I pulled a 13.94 @ 103.03mph in my Base Auto!
TheTLProject (11-24-2016)
#446
Originally Posted by TheTLProject
My current one is pretty heavy it's an Interstate.
And fugly . They aren't sponsoring you why are you giving them free advertising?
EvilVirus (11-29-2016)
anx1300c (11-28-2016)
#453
Ive taken this whole thing way too far.
The following 2 users liked this post by thoiboi:
EvilVirus (11-29-2016),
TheTLProject (11-28-2016)
teh CL (12-01-2016)
#462
Originally Posted by thisaznboi88
buy my camshafts and be faster!
Best of both worlds
#465
I ran them in my untuned motor without issue pre-hondata flashpro when I was N/A. I also had Port and polished TL-S cylinder heads at the same time.
dynoooo
https://www.youtube.com/watch?v=qft1jwqH8uc
dynoooo
Whats a good price quote for labor on this?
#467
3.5 psi
that won't be worth it unless you can put them in yourself.
Do you have ported manifold, runners and bigger TB? If not you should tackle that. Do some reading on DIYs and you can tackle the runners and manifold yourself. Send your TB to maxbore.
#470
2006 Full-Bolt Ons/Gutted Acura TL Auto Base
AEM 3.25 inch Cold Air Intake
Ram-Air Mod
Throttle Body Coolant Bypass
EGR Valve Bypass
J37 Throttle Body
J37 Intake Manifold
P2R J37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 TB Thermal Gasket x2
P2R J37 IM Thermal Gasket x1
RV6 Hi-Flow PreCats
ATLP V2 J-Pipe
JE Test Pipe
Vibrant 2.5 inch Inlet/Outlet Ultra Quiet Resonator
XLR8 Y-Pipe
Rear Mufflers Delete w/ XLR8 Single Tips
UR Lightweight Underdrive Crank Pulley
AEM Fuel/Ignition Controller
BoomSlang Adapter Harness
BrakeLogic Drilled/Slotted Front & Rear Rotors
Hawk HPS Brake Pads
BFGoodrich GForce Comp2 A/S 235/45/17 Rear
Bridgestone Potenza RE71R 235/45/17 Front
Lightweight Wheels
Stock Suspension
Pro-Tuned By JE Import Performance
Weight Saved:
Hood Insulation (2lbs)
Sound System Amplifier (3lbs)
Shifter Column Top Plate/Friction Strip (.5lbs)
Center Console Bracket (.5lbs)
AC Blower Cover (.75lbs)
AC Controls + Navi Screen (4lbs)
AC Top Vent + Clock (1.5 lbs)
AC Blower Motor + Filter (6lbs)
AC Rear Routed Air Ducting (1lb)
Driver/Passenger Air Vent + Trim (2lbs)
Leftover Carpeting (.25lbs)
Engine Bay Grill Cover (1lb)
Trunk Vibration Dampener (1lb)
Stock Airbox Replaced w/ CAI (8lbs)
Weather Strip (above hood) (2lbs)
Engine Bay Covers (6lbs)
Spare Tire (36lbs)
Rear Floor Mats (6lbs)
Rear Seat (46lbs)
Drivers/Passengers Seat Kick Panels (10lbs)
E-Brake Hand Assembly (5.5lbs)
Rear Window Light Cover (.5lbs)
Interior Carpeting + Insulation (25lbs)
Door and Center Console Trim (10lbs)
Front Floor Mats (5lbs)
Glove Box (9lbs)
Roof Console (3lbs)
Dashboard Removal (75%, 7lbs)
Glove Box Mounting Beam (.5lbs)
Trunk Insulation (23lbs)
Lighter Exhaust Parts (30lbs)
Lighter Intake Manifold (8lbs)
Passenger Air Bag (13lbs)
Side Air Bags (10lbs)
Air Bag Trim Pieces (4lbs)
UR Lightweight Underdrive Crank Pulley (7lbs static, 21lbs dynamic)
Headliner and Plastic Bracket (6lbs)
Rear Door Panels (14lbs)
Center Console (13lbs)
Rear Speaker + Rear Sub (8lbs)
Center Speaker (.5 lbs)
Drivers/Passengers Side Tweeters (1lb)
Rear Seat Belts (6lbs)
Rear Speaker Cover (5lbs)
Foot Rest Plate (1.2lbs)
Partial Firewall Insulation (10lbs)
Radio Delete (6.5lbs)
Metal Front/Rear Door Accent Trim (2lbs)
Front Door Panels and Front Speakers (22.5lbs)
DVD Drive + Touch Sensor + Buttons (5.5lbs)
Rear Wheel Well Insulation (3lbs)
Sun Visors (2.5lbs)
XM Antenna (.5lb)
Front bumper vibration damper and support (26lbs)
Motegi TrakLite V2 Wheels (55lbs static, 108lbs dynamic)
Full exhaust heat shield delete (3lbs)
Steering wheel undertrim (1lb)
Passenger Seat Head Rest (3lbs)
Passenger Seat (57lbs)
Drivers Seat Plastic Trim (1lb)
Rear Roof Light (.5lbs)
Current (New) Scale Weight: 2998.5lbs
Factory (OEM) Scale Weight: 3580lbs
Static Weight Removed : 581.5lbs
Rotational Weight Removed : 129lbs
Total (Static + Rotational) Weight Removed : 642lbs
Fluids Used
Motor Oil - Motul Fully Synthetic
Transmission Fluid - Honda DW-1 ATF
Pending mods
Innovative Polyurethane Motor Mounts (85A)
RacingBrake Lightweight Front Rotors
Coilover Suspension (Brand undecided, 1 inch front drop, 1.5 inch rear drop)
Type S Non-Adjustable Front Sway Bar
Progress Adjustable Rear Sway Bar
Nitrous Xpress 15lb Bottle (50hp, Dry)
Three Inch Single Exit Exhaust
Lightweight Racing Seats
Larger 4 Inch Intake w/ Oversized AirRaid Filter
Ported & Polished Lower Intake Runners
Ported & Polished Intake Manifold
Ported & Polished Throttle Body
Nitto Drag Radials (245/45/17)
Full AC Delete
Random Information
Intake and intake manifold are under wrapped with foil duct insulation to reflect heat away from the two parts.
Rear doors are permanently locked
No traction control & no ABS
All airbags disabled
Top 3 Best Quarter Mile Times (ignore the time, the trap speed tells the whole story) (Car weighed 3100lbs for these runs)
13.8 @ 102.45
13.9 @ 103.03
14.0 @ 103.08
My YouTube channel with every video for the car so far:
https://m.youtube.com/user/Dark04GTS
thisaznboi88 (12-09-2016)
#472
3.5 psi
you don't have ported runners on the list. I don't see how that would hurt performance, especially since he's doing the 1/4 mile and is mostly using top end. I could see it hurting torque a little below like 3k rpm, but that wouldn't matter for him. At least gasket match them and get rid of all the nasty casting marks.
#473
man your car is not even a luxury car anymore... It is gutted to death. lol
TheTLProject (12-09-2016)
#477
here ya go. pre-gutted
5 X BRAKE AND CLUTCH CLEANER 400ML,REMOVES OIL,GREASE,PAD & CLUTCH DUST SAFELY | eBay
#478
5 X BRAKE AND CLUTCH CLEANER 400ML,REMOVES OIL,GREASE,PAD & CLUTCH DUST SAFELY eBay
