J36 is done
#205
J36Twingt28r's,nextgt30r
^^ he said its about a little more than 5k. i know cause im trying to save up for it as we speak, i should have $$ for the build by end of march so paul get ready
#207
5k that's almost what i paid for my Tl i already have the money and i was thinking about it but changed my mind, getting a n-240zx with supra engine on boost,$9000 love the TL but is not definitely a car to be racing.
#210
Block, head castings (ported), valves & springs, oil pan, intake and runners (ported), rear main seal casting, mount castings, spool valve and casting, ect non friction parts, the crank, rods, pistons, rings,bearings, cams, spring retainers(I am now replacing all retainers with Ti ones from KMS for $120), water pump, timing pullys, timing belt, oil pump, all gaskets and seals get replaced. Head bolts are replaced if they are out of spec when pulled.
#211
Registered Member
Ok. I was just trying to see what would be a better route to minimize downtime of a vehicle. Didn't know if I could buy a new block and go from there or if Id need to buy a spare engine. Sorry for all the question just want to get my research done before making my decision. My car has 119k on it so rebuild time will be in the next year. Thanks for the info Paul
#217
hmm so paul i've been meaning to ask will the kms forged piston decrease the hp/ torque expected to gain from a j36 build? cause i know u use forged pistons from another acura. plus have u tried the kms block guard at all yet?
#218
I talked to them about the block gaurds about a year ago and was told they stopped making them. As far as pistons, the RL pistons I used , although forged are not as strong , the forging was done so that thinner material could be used and reduce weight, although they are still stronger than cast OE parts.
#219
so for the j36 would i be better off getting kms pistons if im going boost? and will the kms affect the compression ratio compared to the rl pistons used in the j36 build originally?
#223
All motor
Can we get a video of at least ONE of the J33/35/36/37s!?!
#226
so paul when u do the j36 build do u switch it from dbw to cable right away or its that an additional option i have to pay extra for? also the fic 8 u guys have been talking about for the turbo kit, will i be able to use that fic8 for a j36 until i get the turbo? thanks for the videos paul looks amazing. and hope to see some more soon!!
#228
cool so did u get the 80mm throttle body working then? im pretty sure u charge 450 or so for the 80mm throttle body + trading in my stock manifold, and tb right? but u said on v6net that this 80mm throttle body will benefit the NA people better so i shouldn't do this, cause im planning on going FI right? plus what should i tune the j36 with since im planning on going boost?
#230
Hey slippry! In regards of your j36 stroker
id like to inquire how I’d get ahold of Paul to do the same work on my tl.
#231
#232
Read the post above you, Paul's been permabanned here for a while now
#233
NVA-AV6 was banned and hasn't logged in for over four years, and slippry hasn't logged in since 2009.
handsom-hustla
06-14-2015 04:27 PM
96cd5
09-27-2013 12:04 PM
