Pads & Rotors swap
Old Dec 1, 2010 | 11:06 PM
practice89's Avatar
Pads & Rotors swap
i recently purchase slotted rotors and pads from stoptech and planning to do the swap over the weekend. Just wondering if you guys can give me some pointers/tips for the job.
Old Dec 1, 2010 | 11:10 PM
if you havent already, look up mrheeltoes guide to getting the "pin" off the rotor.
I didnt have luck using his method. So i took an extra bolt that i had and screwed it into the rotor, pushing it off the "screw"
I heard a loud pop, and I knew that I could just screw the "pin" out.
the pin looks like its very easy to get off. it looks like all you have to do is take a phillips screw driver to it. but believe me, you either need an impact driver or mrheeltoes method.
or do what i did and just screw an EXTRA bolt in.
when i say extra, it means youre going to be destroying that bolt.
Here is a picture....
as you can see, the two screws are circled.
the yellow circles are where you bolt in the extra bolts.....
Old Dec 1, 2010 | 11:13 PM
practice89's Avatar
thanks i'll look into that. ive searched around and found that you have to clean your rotors with something (which i can't remember) or it'll cause problems? and other tips will be grealt yappreciated
Old Dec 1, 2010 | 11:19 PM
brake cleaner?
you just want a clean and perfect working space.
Old Dec 2, 2010 | 07:24 PM
practice89's Avatar
Anyone know how much brake fluid I need to do a brake fluid flush?
Old Dec 2, 2010 | 07:31 PM
OneWickedTypeS's Avatar
MY KBP IS BTR THN URS...
Be careful with the brake fluid, I just had my calipers on my Type-S replaced due to Acura not doing a very good job cleaning up after the flush/service. The clear started coming off.
Old Dec 2, 2010 | 08:47 PM
practice89's Avatar
Thanks for the advice but mine's a base so Ill be fine on that end.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
