Project TL: Engine swap has begun!
Old 02-12-2007 | 11:45 AM
  #161
csmeance's Avatar
Old 02-12-2007 | 12:32 PM
  #162
neef's Avatar
Real Estate Investor
man this guy straight grinding!
Old 02-12-2007 | 01:05 PM
  #163
lookinco's Avatar
B A N N E D
I didn't know so many people are following this thread. Now i am even more excited!!
Anyways I also located all the wires I would need to wire up the E-manage ultimate. I will get that hooked up and see if it could be a solution to tuning the ECU.
Old 02-12-2007 | 01:47 PM
  #164
neef's Avatar
do you mind sharing the wires so I can cmompare it to what my tuner is going to wire to when i s/c the TL?
Old 02-12-2007 | 01:49 PM
  #165
lookinco's Avatar
B A N N E D
Are you also installing the Greddy E-manage ultimate or just the ACM that comes with the supercharger?
I will have the wires /pinout typed out in a bit.
Old 02-12-2007 | 02:02 PM
  #166
lookinco's Avatar
B A N N E D
2006 TL automatic ECU:
...................................pinout color
Ignition Coil 1...............A20 YEL/GRN
Ignition Coil 2...............A19 BLU/RED
Ignition Coil 3...............A18 WHT/BLU
Ignition Coil 4...............A17 BRN
Ignition Coil 5...............A16 BLK/RED
Ignition Coil 6...............A15 BRN/WHT
Injector 1.....................A21 BRN
Injector 2.....................A31 RED
Injector 3.....................A30 BLU
Injector 4.....................A29 YEL
Injector 5.....................A28 BLK/RED
Injector 6.....................A27 WHT/BLU
VTEC solenoid..............A22 GRN/YEL
MAP sensor..................C5 GRN/RED
Crank sensor...............B17 BLU
Cam sensor.................B8 YEL
Knock sensor...............B6 RED/BLU
IAT sensor...................A5 RED/YEL
Speed sensor..............B19 BLU
Pedal position sensor..D3 RED/BLU
Ignition........................D6 BLK/GRN
Ground........................A1 BLK
Sensor Ground............D7 GRN
Old 02-12-2007 | 03:06 PM
  #167
dan.....k's Avatar
What would be different for the MT?
Old 02-12-2007 | 03:46 PM
  #168
lookinco's Avatar
B A N N E D
The above pinouts are actually the same on both automatic and manual ECU.
Old 02-12-2007 | 03:54 PM
  #169
03TL_S's Avatar
2006 TL-S.C. 6mt
JUST JOINED the thread, i am shaking with anticipation
Old 02-12-2007 | 03:58 PM
  #170
dan.....k's Avatar
Thanks lookinco! Hondata or E-manage? That's going to be a tough one. I'll wait and see what your results are. Hopefully it can handle the HBP from Comptech.
Old 02-12-2007 | 04:01 PM
  #171
neef's Avatar
probably go with emanage ultimate with a s/c
unless hondata is done..
Old 02-13-2007 | 07:27 PM
  #172
Knertified's Avatar
+1 for anticipation on this thread. Everytime I get an email, I click it to see the details. You should try to snap some pictures of it in the shop to keep our attention
Old 02-13-2007 | 09:38 PM
  #173
Eoanou's Avatar
'10 Hyundai Genesis Coupe
Did you put the motor is yet, is the car running?
Old 02-13-2007 | 09:59 PM
  #174
JoeyASPEC's Avatar
2006 TL
I cant wait to see this. You better post a video of the finished product! lol
Old 02-13-2007 | 10:41 PM
  #175
evantec's Avatar
Ev an' Tec
Talking
LOL - There were 3 things that came to mind when I saw this picture:
1. Now I know who shifts the gears when the automatic is in Drive.
2. If that's the male voice for the NAVI system, where's the woman for the female voice?
3. I think I finally found affordable housing AND a decent car both for under $40K.
(It looks like the roof doesn't leak either!)
Old 02-14-2007 | 02:48 AM
  #176
lookinco's Avatar
B A N N E D
hahaha..good one!!
okay I will snap some pics tomorrow. I will definitely make a video when the car is running.
In the mean time, I just received my premade E-manage harness for the 03-06 V6 Accord. I will see if it would be compatible with the TL.
Old 02-14-2007 | 02:54 AM
  #177
lookinco's Avatar
B A N N E D
And here is a picture of my new wheel. Nothing really amazing. But it sure is pretty light, only 15.5lb each.
Old 02-14-2007 | 02:59 AM
  #178
Accord_V6_400m's Avatar
4drs just wanna have fun!
Cant wait to see this thing in action!
Old 02-14-2007 | 03:02 AM
  #179
aznbo187's Avatar
Any news with the transmission?
Also, what exhaust setup will you be running?
Old 02-14-2007 | 03:10 AM
  #180
lookinco's Avatar
B A N N E D
Transmission is in the shop. They are working on it already.
As for exhaust, I am going for the sleeper look. Going to keep the rear OEM mufflers but changed the B pipe to 2.5" with an E-cutout. Also replaced the 3rd cat with a straight pipe.
Old 02-14-2007 | 06:54 AM
  #181
lookinco's Avatar
B A N N E D
Turns out the wiring for the V6 Accord is totally different. Good thing is the plug seems to be identical so all I have to do is rewire the harness and should be good to go. At least it will still be plug'n play and I won't have to butcher the stock wiring harness.
Old 02-14-2007 | 08:25 AM
  #182
Meek32v6's Avatar
I like to whistle in my
Nice wheels! What size? 17" ? I personally have been debating between stock 17" and 18" now because of weight. I know if I getter a lighter 17 with some good rubber the acceleration would be even better. And with a drop it won't look that bad. Nice updates on the ECU wiring too. Did you try boomslang?
Old 02-14-2007 | 08:42 AM
  #183
Nitrotiger's Avatar
very intresting project
Old 02-14-2007 | 09:17 AM
  #184
ACCURATEin's Avatar
tehLEGOman
More pics! More pics! Enkeis for the win!
Your odessey was pretty smokin so your TL in theory should turn out smokin as well.
Old 02-14-2007 | 05:11 PM
  #185
lookinco's Avatar
B A N N E D
Thanks guys! Okay new pic! Here is my special edition Enkei RPF1 in Time Attack style.
Old 02-14-2007 | 05:50 PM
  #186
Meek32v6's Avatar
haha! Thats what i want to do for mine. 17-18 lightweight black with a red lip.
You're going to be killin them with those on
Old 02-14-2007 | 05:51 PM
  #187
lookinco's Avatar
B A N N E D
I actually did buy the E-manage harness from boomslang. They don't have anything avaliable for the TL probably because no one have ever asked them to make one.
As for the wheels, they are 17". I want to keep my 17" Advan A032 / A048 tires. I know it looks a bit small especially it has a lip on there.....hope it won't look too bad on the TL.
Old 02-14-2007 | 05:56 PM
  #188
PPLAPW's Avatar
I'm in
Awesome!
I may have to plan a trip up North...
Old 02-14-2007 | 08:17 PM
  #189
Meek32v6's Avatar
Cool. I think they'll look fine. I've only seen one other TL member with them. Most will be against the stock size but Im for them. All depends on what you are trying to do with your car
Old 02-14-2007 | 08:21 PM
  #190
lookinco's Avatar
B A N N E D
Thanks for the pics! I have always been trying to find a TL with the RPF1s and now I finally got it! Looks pretty good to me!
Old 02-14-2007 | 09:11 PM
  #191
red00tl's Avatar
Wow, a nice thread.
I hope everything works out for you, lookinco.
It's also good to know there are mod shops in Vancouver area.
I thought they were all south of the border.
Old 02-14-2007 | 09:37 PM
  #192
mmcv6's Avatar
313.4WHP& 284.6TQ
looks good. let us know how much work is needed for the rewire for the boomslang harness? I talk to boomslang about the tl harness for the emanage last week. He told me he would order the factory manual and to give him a ring later on this month. I was going with the emanage before, but now I might be able to get hondata which is alot better. But I plan to ring up boomslang and see what he has for our car. You should do the same so for sure he will make it for us..
cool...
Old 02-14-2007 | 09:45 PM
  #193
lookinco's Avatar
B A N N E D
I already have all the pin outs needed for him to make the harness. If he really does want to make one, I can e-mail him the pinouts.
I have already started modifying the harness. Pretty much everything needs to be rewired.
Old 02-15-2007 | 12:11 AM
  #194
Meek32v6's Avatar
no prob Yours should come out real nice black with the a-spec lip
Old 02-15-2007 | 01:12 AM
  #195
leedogg's Avatar
RAR
Dont be silly.
Everybody knows she's in the trunk.
*hides*
Old 02-16-2007 | 12:32 AM
  #196
lookinco's Avatar
B A N N E D
Nah...she is in my bangbus....haha
Anyways I am working on the E-manage harness and I came upon some questions. Maybe you guys experienced with the E-maange could shed some light.
For the stock MAP sensor, do I simply hook it up to the Airflow Voltage 1 wire of the E-manage and use the stock MAP sensor to tune?
OR
Do I hook up the stock MAP sensor to the Analogue voltage input/output of the E-manage and use it to clamp the voltage of the MAP sensor going to the ECU so it won't throw an engine code when it senses boost? Then use the Greddy pressure sensor to tune accordingly to boost pressure?
Old 02-16-2007 | 04:19 PM
  #197
Pika817's Avatar
07 NBP TL-S
Lookinco, I just noticed you're in Vancouver! Do you work/own at a shop in town?
Old 02-16-2007 | 07:03 PM
  #198
lookinco's Avatar
B A N N E D
okay....after further investigation, I found out that the 03-06 V6 Accord E-manage harness is compatible with the 04/05 TL ECU.
The 06 TL ECU however is COMPLETELY different.
So technically if you guys with the 04/05 TL want to try out the E-manage, the 03-06 V6 Accord harness would just simply be plug'n play for you.
Old 02-16-2007 | 07:17 PM
  #199
special-ed's Avatar
Iro Ridg .308
^^^^^hell yeah. good find!
Old 02-16-2007 | 07:25 PM
  #200
lookinco's Avatar
B A N N E D
Hey, the shop is Advace Motorsport down in Coquitlam. I do not actually own or work there. I am friends with them and they are sponsoring/helping me. I work on my car together with them.
Quick Reply: Project TL: Engine swap has begun!
