Nitrous Setup!!
Old Sep 12, 2007 | 01:27 PM
mo's a-spec's Avatar
Post Nitrous Setup!!
Just wanted to know how many ppl on the forums are spraying or have tried it on a 3g tl. would want to know if i should spray in my car since i do have the kit laying around and not doin anything. any problems with it?
Old Sep 12, 2007 | 01:37 PM
Pizza4Everyone's Avatar
let it laying around
Old Sep 12, 2007 | 03:09 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
there's been a few people on this site that spayed... however, it was done correctly with a drive by wire module/switch and only with 50 to 75 shots... this engine isn't NOS friendly 'cause of it's high compression...
Moe... do it right by a professional...
Old Sep 12, 2007 | 06:47 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
I'd say pass on that...
Old Sep 12, 2007 | 06:51 PM
ballinfizzle89's Avatar
FizzyStatus!
Old Sep 13, 2007 | 12:06 AM
JOES05tl's Avatar
Moe, look up a place called bottlefedracing- they know their shit, give them a call. A 70 hp & 70 tq bump all the way from when you spray 'till redline is no fucking joke! DIRTYJOHN has a tl-p on the bottle and smokes GTO's, vids are in the racing forums. If you have timing advancing mods(hondata, stand-alone, etc.) then you cant do it. But if you dont- you will have no problems. Just talk to some pros about your setup first.
Old Sep 13, 2007 | 11:27 AM
erick3's Avatar
Originally Posted by ballinfizzle89
...minus the stupid
Old Sep 14, 2007 | 05:02 PM
just got off the phone with bottlefedracing. they told me that i wouldn't need that flyby wire. but he is gonna get a second opinion from another shop. i have a nitrous express kit capable of like 50-200hp depending on the jets u use. any1 have any info bout where it is best to shoot at? into my aem intake? or intake manifold?
Old Sep 14, 2007 | 08:34 PM
JOES05tl's Avatar
thats a really tricky question. Heres my attemt to answer-
You could spray into your intake pipe, before the throttle body, but then the issue of uneven loads on cylinders arises, cuz the juice might have an uneven amount going into each cylinder, cuz the closest ones can get most of it. Or the issue of pooling(bad).
You could also do a totally custom direct port injection (very expensive) and probably never have a problem for the life of your motor :wish I hope this makes sense, cuz its friday, and I'm already fuct up!
Anyways, I think theres 3 people w/ 3g's spraying into the pipe w/ no reported problems. then theres a guy (no names!) that thought he could do a SC w/ methanol inj., and nitrous. ANd a high boost pulley, i think, and his engine is not with us anymore- rest its soul, HA.
As long as you not trying to spray more than 60~80'ish, then you should be alright w/ this method. There is a bunch of 2g tl on the bottle. Most notoriously, DIRTYJOHN!!! Anyway, good luck. And the guys at bottlefedracing are good people. But good luck!
FUCK- I WROTE A BOOK!
Old Oct 24, 2007 | 01:39 AM
LudaChris's Avatar
I suggest spraying in the pipe at least 12-16 inches away from the throttle body, I've been using N2O for quite a while and from experience when I used to run the nozzle right on the throttle body (Prelude), cylinder closes to it (#4) tends to run leaner according to how the plugs look and also #1 compared to 2 and 3. Real proof was on the compression test, about 15-20psi lower.
Old Oct 25, 2007 | 01:05 AM
LudaChris's Avatar
I highly suggest you use a drive by wire, basically a Zex kit(recomended) who all started it, easier install if that matters to you. Not unless you want a switch on your pedal.
Old Nov 5, 2007 | 04:23 PM
1FastVtec's Avatar
Disturbin' The Peace!
Like LudaChris said, Zex is what I would run. Their Nitrous Control Module monitors the A/F Ratio and if its either to rich or to lean then the module won't allow the system to spray. Give Zex a call, they really know their stuff!
Old Nov 11, 2007 | 04:45 PM
OntheJob's Avatar
Keep'n it clean- Orlando
NOS is fun.. but factor in the price of you bottle fills over a certain period of time + what you pay for install and just get a blower for an extra chunk of change. Its all preference but once you ride/drive a supercharged car "any supercharged car" NOS will never cross your mind again.
Old Nov 11, 2007 | 04:53 PM
S1CK TypeS's Avatar
B A N N E D
call up excelerate he can point u in the right direction. he'll be installin mine
Jul 16, 2017 07:33 AM
yesSIR-S
May 13, 2016 05:42 PM
dirleton
Sep 25, 2015 12:25 AM
Sep 17, 2015 09:01 PM
