VNqHPWvpFa2XBlWBqI1FVm/6HWK1EyUzwTpVyr/AEMXZmyobfRw1OCqB7Skj9WZpvhlplIS2kqUfMk10v8A0RsESS VK5CT7qMTfW9un6BpKTB1I199Ml/oJro6PisruE4G4yM7wGY7pPAd3Opri/JBSBArL3ElPA7HuP1UBPAj3VSlY5vWXa6lFCrFiTxV57Gk66sl 4Uxon9o0iuESZq/RLEIsj2QoTNTobitEjnUyHo1Bjwp29CsDGEmNCDUN04RpFRv3S jvr460I9cTw+J+VdCC0TY8RJ1hrKF62sp/ERzZs23MACfifIVfuj+FZG5Ig6cJpDgSgV/RpygbnTN5qiR5RVuRtWV5t2fqjR8OnFyCEN8R7ypI+FSlzxHga FSitVGsvmaOabvqjgCOca+Gn2UVhjoTrruNP4cfKgVqP+VFYOC VmYI5byPOilLUDJdF4sblCkgJUPA6K/zopi3ykmdI9mNN9/GlVpYp9rcEeyfqP1U3Y0H21erfRlTXZIECNBFc96ZYOlLiXBpB EkGNO+uhhzmKR9IGkrbUFUU2l2M8duMihXd6kN53UyEA77kTpN KMUQHGEuJbUnrPZgg9404VYsD6OLuW/pTCCSI4kAx7qu+HdHGkADLMADXXyHKjrl/C1fevRx3A+jr5P4shPM/XV0TgxQgaaxrXQkMITpAHlQt/ZhSTFI8iqc1omvyEnhzu4YgAg+Iig2BlM06uWcqyDpG3Ee6lzl zlP4xQH6IH17VUri/TLfyG3rU7kiNvGvcyzur3VL+EUxutU/nEfZUYcSdQI7p+0VDhnolS0He7lbUtuVlXA6cvsNMi4OWnjQz5 ABIHxo4Non2LEknXL48K9yEg6ifGt7i8nRQg0ISsHQE98/x0qzFaBLEQvNEb5fEEmhnwOc8Nvtpg8QrTWeR3+w0CpEHUacjr ViHRWmwBSCDt9R91bZZ0IpiE6diPBW3lXiO9KQeca/GmqQsFFr4UC4DNPooG9to9mmV2d4V5rRbNe1t1auVZVjkJwt+F W6W0COPGm6Vilq4jSvetMV5+eyfZuQSisGnWV5NBtXHOpTc0rg HpIpdZZ3WVUiZoB27moEOxuaPh0RunRsMxVKxE603buRGu1cuY uDvtTuwxxYMTp30UZ8RE6Uy6JeJMzIPCq/0pvT1ZCdyD86lLi9DvP30pXfW7i9ADqoe4cKZz5ISocS34Kzlb QOSRp5CmhcpNZXPZAG8cakXdE6AgHjT65dCZx1hiX51IgjnvQj 7qj7KtO8aeEiorq5InXhvG3fSW4xPKJVBnlIPu1G3fTvaBSIcS tlrUTKO/kPeZqtXdkqTCmT3KI+Z0p85eNlJI48NQffVWxdxontKUjv9v4a H40j4470WFI3V6ykSGgU8ClCVfKaCOLq2MA8imD7opfbFCVdm8 6vkQlxM/VTT8KpgC4eaeHNbKkn/uImDTvxiVbhCrFVH9E8xpXnryz3jwFav2tq6forpLavzVlWUnk FkSPEg1u9gFw2AvQp/RVnB8CkGo/HCVyYI+ud9+da54/z3qJayBJB+/DxodSzPcePD+FSqmiHNBZUDukGtULI+/214hNSLjeuSYps1UedYF+dYda0SiDTeGC3IKA0qK4RIqSa2UgR QrpgvsVZDWURl7vjXtO7FYNku1OpWlLmlQNamQ9WY6pGs5GyyR XiHT51iAVGBTG0t0gwrfeofQDmBpZUaIRZGDO/CnTTKeFTBsUrZfwH5BKbc7V6ho5hrxpm8UpoR9xI1SfGo4Tf0T 8pbMIfBSBy50xyp5VTcGxMqIA1A4jbXnVjtruQVe7z0psa5LrB UpaGrb07OhoBy6y5swk8+Md1TuXEEDhFKsRvJzDfXSp4tMhYyR F0YICidNJE+8UI88BqY25AClqrh0CculBXWJ5QdCPKRVitt9HO IXfXcJnY8ANvjSJWNIJhxAPMEBXw0NDXeKg+yT5UvdugrcA/P3inqrvsFyHi2bVeoaTl4qQdvIkEVpeYDbFMoknuXl/srGvvpOAJ7JKFd8kftDbzo1hxwb9knZYEoUO8beaYpyTQttMWL w9saLW40eS28w/bQaZ4S482PoHQ6jigjMlQ5RuPHSpkvAyhY6pR3/KbVpM5eAPMRQN7hWQyOyT7ImUqj8xf1GKNNt4QsGPrQdJ6tSmn Pym19pJgcM3DuoNbhSSHGx4jsjxAGnwoM364yqhUcFAEiOE7xR bV+hwBDiYnTNqQPLfzGtc4nciF64SDoCO7+NCLuSrwra+sFN96 d/I7EHYjvFQNNd3nQOCXZ2hluvSigmhW00YigbINiawbV6BW1Lfs mIPlNZU1ZR4dgjexWoWb4qWEg7mkXjR+EA9YmAPGrjqSQP5DbO h4Ra5E95rdf42a2ZdhI8KEDoK96ypQ1j1IsnRXC2rq9KH0BxKb cqAJMBXWgTod40rbA+jtsvGr+2U0Cy00wpDZKsqVKSkqIE7man 9HKv5QX/Vf8YUd0c/1hxP+gtv7iK16YpQRUm3pBgHRS0cvsSbWwlSGnLcNpJVCQq2bW oDXiok+dAdEOizD91fdcnO1b3JaaZJOQSAolQntbwAdKtXRf+c sW/pbb/6rdUjCuk6rLEb0Bp15py5X1obbWtTShAQsQIIKd0zO0UzigdY5 ewexvLN5+1ZFs62XkoUiG1ZmSpMkJMLQSNjzqH0d2uG3lu22pr PcoZbU9nS6nU7nMYCteVZ0z6DWmIsm8swkPwpQUB2HSJzIcSRo vQidCCNaS+gi9625uCBADDenL6RUCuzs7Rn0wNgw4lm1QUXKHm yvKl2AgglQKz2diNJqTodhbN1c3PrDYcyNsFIUT2c3W5joeMD3 VW+ndxlxS50/KRr/AO0jhVo9FFwV3F6pX+7thpy+lpLjtujfUA9HRrD7v1hFu2tl23 cU0VoUtJS4EghQGYpWnUaKEd1IOgWCMXtndJfaSq6bW6jrO0DK grIsa8FAgfq1dsKcac9eRYw0+H1JeWtBUC/lHbjNqIjiPCqT6NLnqbxDat3WnWXO963dWqfPM6fOm4kwNeA7/Ri2ZwNl5y3Su7dQ2kOKBKw4+vQ7/khX9mkuF9GTcP8AUh5pkBKVlbntKClKTDaZAKuzx5jeugdOFdZ d21uB2GULfI5KP0LQ9xcqr9MrBCrV5a0AqS2SlRAJBGxB4Uiyx KxRDinxbDenPRC1s7Ngso+k9YQhTpJK1gpcKsx21I2iBApX0Bw hm5vS1cNhxsW6lhKpy5g4gZoB3g1ePSm1mtLdPO5a/du1WfRgwUYmoH/hV/vW6bv7JAd5pYFdEsLfeetE2+R1lLalKQVoIDk5ClYVrBB0NJPR 90RZLD714n1hTb76EpXqhIYUUSG/ZKyUkyasmMdIsOsLt91x1QuXENBbYC1kpSD1YSkCBOY6zVH9HP Tlxpx5LzDqrZ64ddS4htawypxZUpC8o1TttqDPCmYAHdLsCsX8 KOI2rIt3A0HkhMIJTICkLQk5Tpx4V450Vsx0f9aFuj1j1IOdbr n6zIDnmd5rT0jdAbZVuvErIIBCOuUEwWnURmLieCVR2tNDrpT1 7/Vb/wCPT+7FSTop6M9H7a3wkYhcs+suFnryF9oJB1ShtKuynQiTEmv PSN0TYt2m7u2QGgXG0uNpnIpLmiVBOyVhRGoiQTSjBPRh61h7V wi5KFut5koUn6NJJgJmZjyq6+lp9CMPaaUQVKetwlPFXVqClkD uCT8KGSWHJ9nLmk1OmtVNxqNUnY93I1iqzH7wsEla5+1FeBydq 0iTUfZBNFZXleU7UCUKaYYL+MEnjQITUjS8pkcK0GtQk6CXeFB rJBkUmscZnRW/Dwoty9TETvtVP4MY3mXr0b4rZ25duLm8bbeJU0G1rQkJbSrMlQ TGYk8zUWFdMmG8ZurtSiLa4ShpLpSqAW0tgOERIbUQrtERoDsa o1tcQRWOvwZFWV6AZ2tGMWFq5dXartsi5U2opCkqMttJbCUJRK lEhMxFVP0f9KWmLm6N0rqRdu9chS9EhRJT1SlDRKsuQ66akcK5 +xdIzHRII3MAH5UWrFG+JG2xqHJ6R0dTaxmxwq1dSLpLpccedS kKSpalumciUonQHie8mudegvGLe1uLg3LzbILLYBWsJBIUZAne qPimIJUR1YA01IAE+6ldMQLZ0XppfIfxV1xhxLjZ6uFIIUgwhI Oo0q4+j3Fre0fujcvtshbbGXOoIBy9Zmid4ke+uRdF3srwk6cu ddNtrgZdKqW2Oue4OguUcLjhnSDCrVVy4i+bWp94vLAWlZzFIG VCECToNtTNU7AbpDVza3L6g0hVxcuKKzlCA6l0oCp23A8TUoIU RNNm4pb8rX6DVWE15ijNxiDrjDqHUC3ZSVIUFJCg44SmRxgj3i l3ShzrLO4CR/slR316/cKWcqdqNaWEJiqk7OVnNBpYsCel2P2t0i2at7hl1YuG1FKFhRA DboJIGwEigMIu2rPEA5cOoaQq2cSFLUEpKutbOWTpMAnyqdq/HCp7m6J0AOWGh7KSJ6wl06j8wAedWo38rN/gtxyOFM6aLbur64eYWlxvKykKQoKSSEGQCN4mnnowx+3ZYdsrh wMkuLU2pZhK0uASAo6Zgc2h4RQt9eNgJBRuuVAp4ddmKtv92Ii fKlt1eMLSUrQkiNg2ka9eCkTw+iB9+tNVjjLX6J4xlEs/SLGbOwwhdg3cJeWWHGWwCFLOcEZ1ZNEJGY6nlQj3SW0/0d9X9ZZ6/wBRSjqs6esz5AMmXfNPCq6LZhTq+pbQmEQFdUnLHWiU5ISCerO XMAYncxNC3l9adtpKUyHnAITpHXApUlWWMoQCIkDuM09TTFOOD Nu7tvwGEfhFfX9RHq3XtgZ50b6vLm8pmq+poFWYlSlgR21KWQn 9FSidO4Ux/CdsVgqSkR1+UhsAJBWgtEgJM9kLGoJE1JbX7K8vZCAkvLP0YJm T1IlSTpHCDw00oZvSY9C4PlM8U7EeP11qt3kdDT83zCoGUZeuK wOr0ILASFbbByZTxoV+4aKClAGZRbSpfVBMwlfWrCY7AJyciYM VWlFB6KWTRTcmDHjRrb7aUZQiQEHXIApSuvEdo6j6KeOk0fcXz ZDqUAJCkKAPV8esSpCIyjUJSROusSTFBxJ0TRWVLlV9yKyo6O0 58K9NZWVpsrnifaFGDh41lZQslBtvuPEVPcbGsrKg4Snc+FCnj 5fKvKypj/0QCmvRXlZTWCwvDPxqa6Xh/se75mvayqHlex9XsZMUwG3lXlZVNFn6NLHc1JdVlZSfsEhwr2q bq9msrKKH/YMyn9IN00pXt51lZVmz6Or9EFz7B8aSub+Q+YrKynVegbPZKjf 78qaYf+R41lZRyAQS1sPH662PHxr2spD9k/ZsnYVO19/jWVlAwjWsrKyuOP/Z
Old 02-05-2015, 09:18 PM
  #223
Did you decide if you are going to go with stock or lower compression? I think Pauter is the only place that makes J series rods, but they are proud of them ($$$$ I think.)
Since you are going all out, lower the CR to 9:1 and crank the boost up!
Old 02-05-2015, 09:22 PM
  #224
I believe that the CR will be lowered to 10:1, Pauter is the only place I've seen the J series rods, they are quite expensive. The guys at SpeedFactory are researching options on aftermarket rods.
  #225
UTAH TSX's Avatar
That was supposed to be a picture
Old 02-05-2015, 09:23 PM
  #226
^lol
I bought wastegate springs for my turbosmart 40mm compgate yesterday that would allow me to go up to 21psi... I don't think that would be a good idea though. The current spring in the wastegate is 7 psi and I get to 11 psi with my boost controller, I'm thinking I'll put in the 11psi spring and have some overhead.
Old 02-05-2015, 09:34 PM
  #227
@ UTAH TSX WTH did you post? I can't see it. Its just coding
Old 02-05-2015, 10:18 PM
  #228
UTAH TSX's Avatar
It was that sad cat wanting boost picture, gone wrong and I couldn't edit it
Old 02-06-2015, 05:32 AM
  #229
^lol
I could be wrong, but I think 10:1 and 21PSI might be pushing it a bit. For a high boost setup, I wouldn't got above 9.5:1. Granted you can always turn down the timing, but then the motor would just be lazy and ultimately power limited. Sure you'll have meth, but do you want that to be a 'helper' or the 'only savior'. Just ask the OMG WTF SUPER STRONG 2JZGTE Supra guys if their engines are 'indestructible'. Doesn't matter the parts you throw at it if it detonates, it can still blow.
I may be misunderstanding what you are saying with the wastegate. If you have a 7 psi spring, you would be limited to 7psi if you don't have a boost controller (given the wastegate is large enough and doesn't creep.)
If you go to an 11psi spring, that is the lowest amount of boost you'll be able to run. A boost controller will let you go higher, as it bleeds off manifold pressure that the wastegate sees, so I don't understand why you couldn't run 20+ PSI with the 7psi spring and a good boost controller.
Old 02-06-2015, 05:59 AM
  #230
KN_TL's Avatar
Should have bought my customs. Can't find off the shelf for $100 each.....someone in CT took them off my hands.
Pauter was the only ones I could find which were close to $1500. But they do make the stocks look like toothpicks.
All this money into your cars and you all won't spend a few hundred on a boost controller instead going to swap springs?????
Old 02-06-2015, 08:46 AM
  #231
I'm not going to run 21 psi. I have a boost controller, it must not be a very good one though as it maxes out at 11 psi right now. It's a blox manual boost controller. What boost controller would you guys recommend?
@KN_TL I don't think I realized you were selling your customs until after you had already sold them. In hindsight I should have picked them up.
Old 02-06-2015, 09:01 AM
  #232
It doesn't make sense that the boost controller maxes out at 11. Are you saying that having it set to run as high of boost as it can it won't run more than 11 psi? That sounds more like a mechanical issue with the engine.
The wastegate has a spring that is set for a certain manifold pressure. in your case it is 7psi. The boost controller has a ball and spring that essentially 'fools' the wastegate. It allows you to run more boost as the spring in the boost controller takes more pressure than 7 psi to let pressure flow to the wastegate, thus raising the boost.
If you have it completely tight, I would think the wastegate would never actuate, thus allowing unlimited boost.
Typically people have the opposite problem. They put a small spring in the wastegate and it exceeds that because the wastegate cant evacuate enough exhaust pressure. I believe that is why Utahs went to a different wastegate.
An easy test (well, dangerous tho) would be to disconnect the wastegate pressure line. If you build more than 11psi, then your boost controller might be doing something funky. But, be warned it could go to 40+ psi since the wastegate will never know how much pressure the engine is seeing.
Old 02-06-2015, 09:13 AM
  #233
I just thought - are you running the stock map sensor? If so, you'll be limited to 10PSI by the Hondata.
That has nothing to do with the wastegate spring though. I REALLY hope they have the boost cut enabled.
Old 02-06-2015, 09:22 AM
  #234
Well it seems like I didn't have to order new wastegate springs since the boost controller should allow me to go above the wastegate spring's psi rating.
@Screamin I think you just solved why I am not seeing over 11psi, I have a 4 bar MAP sensor, but the boost cut off is set to 11.5 psi. Would this be limiting the amount of boost I'm seeing from the boost controller?
Old 02-06-2015, 09:23 AM
  #235
Not with regards to the wastegate, but it would limit the engine RPMs once the boost reaches that pressure. That's the only way the Hondata can limit boost. Once it senses 11.5PSI of manifold pressure, it won't let it rev past that.
maddogtheta (02-06-2015)
Old 02-18-2015, 08:52 PM
  #236
Update
pistons from bank 2 and 3 had cracked ring lands this second time around. No Skirts falling apart. I'll hopefully have some pictures of the damage tomorrow.
Old 02-20-2015, 01:09 PM
  #237
Broken pistons
Here are pics of the pistons that have failed, three broken ringlands, one broken piston skirt.
First time my engine broke:
Cylinder 1 with the broken piston skirt
Cylinder 6 with broken ringland
Second time it broke on the last dyno run before I got it back after reaplacing the broken pistons with oem:
Cylinder 2 with broken ringland
Cylinder 3 with broken ringland
Pauter rods are going to be installed for added reliability
Old 02-26-2015, 10:53 PM
  #238
6spd-GERCO's Avatar
I know you didn't get to mess around with the turbo much but how did the traction control work out for you?
Old 02-27-2015, 11:13 AM
  #239
I ended up not getting the traction control installed. It was going to end up costing too much and from what I read about the TL's traction control it seemed like that system would be enough for the time being.
From what little time I had driving my TL around turbo'd and the way that the power came on gradually with the turbo mounted in the rear, I never had any issues with traction.
6spd-GERCO (02-28-2015)
Old 02-28-2015, 11:46 AM
  #240
6spd-GERCO's Avatar
That make sense, I was hoping you tried it because I haven't see anybody with a TL try Hondata traction control. I know for ice rally x and winter autoX racing the TL's TC sucks way to intrusive.
Quick Reply: Rear mount turbo - Type S
