Questions related to 07 TL-S Brakes Systems
Hi Guys,
I'm sure some or most of you have upgraded your 07/08 TL-S Brakes Systems.
What have you upgraded?
Front Rotors? Drilled? Slotted? What Brand? Brembo? Or? What's the Model #? If other brand, are they compatible with Brembo Calipers? Or have you upgraded the Front Calipers, too? If so, why?
Have you upgraded the Rear Calipers? If not, then, What about Rear Rotors? Is there Brembo Drilled or Slotted compatible with stock Calipers? If so, what's the model #? Or other brands.
Do drilled or slotted rotors need resurfacing every once in a while?
I know these are lots of questions.
Thanks in advance
Thanks in advance
http://www.heeltoeauto.com
Nothing,
so, I've tried http://www.excelerateperformance.com/
and only Rotora,
got, Basic OEM:
R.40061
Axle Rear
Position Left (Drivers Side)
Position Right (Passenger Side)
R.40062
Axle Front
Drilled & Slotted:
R.40061.2C
Axle Rear
R.40062.1C
Axle Front
R.40062.2C
Axle Front
R.40061.1C
Axle Rear
Slotted:
R.40061.2S
Axle Rear
R.40061.1S
Axle Rear
R.40062.1S
Axle Front
R.40062.2S
Axle Front
Now, my questions still remains: Are these compatible with Front Brembo Calipers? What about rear Calipers? Have you upgraded them?
Do we only have Rotora as a choice?
94 DC4 RS LSV/Turbo
if you want the full low down on upgrading your braking system pm excelerate
josh (excelerate) has a few recommendations and can outfit your car with some pretty great prices
Some Options
Stop Tech or Rotora Slotted Rotors
Stop Tech or Rotora Drilled Rotors
Rotora Slotted and Drilled Rotors
for pads there are a ton of options depends on what you want performance, quiet, less dust etc.
Some Options
Some Options
Some Options
AZ Community Team
Received 7,771 Likes
ok, went to
Nothing,
and only Rotora,
got, Basic OEM:
Nothing,
and only Rotora,
got, Basic OEM:
You're not doing it right.
HeelToe Auto for Racing Brake and StopTech (YES for Brembo):
http://www.heeltoeauto.com/Heeltoe-B...-pr-40007.html
Excelerate Performance for Rotora or StopTech - you have to pick the part for YOUR car (i.e. TL MT or TL-S = same brakes).
Personally, I'd recommend slotted over drilled/slotted, but either way is fine if you get a good brand. Racing Brake ET series pads are the shit.
Almost nobody upgrades rear calipers - very little gain for the cost.
AZ Community Team
thanks again for all the info.
AZ Community Team
Racing Brake is a light-weight, 2-peice rotor with a special vane design for cooling. $$$$. Some of the best brakes available for this car (Rotora makes a 2-peice as well).
StopTech is a simple match to the OE design with slots. I tracked the StopTech fronts with ET500 pads this week-end, they did very well. Some moderate fade late in each session, but overall very good for the price.
thanks for all the info. sorry for asking so many questions.
Hey Bearcat94,
Thanks for the response.
But, I went to StopTech, and it's confusing, there so many different stuff.
I don't understand the list at all, I mean I see that there are different size, for sure.
There is AeroRotors, AeroRotor Direct Replacement Kits and SportStop Direct Replacement Rotors.
However, which are which? Could you help me out?
If I want Front Rotors to go with stock Brembo calipers do they work? By the way, I went to Brembo site, and they also got drilled or slotted rotors, are those any better than StopTech? What about Rotora?
So, nobody upgrades Rear Calipers, right? Then what about rotors?
AZ Community Team
Not everything that StopTech or Rotora or Brembo (or whomever) makes will fit your car.
Go to these sites and look up fitments for your car:
http://store.excelerateperformance.c...s/c-10043.aspx
Then, once you see what's available, go to the manufacturers web site for that model/type (Racing Brake AeroRotors for example) and read the product description and benefits.
I don't think you can buy Brembo Slotted or Drilled direct; and be careful of no name companies that buy blanks and drill them themselves.
Direct Replacement - Exact OE size and fit and/or OE Style Design.
When in doubt Call or PM Josh at Excelerate or Marcus at Mr. HeelToe. They wil discuss your need, your car, your budget and put you onto the right product.
Former Sponsor
To make this easy just give us a call or send us an email at sales@excelerateperformance.com with your vehicle info and zip code. We'll give you a quote and explain to you the differences.
mada51589
05-03-2022 08:54 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
