Need new ATLP J-Pipe v2 Gaskets - Mine are leaking
Old 08-13-2011 | 10:07 AM
PeteThaPitbull's Avatar
2005 Acura TL w/ Navi
Lightbulb Need new ATLP J-Pipe v2 Gaskets - Mine are leaking
I need to order 2 new gaskets going from the 1st and 2nd cat into the ATLP J-Pipe, does anyone know where can i order them from and what part numbers? I ordered gaskets from delray acura and i think they sent me the wrong ones (part# 18212-SA7-003 - Gasket, EX. Pipe Ishino) they are just round ring looking gaskets but doesnt have the holes for the studs like the ones i have on their now thanks
Old 08-16-2011 | 12:12 AM
anyone?
Old 08-17-2011 | 10:51 AM
LoveMyTL-S's Avatar
Anyone?
Old 08-17-2011 | 11:09 AM
Yvuru's Avatar
got pictures?
my xlr8 exhaust did not come with gaskets. the performance shop where i had it installed ordered a set of gaskets from the local parts store that fit perfectly.
not familiar with the atlp jpipe but maybe you would have similar luck to me. go to a shop and see if they can order the right parts for you... unless you need atlp specific gaskets then you will have to ask heeltoe about that
the gasket for my xlr8 exhaust was pentagon shaped with a 2.5 inch circle in the middle (i think it was 2.5)
good luck
Old 08-18-2011 | 12:39 AM
KidChenz89's Avatar
05 SSM
This should help you http://www.heeltoeauto.com/ATLP-Perf...-pr-65863.html
Old 08-18-2011 | 03:40 AM
vietxquangstah's Avatar
Originally Posted by KidChenz89
those are the correct ones. i purchased a use xlr8 jpipe and it did not come with any gaskets so i purchased those from heeltoe and they worked perfectly.
its actually 3 gaskets... 2 for the primary cats and 1 more for the 3rd cat at the end of the jpipe
Old 08-21-2011 | 01:02 PM
thanks, i think those are the ones i need. the ones i ordered are just round rings (they look like this - http://www.google.com/imgres?q=ishin...w=1366&bih=661)
Old 08-21-2011 | 03:19 PM
JTS97Z28's Avatar
They sent you the right gaskets if you ordered oem ones for the stock jpipe, you simply ordered the wrong stuff. They are crush rings however those are not what you use for an aftermarket jpipe. You will need the normal flat gaskets that I would imagine you can get from any of the jpipe manufacturers. I know for a fact RV6 sells a hardware and gasket kit for 29 bucks. I made my own using a sheet if gasket material from autozone for 10 bucks. I also used a small bead if gasket maker on both sides if the gasket. No leaking on mine.
James.
Old 08-21-2011 | 10:25 PM
OneWickedTypeS's Avatar
MY KBP IS BTR THN URS...
When I needed gaskets I had to go back to the source, and by that I mean I had to order new gaskets from ATLP.... I could not find a dang thing local....
Mike734
12-10-2021 02:25 PM
iRaw
ILX Photograph Gallery
30
08-05-2016 05:41 PM
InFaMouSLink
10-27-2015 07:52 PM
Avenger411
10-11-2015 04:53 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 05:35 PM
Quick Reply: Need new ATLP J-Pipe v2 Gaskets - Mine are leaking
