Getting pro cats installed in CA
Old Oct 11, 2007 | 06:44 PM
Hi speed's Avatar
runnin a little boost
Does anyone know if shops will install pro cats in California? I heard you are not allowed to mess with your cats unless they are dead?
Old Oct 11, 2007 | 07:06 PM
06 Acura TL A-Spec's Avatar
Any shops should install it. I got mine installed at a shop.
Old Oct 13, 2007 | 12:23 AM
subinf's Avatar
One on the right for me
Ask around. You aren't supposed to remove and replace them, but most shops won't care too much.
Old Oct 17, 2007 | 02:57 AM
MrHeeltoe's Avatar
Former Sponsor
Replacing the cats with something aftermarket on any OBD 2 car is straight up illegal. It may be tough finding someone good who will do it. Shadier places will do it, but then you gotta worry about them screwing something up...
Old Oct 17, 2007 | 06:23 AM
timmahh's Avatar
it's me, Alan Rickman.
.. and you void your warranty.
Old Oct 17, 2007 | 10:25 AM
lembowski's Avatar
Trucki!!
weren't pro-cats trying to get Cali carb'd at sometime?
Old Oct 17, 2007 | 03:14 PM
MrHeeltoe's Avatar
Former Sponsor
That is not going to happen any time soon. The only allowable cats to put on an OBD 2 car are OEM and rebuilt OEM, as the law currently stands.
Old Oct 17, 2007 | 03:35 PM
lembowski's Avatar
Trucki!!
ugh...
Old Oct 17, 2007 | 03:49 PM
Hi speed's Avatar
Are these bad boys going to pass smog or will I have to take them off to get the car smoged? I know visual might not pass but what about the sniffer? Also how hard is it to put these on?
Old Oct 18, 2007 | 09:54 AM
MrHeeltoe's Avatar
Former Sponsor
They would probably pass a tailpipe test. For sure they are going to be less effective for smog than oem cats, due to the lower cell count.
Marcus
Old Oct 18, 2007 | 10:11 AM
01tl4tl's Avatar
Find the import tuner shop and ask where they go
With the normally Ultra Low emissions of the TL- we have a little room on the test
Old Oct 18, 2007 | 01:40 PM
Excelerate's Avatar
Former Sponsor
In CA, any replacement of a perfectly working cat is illegal and it has to be replaced with an OE replacement. You will likely pass the tail pipe test but you will fail visual inspection.
You will be fine in most other states. Some states will require you to prove why you needed to replace the cat so prepare to show how it is defective although I've yet to see someone ask for that info.
Onyxthecat
Oct 18, 2016 02:05 PM
NJALLDAY57
Oct 13, 2015 08:25 AM
IIDXholic
Oct 8, 2015 07:53 AM
