High flow precat gains?
Hey guys,
I just did a mid muffler delete today on my TL.
I'm going to be getting a j-pipe next and then probably high flow cats.
Does anyone know what the gains are on high flow pre-cats and the cat after the j-pipe?
I spoke to the guy at the shop who did my muffler mod and he said I wouldn't gain much from high flow cats. I can't use the PCD's since it would fail emissions. I live in Allegheny county near pittsburgh.
I'm wondering if PCD's would pass emissions too since they would be barely visible anyway.
^you dont say what model your car is.
base cats have a cell count of 900.
type-s cats have a cell count of 600.
High flow cats have a cell count of 200-300
pcds are straight pipe so it has 0 cells.
from the base TL to high flow cats you'll be going from a 900 cell cat to a 300 cell.
pretty big improvement.
Sounds like that would be a huge difference. I will definitely be getting them then.
From what I can deduct from Justin's post, a base TL will yield the biggest improvement while PCDs for a type-s will only be a small improvement considering the type-S already has higher flowing cats than the base. Although, the Honda manufacturers decided to add to production costs by making two different sets of cats for the base and type-s and there really isn't that great of a difference in cell count so maybe a little bit does help? You would be going from 600 cells to 1 cell.
High flow cats do not, in and of themselves. add rasp. I have none.
I read a tech article a while back that said when the type s came out 6hp was gained from going to 600 cell cats from 900 on the base. This makes sense because the 4g TL has the same engine as the type s but is rated at 280 since it has 900 cell cats vs 286 in the type s with 600 cell cats. Using that logic, I bet you would get 6hp for every 300 cell you lost on your primary cats. If I come across that article again, I will post the link.
My best guess is that on a base TL you will get:
6hp going to type s cats
12hp going to HFC
18hp going to PCD
Shameless plug: If you want the most gains possible, buy my V3 RV6 PCD for sale in the Black Market
12hp going to HFC
18hp going to PCD
A Type-S will still gain heavily from the full deletes. Going from 600 cell cats to straight pipes is still a vast improvement. In theory, it's the same flow improvement as going from the stock 900 cell base cats to the 200-300 cell HFC's.
Nice thing about the HFC's is you don't have to worry about hacking into your exhaust and adding a huge resonator if the rasp gets annoying. My Excelerate cat back is the resonated version, but the resonator is so tiny I don't think it's doing much.
^just wanted to emphasize on the Variables part.
my set up does rasp, but I dont have any plans to quell the sound.
Unless, I were to get the rv6 exhaust.
also, our vee six is designed to sound ugly. lol
its just the way our motor sings!
Just an FYI, back when I had pre-cat deletes, and test pipe. My bumper turned yellow-blackish if I didnt stay on top of my weekly washes. Keep in mind I also have a white care. Im sure it doesn't show up on darker colors.
With windows down at a stop, could you distinctly smell the emissions?
Definitely. I'm not too concerned with emissions. It's not too hard to swap everything out or just swap the factory J-pipe back in. And the smell really isn't that bad. Ever go to a drag strip and smell all the uncatted cars there? Same thing.
AbyssPearlTL nailed it, but there isn't a smell with the windows up.
Thanks for clearing that up for me Inaccurate!
12hp going to HFC
18hp going to PCD
12hp going to HFC
18hp going to PCD
