New exhaust on its way!!!
Old 10-13-2014, 12:44 PM
Weezy2328's Avatar
whats up guys I finally pulled the trigger and got the xlr8 non res catback exhaust for my 08 tl type s....some quick questions, should I do a ecu reset after the install, if so can someone explain the steps....also I have a aem v2 cai, so now that ill have them paired together I wanna get it tuned so the car runs perfect....can I just bring my car to a dyno or do I need some sort of hondata??
also lately my car has been boggin when I press the gas pedal from a stop...all I have is the intake installed, and when I first installed it, the throttle response was very good now it sucks!! anyone have any info on this!!!?!?
Old 10-13-2014, 12:51 PM
Received 16,260 Likes on 11,971 Posts
you dont have to do anything, except install the exhaust.
if you want to buy hondata to get the car tuned, then yes, you'll need to spend money on Hondata and dyno tunes.
but if all you want to do is install your exhaust, then that's all you have to do....bolt on exhaust and you're good to go.
Old 10-13-2014, 12:53 PM
Weezy2328's Avatar
alright thank you...any insite on the car boggin then getting a powerband at like 3000rpms
Old 10-13-2014, 12:57 PM
could be anything
Mugen.Justice's Avatar
Have you tried resetting the ECU?
https://acurazine.com/forums/third-g...-happy-747662/
Post #17.
justnspace (10-13-2014)
Old 10-13-2014, 01:03 PM
Weezy2328's Avatar
no should I wait for my exhaust to be installed or just do it today aftyer work? would it make a difference
Old 10-13-2014, 01:09 PM
you're thinking waaaaaaaaaay to hard on this.
to see if it will fix your bogging issue, reset the ECU according to thread above.
then, when you install your exhaust, you can reset your ecu.
it only takes 2 secs and doesnt hurt the car at all.
so, if you want to do it before or after your exhaust, you can.
Old 10-13-2014, 01:10 PM
Doesn't matter, might as well do it now - it only takes a few minutes. Try it. Maybe it'll address the issue.
Old 10-13-2014, 01:20 PM
Weezy2328's Avatar
ok thank you
Old 10-13-2014, 07:48 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
also clean your aem v2 filter if you haven't done it in a while
Old 10-13-2014, 09:40 PM
Weezy2328's Avatar
Im bringin the car to mienke to have them put on the exhaust, my intake is loose down by the corner bracket, u think mieke can tighten that
Old 10-13-2014, 10:36 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
How long have you had the intake on and how soon after did the car feel like it was bogging?
Old 10-13-2014, 10:37 PM
TacoBello's Avatar
Why not do it yourself? It's not that hard. Save your money and learn something new!
Old 10-14-2014, 06:03 AM
yeah, lemme put on my Oculus Rift/Samsung Gear VR.
ahhh that's better!
I can now see your car over the internet using Virtual reality technology!
/sarcasm.
how in the world do you think we can see your loose intake bracket from the comfort of our own homes???
Old 10-14-2014, 06:57 AM
Weezy2328's Avatar
got the intake around xmas time last year and I would say the bogging started to happen around 1-2 months ago
I guess u never put in a cold air intake in ur tl cause thiers only one bracket down by the wheel well that actually holds the intake...I don't have the time or space in my apartment complex to take off the bumper so I just wanna hve someone do it
Old 10-14-2014, 10:27 AM
Former Sponsor
ExcelerateRep's Avatar
Exhaust was shipped out yesterday! Thanks for the order. You should get Hondata Flashpro. The Flashpro comes with OTS tunes for the TL's and you will not need a dyno tune as the Flashpro tune is more than sufficient. We have the Flashpro's here in stock and they are on sale as well!
Old 10-14-2014, 12:32 PM
TacoBello's Avatar
Clean your filter. You should clean it every 6 months. Even a factory intake filter needs to be replaced every so often.
I wouldn't be calling justn out, if I were you. Your questions are a bit silly. And if you're going to mod your car, you need to be able to do at least minimal work on it. Mods more often than not reduce reliability in one form or another. If you want to pay meineke to take your car apart and tighten a screw for you, then so be it, but I wouldn't trust those guys to give two squirts about your car. Who installed the intake for you in the first place? Isn't meineke like an oil change/exhaust shop? I seriously wouldn't trust them to take my car apart. It's a one hour job. I'm sure you can find the time.
Old 10-14-2014, 05:05 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
You don't even have to remove your bumper cover to fix it. Just pull back the fender liner. Hell you don't even need to jack it up; just turn your wheel.
OP you got friends get a garage day going and get it done.
joflewbyu2
10-08-2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
jmaxima03
09-27-2015 10:22 AM
prbori
09-27-2015 01:37 AM
ivan06106
09-26-2015 04:38 PM
Quick Reply: New exhaust on its way!!!
