Factory IM Spacer - 17108-RDJ-A00
Old 06-10-2009, 11:07 AM
  #201
practicing nihilist
NedShneebly's Avatar
Just ordered from Acura Carland. $50 shipped for spacer and bolts but I paid for 2Day since I'm heading to the track next week. I'm going to use P2R and stock spacer like ACU-RATE did.
I don't use the plastic covers. Will I need hood spacers anyway?
Old 06-10-2009, 11:18 AM
  #202
gerzand's Avatar
yes and good luck getting the bolts that noone else can manage to get from acura.
Old 06-10-2009, 11:23 AM
  #203
practicing nihilist
yeah, I'm going to eyeball the order status and if it stalls for the bolts, I'll just have them send the spacer and find what I need at Pep Boys, Napa or Tractor Supply.
Old 06-10-2009, 11:28 AM
  #204
Real Cars Have 3 Pedals
ACU-RATE's Avatar
Originally Posted by Dave_B
Better than I thought for sure. My question is are the runs posted the best before and after runs? Did you do just one dyno for before and after? The reason I ask is that many cars will show about a 5whp difference between runs with no changes to the car.
I'm still very impressed by the TL-S 6MT whp/wtq numbers. I can't figure out why these cars aren't going significantly faster (ie MPH) in the 1/4 mile. From what I've seen, typically modded TL-S are doing 99-101mph. I would think it would be more like 104mph.
The B4 dyno was 280 whp & 246 wtq (at best after 3 runs) w/o the manifold at best.....done back in APR 09
&.....281 whp & 254 wtq after 3 runs with the IM SPACER
As far as 1/4 mile.....These cars a heavy FWD Luxury vehicles....They were not build for 1/4 mile......AT ALL
BUT....if you wana talk straight up highway runs from a roll...thats a diff. story....
Old 06-10-2009, 11:41 AM
  #205
practicing nihilist
added the 2 long studs to my order and looks like the other studs are definitely on back order like everyones saying.
you think these can be found at one of the big auto parts stores...the 7 primary bolts?
Old 06-10-2009, 11:47 AM
  #206
gerzand's Avatar
the longest any big name store carried when i checked both online and in store was 70mm in length. we need 105.
Do yourself a favor and just order them from BMW. I posted the part # in my picture post.
Old 06-10-2009, 11:51 AM
  #207
ACU-RATE's Avatar
I found some at LOWE's that work for my install....(7 primary bolts)
Hillman
Hex Cap Screws
Grade 5 USS
5/16-18 x 4
UPC code (Bar code):
0-0823670418-1
i paid $0.92 ea.
Old 06-10-2009, 11:54 AM
  #208
gerzand's Avatar
Hillman
Hex Cap Screws
Grade 5 USS
5/16-18 x 4
0-0823670418-1
i paid $0.92 ea.
I tried out that thread pitch on a 5/16th bolt, and you are definitely risking it mixing Standard with Metric. Just a fair warning - stick with M8 1.25's. Cross threading is not fun.
Old 06-10-2009, 11:58 AM
  #209
ACU-RATE's Avatar
UR right...But thats what i used...& i bolted down fine.....
Im not TELLING anyone to go my route...Im just sharing what i use/did ....
Old 06-10-2009, 12:01 PM
  #210
gerzand's Avatar
Fair enough.
Old 06-10-2009, 12:13 PM
  #211
practicing nihilist
so that's M8 Hex Cap, 1.25 mm? The metric bolt system alway confuses the shit out of me and I'm prone to stripping holes, which I haven't done yet on this car with all the digging in the engine and I don't want to start.
anyone remember the torque spec on these? I think it was in the P2R threads.
Old 06-10-2009, 12:15 PM
  #212
Under construction
alexSU's Avatar
would this mod help my tq numbers, even though im all stock?
Old 06-10-2009, 12:21 PM
  #213
gerzand's Avatar
They are M8x105mmx1.25pitch (standard to M8, unless u get a special narrow pitch of 1.00).
Tq specs are 16 lb/ft
Old 06-10-2009, 01:19 PM
  #214
anx1300c's Avatar
We all know and understand that. It still doesn't explain why they don't seem to trap where they should. FWD limits the elapsed time of a car, not the trap speed. Good numbers though.
Old 06-10-2009, 03:31 PM
  #215
Dave_B's Avatar
If the TL-S was truely a topend car, you'd see evidence of it in the trap speed. I'd expect to see things like 14.0@104mph. That would tell me the motor's powerband is more focused on the higher end and/or the gearing is tall. Both would make the car a bit sluggish from 0-40mph and then the car would really start moving. Instead, I see a motor with a very solid powerband and appropiate gearing for any mph. The times I've seen posted make sense for a car exhibiting these characteristics (ie lower 14s in the 100ish range). I just can't figure out why this 3,600lb car isn't going faster with 280-290whp. 3,600lb 07-08 G35 sedans are going 13.6-13.8@103-104mph with 260-270whp. I haven't seen anyone post up a third party run of a G37 sedan, but I'd expect it to be in the 13.5@104mph range since it makes about 280whp.
Old 06-10-2009, 07:45 PM
  #216
ACU-RATE's Avatar
THIS THREAD IS ABOUT IM SPACER!
PLease don't turn this into a RACING thread...there is a section for that.....
Old 06-10-2009, 07:49 PM
  #217
anx1300c's Avatar
But have you seen any fully bolted TL-S 6MT's run at the track? I mean I ran 99.5 mph on my only full QM run and I'm sure I can break 100 next time out. I'm probably making upper 240's at the wheels which puts me right where a stock Type S 6MT is. I really wish more of these guys with bolted cars would at least make one trip to the track for some empirical data anyway.
Old 06-10-2009, 08:03 PM
  #218
Middle Finger anyone?
NCTL05's Avatar
1. I stalled that dotted is before the IM SPACER.
2. No....I'm running rich....I need a tune, BAD! ...it would have so much more potential with a tune...
So why on earth would it be running rich like that? Was it like that before the spacer or did it happen after you put it on?
Your engine won't blow up anytime soon, but your mpg's must be lower than average.
Old 06-10-2009, 08:13 PM
  #219
Bored at work
tl2slow's Avatar
ok so i tried it out and boy what a difference.... i felt alot more torque in the lower rpm range.. top end was about the same... ok now for the bad...the hood didnt close and i didnt want to put spacers.. i had to stretch some hoses and some wiring... and the vacuum port for the brake booster was hitting the strut bar...i took it back off and plan to take it to a machine shop to get it milled 1/2"...i took some pics ....
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 06-10-2009, 08:33 PM
  #220
practicing nihilist
hmm, not exactly plug and play then. Are you saying you need to trim some fat off the brake booster? Can this be done with a bench grinder, ya think? So, you stretched some of the electrical leads but they fit, right?
I was gonna pick up some washers at the parts store anticipating I would need them.
Very stoked about this. My engines about as open as an NA can be and that means my low end is almost non-existent.
Old 06-10-2009, 09:09 PM
  #221
gerzand's Avatar
tl2slow....did you connect the Fujita CAI yet? I was worried about the P2R TB spacer causing an issue. Let me know, thanks.
Old 06-10-2009, 09:16 PM
  #222
Bored at work
tl2slow's Avatar
i didn't keep it on...i took off the spacer...am going to get it milled 1/2".... but yes i had everything on.. i just had to modify the bracket a little to make the intake fit..... how are you other guys running this spacer if the hood dosent close right...you would need spacers for the p/s and d/s hinges and need to modify the hood lock..you guys have any pics...i don't about you guys but i don't want my tl looking like a civic
Old 06-10-2009, 09:35 PM
  #223
practicing nihilist
ACU-RATE (or was it gerzand) said he just used the 2mm spacers on the hood hinges. I would think as you lifted the rear of the hood it would dip the front enough to catch the latch.
Old 06-10-2009, 11:43 PM
  #224
gerzand's Avatar
geeze guys, most all info is posted already. As said before, I raised the hood latch (its adjustable FYI) and used 2mm washers under both hinges. I didnt use a n IM p2r gasket tho, so you guys will probably have a more challenging time. You can always hammer down the hood support rails if need be.
And my car looks totally stock from the outside, no noticable gaps... though every car is goona be a small bit different on your hood/fender alignment.
good luck.
Old 06-11-2009, 03:47 AM
  #225
beachexotic03's Avatar
[IMG]http://img10.imageshack.us/img10/4347/021cpd.jpg[/IMG
If you port the runners bolt down your gasket and use a sharpy and trace where extra Gasket is so you can cut it for a nice even flow.
Old 06-11-2009, 10:35 AM
  #226
94 DC4 RS LSV/Turbo
stillhere153's Avatar
^ i sent you my email... no fair... thats for the ported guys
dang dude you mod crazy I can't wait to edit your vids
Old 06-11-2009, 12:36 PM
  #227
Ryan Christopher
Black_05_TL_6SP's Avatar
Im posting these up in a rush but will be back later with details. One of the pics below is of a BMW Part # for the (7) M8x105 bolts you will need! $3.33 a piece from my local BMW and are used in the 1994-1999 320i. They are out of stock from acura nationwide as had been mentioned....So I did my own hunting Glad to share!
Called my local BMW dealer and they stock the part. They only have 4 in stock but can order more in. $3.43 a bolt.
Old 06-11-2009, 12:38 PM
  #228
Ryan Christopher
Probably would not be as bad if you didn't have the thermal gasket in there. I am going to look into the option of milling it down as well, just to keep enough hood clearance.
Old 06-11-2009, 12:52 PM
  #229
gerzand's Avatar
I realized that my slight increased "engine vibration" i was feeling at idle was actually do to resonance through the car caused by the same VSV sensor as mentioned, rubbing on my RV6 strut bar. But it wasnt anything a quick relocation of the sensor couldn't resolve!
Old 06-11-2009, 12:54 PM
  #230
gerzand's Avatar
Cool. They work great. Worth the $23/24.
EDIT: Pick up 7 M8 lock washers from the store while your at it.
Old 06-11-2009, 05:22 PM
  #231
94 DC4 RS LSV/Turbo
Just got to read the full threads
My apologies for listing some partially misguided info...
But yes looking at acc's dyno sheet... Its just how I suspected... Tq ftw... Now no one can say that they're loosing tq from this and that if you get it back for under $50
Cheap mods ftw... Glad my no longer tl driving ass could help
Old 06-11-2009, 08:27 PM
  #232
practicing nihilist
man, I've never seen lock washers used on intake studs. not saying it shouldn't be done, but do you think it's necessary.
Old 06-11-2009, 08:43 PM
  #233
gerzand's Avatar
only cuz they r hex heads.... playing it safe bro
Old 06-12-2009, 09:41 AM
  #234
ACU-RATE's Avatar
Good FIND !!!!
I give U ALL the CREDIT for it !!!
:gheywave:
Old 06-12-2009, 04:05 PM
  #235
practicing nihilist
well, I drove all over the city today and all I could scrape together was 100mm bolts. I have the 2 long studs coming with the spacer. Looks like about a 1/4" difference between 105mm and 100mm. Do you think this will be OK?
I'm only rushing this a bit because I'm hitting the track Wednesday night.
Old 06-13-2009, 10:38 AM
  #236
Former Whyner
RonJonTL757's Avatar
Caller my local Bimmer sport and they had seven of those bolts on hand $3.44 but cant pick up till monday cuz of my friggn work schedule today.
Called an Ack dealer and they have to order the gasket on monday and they have it listed for $29.33. I checked Delray and they have it for 21 ish but it will be 30 w/shipping so ill just get it local.
Im kinda stumped or missed something in the thread about the 2 studs. I heard that the part AL gave was the same size as stock so should I run without or can I get them somewhere else??
Old 06-13-2009, 11:16 AM
  #237
You need 9 bolts forget the studs
Old 06-13-2009, 11:35 AM
  #238
Former Whyner
Not doubting you but who has done that? I just dont remember reading that anywhere.
Why didnt they just put 9 from factory
Old 06-13-2009, 01:36 PM
  #239
MY KBP IS BTR THN URS...
OneWickedTypeS's Avatar
Would'nt running all bolts be kinda how the throttle body spacer is mounted to.
U remove the 2 studs and 2 bolts and replace with 4 longer bolts...
Old 06-13-2009, 02:00 PM
  #240
Former Whyner
Guess so o well I was just worried about the hole diameter being the same.
Quick Reply: Factory IM Spacer - 17108-RDJ-A00
