Field's Vtec Controller
Old Aug 4, 2010 | 02:15 PM
Drew408's Avatar
Do they still make these and if so, for the TL? If not, what type of Vtec controllers are you guys using these days? Apexi?
Old Aug 4, 2010 | 02:29 PM
Drew, I dont think any one is using a Vtec controller for the TL.
Originally Posted by 01tl4tl
why do you need vtec to come on any earlier?
Its set on the spot where torque is about to jump up!
Originally Posted by stillhere153
if you lower the vtec range on a stock untouched motor you will actually result in a brief delay in rpms... try it out, you'll see
go to: boomslang.us
have them make a harness for the controller of your choice (if you need a vafc I know someone who has one for cheap)
remove the lower intake resonator box- and install a K&N air filter
Thats a decent first mod for better vtec performance
Originally Posted by xoulu
so hmmmmmm this intresting.... what if i got a vtech controller, and lower my vtech to kick in at 25000rpm.... is that a good idea?
Originally Posted by csmeance
I think you would have had pistons going though your hood at around 8K... if you could get it to 25K you'd be floating away either up or down.
Joking aside, if you are going to just drop vtec to 2500, why not just buy a set of aggressive cams and eliminate vtec completely. That way you will always have that aggressive setting that vtec provides.
Vtec at 4k is best imo anything lower won't do much
Old Aug 4, 2010 | 09:47 PM
AtlM5's Avatar
Im pretty sure some of the SC guys run Vtec at 4k
Old Aug 4, 2010 | 10:10 PM
phee's Avatar
I got the Shifts
thats because their engines can take advantage of the extra lope due to the extra air being forced in.
Old Aug 5, 2010 | 02:04 AM
RonJonTL757's Avatar
Former Whyner
The ACM provided by CT-E does this automatically
Old Aug 5, 2010 | 10:55 AM
KN_TL's Avatar
Consensus has always been that the vtec engagement point is optimal unless you are artificially inseminating your ride.
Old Aug 5, 2010 | 03:37 PM
NCTL05's Avatar
Middle Finger anyone?
Old Aug 11, 2010 | 11:37 PM
08TLEE's Avatar
^^^ I'm with that guy...
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
Brandle34
Sep 23, 2015 07:20 PM
