E-shift Procats?
^ Are these things still around? You're talkin' about hiflow replacements for the two main cats that come straight out of the head right? I thought these things were no good. Didn't some guy with a V6 Accord get the element in the cats turned into brittle cakes? Or are you talkin' about something else?
well, no wonder I have not heard about them in a long time. I am just thinking of more performance mods
And yes I believe it is the type-s engine, just tuned much differently
CTS-V Import Slayer
The E-Shift cats were not ULEV rated cats...which tend to run hotter than LEV cats....which is what I believe those cats were rated at. Therefore....they have a tendency to burn up prematurely. Did they make more power....yes. But given there are precat deletes and third cat delete solutions out there now....I would highly recommend going that route.
If someone develops a high flow ULEV rated cat (I think you could insert TYPE-S cats here possibly as a mid-level solution as they are higher flowing than non type s cats in previous years and are ULEV rated) then this would then be a good option for the enviro-consc people. Fact is...if there is a good solution...we should all probably be running cats. But for my purposes...they just got in the way. But I dont daily my car that often either...could....but its not as comfortable as some other options I have.
zaino'd
When you think about it, a Magnaflow high flow cat can be purchased brand new for ~$100+... weld on some additional piping/flanges, O2 sensor holes and voila!
Obviously its more complicated than that but $1000??
I'm running Type-S precats after RV6 deletes... love it.
Shawn, have any RL owners tested the RV6 deletes? I'm guessing they won't fit ...
Ryan Christopher
They have worked well for me. Then again, I have been N/A the whole time.
BUT i read in a thread where someone said that the E-shift pro-cats from the TL-S and it would fit....so
Former Whyner
I just installed my USED E-shift procats last weekend with the ATLP j-pipe and test pipe the power and tone (stock exhaust) is unbelievable!! Not sure how many miles were in them before but the element inside looked great. Im sure they will last... until I finally get a SC then we'll see.
Green Machine
Believe or not, I am still running my E-Shift cats. And they were one of the first ones. Over 30k on them. Given I live in a warmer climate, therefore they do not have to fire as hot at start. I am going to pull the third cat at some point this summer to see if there are any pieces from the upper cats.
Same here; I only have the Eshift cats in (no third). I did get residues from the precats when I changed out the j-pipe, but no issues in operate yet.
So your two main cats are Type-S cats? Can you "feel" the difference? I'm sure there would be a little since they are 'better' flow. But I'm just asking since you seem to have them in. Or are you running just running the precat deletes and straight piped all the way through?
Man of God.....
So what are you saying? That my Eshift cats will break down early? If so, what does this do to the 3rd cat? Does it get damaged as well? Or do the Eshift cats just kinda dump out their guts. Without hurting my 3rd cat?
__________________________________________________ _
If they go bad, aren't they just like the straight pipe, same as the precats deletes?
I don't think I will do anything yet.......
94 DC4 RS LSV/Turbo
Ok let's let the azine official fitment guru get in on this discussion
According to my part # crossreference
The following all have the same cats
Every single V6 honda from 03+ (this of course is 03to08)
Sooooo
To answer your question, get a pair of richie precat deletes
Then pm me when you ready to install em I'll throw em on for buck fitty
If anyone has any questions regarding installing these hit me up, I have the install in my head and can walk you through it with my eyes closed
Not to mention last night/this morning I just did an install on an 04 NYC car (rust ftl)...
Ps. I fucking dare you to throw these on an RL... Easily 20hp
In conclusion I've never seen the procats fail, and I ran them for 5k...
Sooooo
Former Whyner
94 DC4 RS LSV/Turbo
Yea man Alex (infamouslink) aka the games 's cousin came thru, I think its macinthebackoftheac is his sn...
You wouldn't believe how bad the rear cat was rusted... It got to the point where james' went and got the retractable saw and we saw'd off the heatshield... Shit worked....
Oh my god.. And how could I forget, he got some suspsion work done and they had put an impact gun to the 6 12mm holding the strutbar... Let's just say his strutbar is nothing but a hood ornament now... We saw'd that bitch off too
I shoulda snapped a pic...fawk
@04AccordCPE... THAT's the picture that ALWAYS comes to mine when I hear/see Eshift procats.
Sooooo
Sooooo
you bet I will be hitting you up and testing out fitment on this "project car"
will love to give something new to the RL owners. I wouldn't get no rasp right
CTS-V Import Slayer
The basic rule of thumb on E-Shift pro cats seems to be...
If you are running NA they will hold up for quite a while. I am guessing prob over 60-80,000 miles.
If you are running SC they will quickly burn out in short order. Within 10-15,000 likely if not sooner, depending on your driving habits and climate.
Man of God.....
So what am I invisible or what????
No one has the time to answer even one of my questions???
I (don't) whine.
^Your eshifts won't necessarily break down early even with a S/C, and either way your 3rd cat is safe. I've had my procats for 1.5 years blown and are just fine. I think it just depends on what batch you got. IF they do go bad and you decide to gut them they are not as good as the straightpipe bc the airflow is impeded because of the larger diameter of the procats vs. the cat deletes.
Green Machine
They are going to be hi flow cats. If you already have the cats, it won't hurt to install. Trust me, after the install you won't care.
horny =
And a 300hp dyno 286 is the best I pulled @45% humidity and 95 degrees
I need to stop being lazy...
Green Machine
well I bought them used in good shape but just been lacking installing them... planning on taking the car to the shop and getting my meth injection kit, procats, painting the roof, repainting the grill and relocating the battery to the trunk bc of the sc....
