Help
Old Jan 24, 2024 | 05:48 PM
Potleafpanda96's Avatar
3rd Gear
Help
I've done a 3.7 intake ported and polished, 3.7 throttle body's and some after market injectors, I have stage 2 exauhst and a street tune but I can't get over 300-315hp with out doing major work, next step is pulleys and top end work Any suggestions
07 tl base 180k auto😪
Old Jan 25, 2024 | 07:57 AM
TheSauceBoss's Avatar
This topic has been beat to death over the years, so I'll try to be as concise at possible.
You COULD upgrade every part possible. Hi flow pre cats (or delete them), nice J pipe, lightweight crank pulley, remove the interior for weight reduction, put on NICE tires, coilovers for handling if you aren't satisfied with the current suspension, a legitimately good tune from a legitimate tuner. Head work is near non-existent for the J series, as the design provides strict limitations on increasing valve lift, cam lobe height, etc. There are aftermarket cams available, but again, doing that isn't going to be some magical improvement in itself. You will likely spend more $ than what the car is worth, and also never get that same $ back, while seeing a negligible power increase overall. You have to ask yourself, is the juice worth the squeeze?
You COULD boost the car. You would see a significant power increase. You'd spend more than the car is worth, and who honestly knows what would happen to an engine and automatic transmission with 180k when you boost it. Same logic applies to supercharging, on a lesser scale.
You COULD just sell this car and get something with more power.
It all just depends on what your end goal is.
Old Jan 25, 2024 | 08:36 AM
twokexlv6coupe's Avatar
Lay off the pot, panda bear; you have delusional goals.
You won't get more than 265/270 whp with that automatic, without spending $20K.
Just buy something with an LS(X) where installing mods ACTUALLY has an effect and makes noticeable power.
Old Jan 25, 2024 | 09:45 AM
Sweetleafpanda96, this kit will work; however, it will require work.
FS: Acura TL 2004-2008 Supercharger Rotrex Stage 3 630WHP J-Series GBP Kit - AcuraZine - Acura Enthusiast Community
Old Jan 25, 2024 | 09:46 AM
3rd Gear
Mann I paid 4oo$ for this thing and am 3k deep back yard build at it finest 👌💯
Old Jan 25, 2024 | 09:49 AM
3rd Gear
Look I a paid 400$ for this thing and dumped 3k in off rip getting it running right and to where I am now right at 3-302 but can't get past it, I just 400-450 daily
Old Jan 25, 2024 | 10:02 AM
Just curious, what did you manage to spend $3k on? Was it the bolt-ons you mentioned in the original post?
Old Jan 25, 2024 | 11:55 AM
MyGuti's Avatar
lol
Old Jan 25, 2024 | 03:18 PM
Pair of TLs's Avatar
Old Jan 25, 2024 | 03:42 PM
If you think dumping "3K" is considered a lot of money, boy do I have bad news for you (mostly for your wallet) if you wanna hit 4-450 hp with an auto.
Old Jan 25, 2024 | 08:28 PM
619rcr's Avatar
Any suggestions
base & auto. Those are your two limiting factors.
Build a 3.6 & you'll have some more power. But, the slushbox won't transfer nearly as much as a manual to ground.
First step should be manual trans.
MyFirstTLca
Mar 21, 2020 07:29 PM
bmahoney91
Jul 8, 2014 08:57 PM
SRT-11
103
Dec 7, 2013 01:40 AM
dstah
Feb 21, 2013 06:20 PM
msung7
Aug 4, 2009 04:08 PM
