Engine Port & Polish, new Valves
Old 05-17-2007, 10:29 PM
  #161
3rdGenHybrid's Avatar
take it back to the shop....if you lived aroudn my way....i'd do it for you....buy im not driving 2000miles for that....
Old 05-18-2007, 07:51 PM
  #162
.43g at 900+fps
jdmspec333's Avatar
i got my heads back from the machine shop and i got the lift specs for the cams
05 tl
low- .249
mid- .208
high- .249
07 tl-s
low- .251
mid- .208
high- .253
hope this helps. i couldn't get the duration of the cams. sorry. but judging from the looks of these numbers, the tl-s cams are a def plus.
Old 05-18-2007, 10:07 PM
  #163
313.4WHP& 284.6TQ
mmcv6's Avatar
ussi-
Take it back to the shop who did the install/machine work etc. They should fix it.
If they wont bring it to C&C auto the place I go to. They will fix it for you 100% with a fair price...
cool
Old 05-18-2007, 10:24 PM
  #164
I have car ADD
BLACKURA_NY's Avatar
describe the noise better..... like, a grinding sound if a wheel and caliber are rubbing? outta curiousity, did you happen to change your timing belt to an 07TL-S ? or are they the same
Old 05-19-2007, 02:44 PM
  #165
what are u measure low mid high? i just wanna know Intake's lobes, Vtec's lobe, and exhaust's lobe's measurements....lift and duration would be great...
Old 05-19-2007, 02:45 PM
  #166
o...btw...how did u like your intake spacers? debating on getting them...
Old 05-20-2007, 08:18 PM
  #167
I (don't) whine.
ussi's Avatar
it actually sounds alot like my calibers are rubbing... the noise is elevated and you can hear it speed up as my RPMs rise. could it be my cams? the noise is nonexistant when car is idleing...
i kept the same timing belt.
hard to tell the exact benefit since i did so many things at once, but everyone seems to agree that for a $100 they are worth it.
Old 05-20-2007, 10:15 PM
  #168
I have car ADD
the thermoblocks are ok. i just got them 2 weeks ago. a lil more low end power. they say it makes the car better on hot days (heat soak), i think its better on cold days because it keeps the engine even cooler, when its already cool. cooling it down while its hot, doesnt do that much IMO.
worth $100... eh i guess. i just think we are all desperate to make our cars faster! lol
Old 05-20-2007, 10:16 PM
  #169
I have car ADD
be the way, ussi. do u think u should have changed the timing belt? or are they the same belts for TL & TLS.
Old 05-21-2007, 05:53 PM
  #170
i think ill try those intake spacers....did you ever get that noise fixed though?
Old 05-21-2007, 06:51 PM
  #171
I (don't) whine.
ussi's Avatar
I didn't even to think to change the timing belt till you mentioned it actually...i'll look into the part numbers. I'm sure they are different because the cams and crank are different on the Type-S.
I haven't had a chance to take it in, I just put in a dynomax resonator because my car was just too loud, and after the ProCats I was getting a nasty rasp, sounds great now. I plan to take my car in to the mechanic tomorrow or wednesday, then dyno'd next week.
Old 05-21-2007, 10:50 PM
  #172
I (don't) whine.
ussi's Avatar
05 tl
low- .249
mid- .208
high- .249
07 tl-s
low- .251
mid- .208
high- .253
that little lift change will make a big difference?
Old 05-22-2007, 07:23 PM
  #173
Spent
grossman42x's Avatar
how much would it cost to fix bent valves
Old 05-22-2007, 07:29 PM
  #174
I (don't) whine.
ussi's Avatar
^^Cost to remove heads + machine shop labor + parts (new head set, valves) = $2000
Old 05-22-2007, 11:16 PM
  #175
.43g at 900+fps
jdmspec333's Avatar
it'll make a difference, how much is really unknown without the duration spec. but i'm almost positive that it's all around a better camshaft. like ctr cams vs. gsr cams or even itr cams. ctrs are arguably the best camshaft for a dohc vtec. i'm confident i made the right choice with the tl-s cams...
Old 05-22-2007, 11:57 PM
  #176
I (don't) whine.
ussi's Avatar
jdmspec, have you installed them yet?
Old 05-23-2007, 01:21 PM
  #177
.43g at 900+fps
jdmspec333's Avatar
yeah it's in. oh and i don't know if i mentioned this before, the tb service may disrupt the vsa system. not like i care i normally turn it off when i drive...
Old 05-23-2007, 04:56 PM
  #178
I have car ADD
BTW. same timing belt for all 3g applications (06 base vs 07 type s) i dont think 04 base should be different from 06 base
Old 05-23-2007, 09:16 PM
  #179
I (don't) whine.
ussi's Avatar
fuck CEL just came on the way back home today
I'll try to take my car in tomorrow to mechanic...
otherwise my car is running stock...i have alot more top end power...
Old 05-23-2007, 11:36 PM
  #180
I have car ADD
i think for those of us who fck with our cars enough ,we should just do a group buy for those lil computers to see what CEL's are about. lol
Old 05-24-2007, 12:51 AM
  #181
I (don't) whine.
ussi's Avatar
Ok, so that noise i was talking about earlier which i was having trouble describing is coming from my blower...it sounds like one of the "screws" in the is either off balance of is making contact with the other "screw". I hope its not as what i make it sound like because my car is running great..boost is good etc.. but the sound is still coming from the blower...but i guess with comptech back in the picture...warranty??
Still don't know what the CEL is about but i hope its something stupid like the cats or something...
Old 05-29-2007, 08:22 PM
  #182
ThinJim's Avatar
Not to hijack your thread, but thought this might interest you guys that are into the hp chase. I've been working on and will be for a while, a special motor. I'm at the head stage and will pick them up next week. In the meantime, the head shop that did the work has sent me a before and after flow chart. The heads now have a custom 1mm oversized intake and exhaust valves, Ferrea springs, bronze guides and are fully ported. Enjoy this expensive bit of info and please, no questions on "how much did it cost". If you have to ask, you quite possibly couldn't afford it. Any engineers care to chime in?
Old 05-29-2007, 11:20 PM
  #183
'10 Hyundai Genesis Coupe
Eoanou's Avatar
Keep us posted man, sorry to hear the blower is making the noise, but I suppose it could have been worse? I don't know I could be wrong...
Old 06-06-2007, 11:45 AM
  #184
ThinJim's Avatar
any updates. you did use the '07 tls cams, right? did you do any flow number comparisions of before and after the port job?
Old 06-06-2007, 07:52 PM
  #185
I (don't) whine.
ussi's Avatar
I used the TLS cams. The shittiest thing happened..the day before i went to pick up my head from the shop, my palm 700 got stolen out of my rental. I was PIST and forgot to tell them flow comparison.
i really need to make time for a dyno, since i did so many mods simultaneously it will be hard to know which mod is really worth doing, but the dyno should give a better idea.
other than that the car drives great, i've just started to beat up on it a bit now that my belt problem is gone.
Old 06-06-2007, 09:51 PM
  #186
ThinJim's Avatar
I was curious about your before and after numbers on the flow. these heads are peculiar. I'm picking up my heads tomorrow. They're different than yours as the exhaust manifold is cast into yours and not mine, other than that, they're basically the same. They replaced both intake and exhaust valves with a 1mm larger size, bronze guides, new seats, springs and retainers and port and polish. bummer about the palm.
Old 06-06-2007, 10:55 PM
  #187
I have car ADD
so i have been seriously following this thread since the beginning.... and i need to do some work to my motor this month....
overall, i know you did alot at once, but do you feel a serious difference? are you confident is some really high #'s from this?? are you happy for the time and money you spent on this?
I have been thinking about getting the cams, port & polishing it. I figured if hondata or comptech officially release an ECU for us, some larger injectors and bored fuel rails will show some positive results....
i dont think we can wait any longer for you to get a dyno!!!
i've got $20 bucks on it, anybody else?? lol
Old 06-07-2007, 03:23 AM
  #188
I (don't) whine.
ussi's Avatar
i wish i had done it too. I assume my head flow numbers would be similar to yours since we did about the same to them, except my intake valves are stock, i really wish i had just changed them out also, its just the advice i got was it wouldn't make much of a difference, but seeing that they are larger on the new Type-S, I shoulda just forked over a lil more cash for them. Did you find oem valves that fit or did you get aftermarket ones?
If you have you're before an after numbers, please post em, i'd love to see what kind of increase you're getting.
Old 06-07-2007, 03:30 AM
  #189
I (don't) whine.
ussi's Avatar
haha ok ok, i'll call the shop and see when they have time.. i was just waiting on something
just paypal the $20 over
yeah, i DEFINITELY felt the difference. as big a difference as when i put on my blower, no way. But my car pulls really hard in high rpms, problem is i really lose traction in first and second at 6k rpms. I've just now started to really push my car cuz i was cautious when i initially got my car back, and belts kept tearing, now the fun begins.
once i get it to the dyno you can look at the dyno #'s and decide if its worth it. although your gains will be different on a N/A motor, but it will help you decide, just get a good mechanic that will do the head job for a good price.
Old 06-24-2008, 05:00 PM
  #190
I got the Shifts
phee's Avatar
update?
Old 09-28-2008, 10:38 AM
  #191
CLS6SpeedNupe's Avatar
bump
BoricuaTL
04-08-2016 01:08 PM
sockr1
10-01-2015 01:31 AM
09-17-2015 08:57 PM
michaellong77
1G CL Problems & Fixes
09-11-2015 12:54 AM
Papa Roe
4G TL Problems & Fixes
09-01-2015 09:41 PM
Quick Reply: Engine Port & Polish, new Valves
