Please help looking for a clutch conversion
Hi,
my clutch is going out on my 07 acura tl type s.
was going to replace it but I have the dual mass flywheel and I can only find it for about 800. bucks.
does anyone know of a conversion kit so i can do away with the dual mass flywheel?
or possible cheap place to get one?
runnin a little boost
Hi,
Well I was looking into a cheaper way to go. just seems like 800 is over kill for a flywheel. If I can get a standered set up that might be cheaper and possible last longer then I would just go that way.
Why are you replacing the flywheel? If all you want is a new clutch, then just do that, should only be around 300 in parts + labor. Chances are the flywheel is still good, they usually outlast a clutch. How many miles?
Former Sponsor
If you have a TL-S and the OE DMF is good I would just upgrade to a CM kit.
http://store.excelerateperformance.c.../i-332336.aspx
SidhuSaaB
05-30-2020 12:40 AM
