Pushing an Acura TL to 300whp
So, a friend of mine pointed me towards the TL as both a performance car and a reliable car. I must admit the more I look, the more I'm intrigued by them. But, I was wondering if it's possible to push a stock 2004-2008 TL from the stock ~275bhp to ~300whp. Here's my limitations though:
- Mainly bolt ons. Nothing super custom or that has to be blueprinted. I want a daily driver that's fun to drive, not a stock car.
- Needs to run reliably on 87 octane (don't want it draining me at the pump)
- Want the 6-speed manual, NOT automatic
The kinds of things I'm thinking about are like performance headers, downpipe, maybe CAI, modest tune (again, wanna run 87 octane), etc.
I know for another car I like, 2009 Cobalt SS sedan, I've seen plenty with 350whp or better out of a 2.0L turbo. So, I'm hoping a 3.2L V6 naturally aspirated can achieve 300whp at least.
Is that doable or am I just dreaming?
j32 or j35?
not going to get max power with 87 oct or cheap. Engine dumb down the timing and you will actually be using more gas and producing less power. You might also run into knocking issue once you start modding.
might happen for the 3.5L but not for the j32 unless you are willing to put stage2 camshaft and hondata. sorry but you will have to throw tons of cash at it or run boost.
EvilVirus (11-02-2015)
Registered Bunny
The TL is also a very... err... not rewarding platform. It's not that you can't make more power, it's that it's not cheap nor easy. Gotta pay to play as they all say.
As for the comparison between the Cobalt SS and the TL... it's a completely different car. There's nothing that ties them together other than they both have wheels.
Stock BHP is technically 258 on all 3G base models. The 04-05 were overrated at 270. I'm probably around 270 whp with all the conventional bolt ons and Flashpro tuning. 300 N/A can be done, but it will take cams on top of all the standard bolt ons and most likely head work as well. Figure on spending at least 8k to get there. You will most certainly not be running 87 octane though.
Huh, I thought the TL ran 87 stock. No matter...
If I did add a few bolt-ons (performance headers, downpipe, CAI, modest tune), how much do you think I could add to it realistically?
And another question (kinda related): what kinds of things could I do to reduce 0-60 times? I could care less if a car can do 150mph+, where am I ever gonna go that fast on a daily driver? But, if I can shave some time off 0-60, that interests me.
My advice to you is to read more of the performance section to understand the TL better.
Here read this one:
https://acurazine.com/forums/perform...mplete-897606/
Here read this one:
0-60 is not this car's strong point. It's not a good "light to light" car. Summer tires can help, but only so much. I recently got left at a light by a VW Golf R32 (they're AWD) as I was spinning through first. I caught/passed him around 75 mph, but a lot of technically slower cars can/will get you off the line. You don't want to get into it unless you have enough road to stretch its legs.
Not to be mean but unless you are planning to drop 8-10k to make significantly higher HP ask in turbo or S/C. your not going to get more than 30whp with bolt ons. What you will do instead is change the area under the curve and expand the power band.
EvilVirus (11-03-2015)
^ my bad. I was thinking Auto not MT.
But yeah 40-50 whp will run you close to 3-4k or more depending if you get new or use parts.
Catback:500-1000
Jpipe ~450
PCD ~400?
CAI~ 100-250
Flashpro~ 700
Etune or dyno tune ~100-450
Pulley ~250
SHAWD IM ~300
ZDX TB ~250
PNP lower runners ~150-250
MDX or P2r IM spacer ~70-150
Catback:500-1000
Jpipe ~450
PCD ~400?
CAI~ 100-250
Flashpro~ 700
Pulley ~250
SHAWD IM ~300
ZDX TB ~250
Easy way to drop your 0-60 time is to decrease the tire circumference by going to a lower profile tire with the same tread with. However, gas mileage will suffer accordingly.
Jeff
I've pretty much done all of the bolt ons with the exception of PCD/HFPC and pulley (maybe next year) but where I'm a 06 theres no flashpro available so not getting the full potential out of it. But I can tell you the car responded pretty well to the bolt ons... is it a super fast car now?? NO, but it can go when pushed.. Buddy above is right it shifts the power band. The car is pretty much all top end now, its pretty fun to rip around in now but I will say it did not come cheap.
Lose weight. It's like free HP
Oh Sickest TL (11-10-2015)
Mr. Detail
Cold air intake (doesn't make much power on its own but helps more if you are modded), intake manifold from a larger J-series engine, larger throttle body, maybe Type S, MDX or RL cams, etc will all help make power.
Definitely make the car more fun to drive but if you're hunting for 12s, going to need a power adder for sure.
rockyboy
Dating & Relationships
11-02-2015 10:48 AM
Jamyll22
11-02-2015 09:29 AM
MonkeyTrucker
11-01-2015 06:43 PM
