knock sensor trouble
Old 03-12-2007 | 11:27 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
ive been told to reconnect the knock/map wire back to stock?-by mmcv
(the comptech s/c has caused me to throw a knock sensor 1 code.)
its bucking and surging real bad.
any s/c guys here know what to do, or have any Cali shop phone numbers where i can call them and break down what wire to relocate?
prec
Old 03-12-2007 | 01:20 PM
ACCURATEin's Avatar
tehLEGOman
...i just passed through jacksonville yesterday on 95 north....thought about gettin in contact with you to check out your TL.
I'm not sure what to tell you other than have everything connected as the directions indicate. I haven't had any check engine light problems besides a miserable evaporative emmisions control leak that isn't detrimental to anything besides passing inspection.
Old 03-12-2007 | 02:27 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
yeah im goin crazy, i really just need to know what wire to bypass from the acm, directly back into the ecu (knock sensor wire) cant determine the color
Old 03-12-2007 | 04:22 PM
lookinco's Avatar
B A N N E D
knock sensor wire is on terminal B6. The wire is RED/BLUE from ECU and Black/White and White/Black from the ACM.
Old 03-12-2007 | 04:47 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
lookinco. the TL genius! i'll let you know how it works
Old 03-12-2007 | 04:52 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
LOOKINCO---
is there anyway i can call you on your cell real quick? i am still confused, or in detail explain what i need to do to bypass this wire?pm me
Old 03-12-2007 | 05:50 PM
StYLeZz101's Avatar
i also have this problem and have been lookin for a way to fix it..when the charger was 1t installed it worked fine and then i was about to run a 350z and the stupid light comes on so i was like damn...and when i checked it..it was the knock sensor.. thanks for the wire code..
Old 03-12-2007 | 06:00 PM
StYLeZz101's Avatar
all u have to do is solder back the red/blue wire from the ecm to the red/blue to the engine??
Old 03-12-2007 | 06:08 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
just waitin on the professional remedy,,,,=)
Old 03-12-2007 | 08:06 PM
lookinco's Avatar
B A N N E D
Yes, just hook the RED/BLUE wire back up together.
One thing you guys should check to see if your engine is hitting / rubbing on anything that could case a vibration. The knock sensor is very sensitive to vibration and noise and would throw the code if it senses anything irregular.
I had the code before and I found out that my Greddy strut bar was hitting the bolt on the intake manifold. As soon as I raised the strut bar, no more knock sensor code.
Hope it helps!
Old 03-12-2007 | 08:47 PM
StYLeZz101's Avatar
Hope it helps!
i'm gonna try with the wires 1st i havent heard n e weird noises comin from n e there and doesnt seem like n e thing is touching it...it sucks having boost and not being able to enjoy it...if this doesnt work it might be bye bye tl..
Old 03-13-2007 | 02:37 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
Like I told you. Reconnect the wires back to stock.
Easy fix..Will take you 30 seconds...
Old 03-13-2007 | 09:53 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
thing is, i didnt do the install my tech did, using the instructions, so its hard for me to explain to hm what to undo...wish i had a diagram or something
Old 03-13-2007 | 10:09 AM
lookinco's Avatar
B A N N E D
Here is the link to the supercharer installation manual which includes the wiring diagram for the comptech ACM.
http://www.comptechusa.com/store/med...-SCKit2005.pdf
Old 03-13-2007 | 03:18 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
sorry to be a nag, i just want to do it right---am i re saudering this wire? so i remove the wire from the piggyback and relocate it to the ecu? argh
Old 03-13-2007 | 05:34 PM
StYLeZz101's Avatar
i juss looked at mine and it wasnt soldered...i connected it back with out using the acm and if this works then i'm goin to solder it back
Old 03-13-2007 | 07:10 PM
StYLeZz101's Avatar
well i connected with back to the stock way bypassing the ACM and so far nothing has come on yet... and i've been beatin on the car..pushin it to see if ne cel would pop up but nothing, i'm gonna give it a week or so b4 i go and solder the wires together..
ok now i have a question... what was the point of goin through the ACM for the knock sensor in the 1st place?? is it b/c its more sensetive and it would come on earlier...and would there be a long run problem having the ACM bypassed for the knock sensor?? cuz i think there has to be a reason y it was suppose to be done..
Old 03-13-2007 | 08:49 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
gonna do it tomarow
Old 03-13-2007 | 11:28 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
comptech only had you connect the knock wire into the acm just incase they modify the knock signal. But they did not and never changed the instruc....
Old 03-13-2007 | 11:30 PM
StYLeZz101's Avatar
Thumbs up
thank you telling me how to fix it and i also wanna thank lookinco for tellin exactly what wire it was
Old 03-14-2007 | 12:55 AM
lookinco's Avatar
B A N N E D
You are welcome.
Old 03-14-2007 | 02:35 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
super
Old 03-14-2007 | 04:41 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
done!!! thanks lookinCo and everyone else
easy fix
now should i put the high boost pulley on....=)
08KBP_VA
10-22-2019 02:55 PM
Jinkazetsukai
11-21-2015 06:28 PM
RobbDizzle
10-15-2015 12:16 PM
thegipper
09-28-2015 02:01 PM
STL TL-S
09-23-2015 09:52 PM
Quick Reply: knock sensor trouble
