Looking for CamShaft Tester
Old Aug 25, 2008 | 01:44 PM
PowerRev's Avatar
I know a lot of you guys on here are interested in seeing a camshaft released for your cars. We have made cams for these engines a few times in the past already; however, we have never installed them in a TL with stock ECU.
We get a lot of request for cams for the J32A3 and we are finally going to give in and try to release a camshaft for this engine. We will however, need someone who is willing to test out a set on their engine. Basically we need to see how the stock ecu is going to react with the camshafts, and how much HP you are able to pickup.
Camshafts will work with stock valve train.
We only have a few requirements for the test dummy.
1. Must have J32A3 obviously
2. Must have Intake, Exhaust, & P2R Spacer
3. Some sort of AFC, Emanage, etc for slight adjustment after camshaft install
4. Access to dyno,
We need someone who will be able to do an install and dyno within 2 weeks of receiving the camshafts.
If your interested, please call me at 954-326-0497
You will be required to post up all results here on Acurazine, along with pictures, info, etc.
Old Aug 25, 2008 | 01:45 PM
PowerRev's Avatar
Ahhhh, how did i do that. This was suppose to post in the Performance Section. Sorry Mods
Old Aug 25, 2008 | 01:49 PM
TeknoKing's Avatar
Good luck with finding the "test DUMMY".
The idea is great, but gambling so high at our expense? Good Luck.
Old Aug 25, 2008 | 03:32 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
^ true in part... but I'd be that dummy if they were in nyc rofl
Old Aug 25, 2008 | 05:19 PM
PowerRev's Avatar
We are actually not lookin for someone local.
Old Aug 25, 2008 | 05:25 PM
phee's Avatar
I got the Shifts
too bad its not for the 2nd gen
Old Aug 25, 2008 | 06:15 PM
TeknoKing's Avatar
Really? what's the logic behind this?
Old Aug 25, 2008 | 07:34 PM
modificata3's Avatar
07 TL type S NBP!
wow...if I had all the mods required I'd be on it
Old Aug 25, 2008 | 07:57 PM
ussi's Avatar
I (don't) whine.
Re-post this in the performance section...some people are interested in cams. You need to couple this with tuning obviously if the cams are significantly different than oem.
Old Aug 25, 2008 | 08:41 PM
ABP_04TL's Avatar
6-SPEED LOVER
damn y u sooo far $%^& !!!! come 2 NYC
mada51589
Jan 9, 2025 04:40 PM
dirko
Oct 1, 2015 08:45 PM
Sep 14, 2015 10:09 PM
heyitsme
Jul 19, 2005 09:29 PM
