Rear mount turbo - Type S
#161
No offense, but I would think you don't have the budget to NOT do them. You just put a pile of money into the car. Are you simply doing a stock shortblock and returning it to stock? If not, you could be putting yourself back in the same boat without using better pistons. Granted, you might be fine with a stock shortblock with increased ring gap and water/meth, but it's SUCH cheap insurance to do pistons since you're doing a motor anyways, I'd strongly suggest it, as well as lowering the compression ratio. You can then turn the boost up and take better advantage of the water/meth injection.
#162
damn, that sucks. Same thing I had happen to me.
One good thing is that I ran my motor with badly cracked lands and it didn't damage the cylinder. But.....after only 35K miles, about 8K of it boosted, the cylinders were out of round which were fixed by simple honing. Unfortunately, it put it outside the clearance specs of any off the shelf forged pistons. If you're interested in some CP's, let me know.
Here is some info. These are modeled against SC70404
#163
Luckily I am able to borrow my parent's oddyssey so I won't be putting many miles on it in it's current state.
#167
Oh yeah, I didn't think about that either. These pistons definitely do not seem tolerant at all.
#168
Another thing that didn't hold out if anyone recalls from tony the tiger's thread is that car originally was pushing 442HP on the stock J32 and the motor dropped a valve from the stock valve train destroying the engine. Which led to the high CR turbo build that was done to that car.
#171
#174
J-series addict
Yep, stock ringlands are very susceptible to damage even with mild detonation. That's why widening the gap of the stock rings is the best mod you can do while you're in the bottom end and plan on running boost. And adding water/meth injection is the second best. Ok, maybe tuning the damn thing correctly is above both of those but you all get my drift here I think. That's a statement that's tossed around waaaaaaay too loosely around forums IMO.
#175
I'm leaning towards going low compression forged pistons and a water/meth system at this point. I have to talk to the guys at SpeedFactory Monday about it and see what they recommend.
#176
Don't go to low of compression that is old school thinking, you will loose a bunch of pre boost power and take a big loss in gas mileage with 9.0-1 compression, with the engine management we have and forged pistons 11.0-1 is not a problem with a proper tune, you will have to run much higher boost to get the same power and your lag will be even worse with low compression, hell the new civic's are 11.0-1 and people are running 10-12 Lbs making over 400 WHP with stock internals with a 2.4L 4cly. and they are very dependable, it's all in the tune bad tune bad problems guaranteed
#177
#178
It remains to be seen if it is going adversely affect the performance but I am more concerned with margin of safety if I get a bad tank of gas or my meth bottle runs dry and I don't notice it. Also shit happens with electronic components in the hostile environment of an internal combustion engine that could cause things to go off.
Just my opinion.
screaminz28 (01-11-2015)
#179
I agree with KN. While there are numerous examples of 11:1 tubo'd vehicles, I'd say it is the exception rather than the rule, and they have very little margin for error. Also, we can't compare to anything new OEM turbo that uses DI since that is a completely different ball of wax.
Imagine how much MORE power the civics would make with an extra 5 degrees (or more) of timing.
#180
#186
How are things going ? have you tore down the engine yet ? we are still tuning we have about 25 datalogs with vitt changing them each time and we are still at 4 LBS tapering to 2LBS this is as low as we can go, Vitt is being being very careful
#187
I'm taking the car in to SpeedFactory Monday. They're going to pull out the cracked piston and put a new one in. They're also going to install an AEM water/methanol system.
#189
#191
crazy
Yesterday I talked to the guys at SpeedFactory and was surprised when they told me they had pulled the oil pan off to remove the piston from cylinder 6 with the broken ring lands and they found chunks of metal. Upon further inspection the piston skirt from the piston in cylinder 1 had broken somehow. They were going to look into forged pistons and get back to me.
I went in to the shop today to see the damaged pistons and talk over my options. When I got there they had a theory on why the piston in cylinder 6 had the cracked ring lands. Apparently the broken piston skirt from the piston in cylinder 1 made it's way bouncing around in the engine until they wound up in cylinder 6 where they broke the oil squirter off. This caused the piston in cylinder 6 to heat up which weakened the piston. The added heat made detonation more likely. The detonation cracked the now weakened piston's ring lands.
They had never seen or heard of a piston skirt breaking off before or how the pieces made it all the way to the opposite end of the engine and break the oil squirter off. I guess I'm just that lucky
The plan now is to replace the two pistons, replace all of the rod bearings while the pistons are out, and install a water/meth injector for added safety with the benefit of increasing timing.
I should have the TL back early next week.
#192
I've seen aftermarket pistons drop their skirts, it happens. Had a set at a friend's shop sitting around just to show people. Usually just bad luck. Haven't seen an OEM piston drop its skirt, seen a weird situation on a 9th gen where the skirts melted away, and only the skirts... the rest of the piston was OK.
Sorry to see you go through all this trouble, sucks to see it happen no matter the why/how/when.
#193
#194
If the whole thing is apart and you're going to be replacing the bottom end bearings, it just seems a waste not to at least go with a stronger set of pistons.....
EDIT:
Too lazy to look but did you mention how many miles are on this motor?
#196
I suppose meth is going to help with the detonation but the stock pistons are just too fragile. Are you going to have some kind of firehouse type alarm when the bottle is empty?
EDIT:
EDIT:
The guys at SpeedFactory seem to think that what happened to my engine was a fluke, and the information that they've been able to gather leads them to believe that the pistons will hold up. I'm inclined to believe what they tell me and trust their experience. If I have further engine issue then I'll know for sure that I need to go with at least forged pistons... There was also the issue of at least a three week wait for forged pistons to be in stock...
The engine has ~99k miles on it.
#197
I'm installing the AEM V2 water/methanol injector along with their failsafe gauge that alerts to any issues with the flow of the water/meth as well as letting me know when I'm out.
ring land failure seems to be a weakness
3 weeks for customs is way off, more like 4-6.
I would have given u a deal of the century.
good luck in whatever u decide!
maddogtheta (01-22-2015)
#199
Even if what occurred was a fluke with regards to the skirt, the ring lands are a known weak spot. Are they at least going to take the existing pistons out and widen the ring end gap? If not, I'd say you should start saving your nickels for when the others do fail.
I don't want to take anything away from SpeedFactory as I'm sure they are top notch, and the quality of their work is excellent, but I'm kind of surprised that they didn't have both water/meth injection from the start (unless they strongly suggested it and you declined) and also the light for the oil scavenge pump. It's great that they have recommended so much stuff AFTER the fact, but those two items would be cheap insurance against larger catastrophe.
#200
The only issue is that if you have further engine issues, it could lead to having to replace EVERYTHING.
