This is how to run a sri!
Old Sep 1, 2009 | 09:21 PM
davewhodavedunn's Avatar
So their is alot of talk of SRI not doing anything. I live in Canada and I got a SRI for that reason. K&N Dyno's their typhoon kit as a SRI and CAI which the kit can be coverted for both. My SRI is awesome, provides alot better throttle response from the stock sluggish unit, and provides a little more power and agressive sound. To prevent the heat from entering the filtre, I installed a customer heat shield. It prevents the air that is hot from floating around at the top of the engine, and now it only sucks from the resonator tubing that is drawn from the bottom of the car.
Product is great!
Old Sep 1, 2009 | 09:45 PM
D'sNBP's Avatar
hates potatoville
Where did you get this from? I want a CAI but when it rains here it really pours so it's not a good idea for me.
Old Sep 2, 2009 | 07:59 AM
KaMLuNg's Avatar
the resonator is a maze of tubing for the air to travel from one end to the other... if you aren't going to run a full CAI, i would still remove the resonator so that so more air can be drawn in thru the fenderwell...
Old Sep 2, 2009 | 06:55 PM
Ebay sells k&n intakes at a decent price and the k & n kits can convert from a sri to a cai. The heat shield is also from ebay and works really well.
Old Sep 2, 2009 | 09:30 PM
I hate cars's Avatar
You're never going to get it. I give up. I'm sure a piece of metal near the filter is really going to knock down temps. I guarantee it did nothing.
Old Sep 2, 2009 | 09:57 PM
blue rocket's Avatar
A Happily Modded TL-S
not bad! but custom FTW!
Old Sep 2, 2009 | 10:18 PM
thats pretty sick...i hate cars, your never going to give up the "im right about everything attitude" just chill it and let me have my fun
Old Sep 2, 2009 | 10:31 PM
Have your fun but it's a total waste of money. You're changing something for the sake of change. I don't have the I'm right about everything attitude, you've just used poor judgment in nearly every post you're made. I'm not going to stand by with all the misinformation around here. It's bad for the board and for the people wanting to make extra power.
Old Sep 2, 2009 | 10:43 PM
The K&N Kit which comes as a SRI and CAI are both rated at 5.5 Horsepower. As you may think it's a hot air intake, keep in my the air from from the CAI filtre lies is as hot, if not hotter on the summer roads as it would be in the engine. In the winter also, if the filtre gets wet, it freezes...regardless, last time I check you didnt make performance parts for a living. Just because one person has a STRONG opinion on something doesnt mean they need to FORCE it on others. Im done with this nosense...
Old Sep 3, 2009 | 12:21 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
the gains you feel are from having a better flowing filter, but indeed ur still sucking in hot air... just touch this "heatshield" when you get a chance... one made of plastic would have made more sense... blue got the full and on point idea for an icebox style
Old Sep 3, 2009 | 02:16 AM
greco9885's Avatar
i hate this topic too, theres a new one every day. ill say it till i die, SRI is useless, only time i EVER see SRI's are on v8 trucks. my 5.7l jeep has one, but the filter is directly behind the grill, and its a good distance away from the engine.
on the TL its different, the battery blocks that flow...
please, give me a break. do u know how easy it is to rig dyno numbers? i can put a SRI on my car and make it dyno over 300
hes not the only person that has a strong hate for SRI, many of us do.
+100000000000000
Old Sep 3, 2009 | 07:06 AM
Dave- I have nothing against you. Just trying to save someone from making the same mistakes that I have in the past. The negatives of an SRI are well known, you're just getting into the mod world so you're not expected to know everything. It just seems like you ask for advice and then do your own thing. Nothing personal. Shortening the intake tract and putting a large cone filter will do nothing when the engine pulls only 300CFM and the stock in take tract will flow 500CFM. I don't know a nice way to say this but I'm not giving you an opinion. It is a fact.
Old Sep 3, 2009 | 07:10 AM
You may be surprised to hear that I run what you could call a SRI on the GN but there's a reason for this. I have a massive 48"x18x2 intercooler so underhood heating isn't a big concern.
In my application I need roughly 1,200+ CFM of airflow and it would've required a 6" diameter pipe after the filter to pull fresh air in. Hell, with a 9" K&N it tried to collapse the filter so I had to go with a 14". In my case the less restriction of the SRI outweighed the advantages of cooler air. On top of that, the car pulls so much air in when you hit it that I watch the inlet air drop down to ambient as if I had a CAI anyway.
So you see, I'm not close minded but I know the TL's measly 300CFM does not require a SRI and you will get much more benefit out of the factory semi-cold air intake or an aftermarket CAI.
Old Sep 3, 2009 | 07:19 AM
KN_TL's Avatar
Being in the engine bay is going to be hot, no working around that. I don't know if asphalt or concrete on a summer day is going to be hotter than your engine bay, especially while your moving.
The increase you feel is in your ears. The growl has a mind over matter affect on the brain.
Old Sep 3, 2009 | 07:38 AM
That's exactly what it is. And for the better throttle response, you're hearing the throttle open which is probably the quickest DBW throttle I've ever driven. There's still that split second delay before the engine reacts though. It's just the noise that makes it seem quicker/more responsive.
Old Sep 3, 2009 | 07:46 AM
KN_TL's Avatar
BTW, I have a CAI and I consider it a waste of +200.00 for just noise. I've also got the spacers installed, another $100 wasted.
But I was just starting out and still learning. I'm not going to get defensive just because other people are denying what some marketer is telling us should be true. People have been debating and proving that a lot of K&N claims are untrue.
Old Sep 3, 2009 | 08:02 AM
KaMLuNg's Avatar
X's a million to infinity and beyond... i was so used to the responsiveness of the TL throttle that when i bought the GS, i thought something was wrong with the car... the GS has about a 1 sec delay when going to WOT whereas i can noticable feel the TL WOT responding almost instantly...
Toyota must have improved the system tho, because the DBW in the Corolla is a bit better... but still not as good at the TL... '01 GS < '07 Corolla < '07 TL from the cars in my fleet...
Specmiata82
Sep 30, 2015 10:04 AM
NorthWestAnimal
Sep 28, 2015 06:20 PM
MikeJM310
Sep 24, 2015 07:24 PM
