Dyno Is In!!!!
Dyno Is In!!!!
well folks, the dyno was performed this morning. i am pretty satisfied. i will post the chart when i get home. i am actually at work today.
BASELINE:
HP = 208
TQ = 195
AEM CAI + CT Catback:
HP = 230
TQ = 212
not bad...
BASELINE:
HP = 208
TQ = 195
HP = 230
TQ = 212
not bad...
i believe my baseline might also have been questionable.
it was somewhat low for a 6MT.
let us say that the average whp on a 6MT is 215.
with today's numbers, it actually sounds more acceptable.
either way, i am very happy with the results.
by the way, i went to TT Performance in Clifton, NJ.
they had a dyno day today. $50 gave you up to 4 pulls which includes A/F ratio.
they told me that my car was running lean. i guess if i get it programmed at the right mixture the car will produce better numbers.
stay tuned....
stay tuned....
http://www.ttperformance.net/
TT Performance Parts Inc.
160 Huron Ave.
Clifton, NJ 07013
Tel: 973-340-4069
Fax: 973-340-4743
160 Huron Ave.
Clifton, NJ 07013
Tel: 973-340-4069
Fax: 973-340-4743
Originally Posted by NFLblitze1
theyll make you a catback exhaust for 150? that seems a bit cheap
Originally Posted by 3PUTT
that price is just to install the new one and removing the old one. it does not mean they will be making you one.
Sorry but what is a CT catback?? Those are pretty impressive #'s!!
stay tuned....
stay tuned....
Also how are you going to get your car smoged when it comes time?
I don't think the CAI or the cat back is smog legal but I could be wrong. If it was legal I would love to get all that stuff.
Very nice numbers and keep up the good work. Peace.
stay tuned....
stay tuned....
Well now I have to ask. Why is the baseline not on the Dyno chart?? It's not valid without having the baseline on the chart, or at least some other dyno chart.
Originally Posted by Donte99TL
Ya it would get better but the only problem is you can't program our ecu. Do you know of any body that can?
Im not sure we have any CARB numbers yet for the CAI but the exhaust is smog legal because you don't remove any of the catalytic converters. I have the K&N cold air intake and I have to take it off before smog (or just get a different carb number from K&N) but my exhaust is legal....no problems there.
Originally Posted by Pro Stock John
Looks good. I would not want the AF any leaner than that but other than that it looks great. 208fwhp base sounds reasonable, and 230-232fwhp with those two boltons is excellent.
do you think the comptech high volume/high pressure fuel pump will help my A/F ratio?
http://www.comptechusa.com/store/360010.html
also, some people have sent me PM requesting for my baseline chart. here is the thread from weeks ago:
https://acurazine.com/forums/ramblings-12/fuckd-up-tidal-wave-kansas-112685/
Leaner mix would mean that not enough fuel is being applied to the combustion mix. Its a bit hard to believe but this actually causes increase in engine temperatures, as well as exhaust gases, which in turn heats up exhuast piping, primarily the cats. More fuel in the mix would generate more power and keep things cooler.
true, i replaced a cat on a car today that was running lean...too much heat destoryed the other one.
Yeah but too much fuel is also not a good thing. If you run too rich then you can destroy your O2 sensors, cats and get a build-up of carbon deposits in the engine etc.. Also you can actually get more HP from lean conditions but at a price ie. blown rings/seals, bad catylitic converters (if you have any), and holes in your block/pistons etc.. I learned all this from owning a turbo'd car and hanging around people mainly with turbo'd vehicles. Temp changes can even effect how your car is running either lean or rich. Highly modded cars are fun to drive but a pain in the ass to maintain from my experiences.
i saw that magnaflow sells them. anyone else?
any recommendations for a replacement performance cat for the 3G TL?
Ok, now if u calculate the wheel horsepower/torque that he got post mods to CRANK power that equates to around 298hp and 258tq. Thats RL territory!!!! Even if these dynos are slightly on the generous side, its still a remarkable increase for around or less then $1500. I personally think that this is more than enough power.
i actually spent under $1200 for both CAI and Catback.
i haven't driven the car in over a week since it has been at the body shop getting painted. someone keyed my hood over the winter. WDP is a delicate paint to blend.
3putt, thats funny, because my car got keyed too. Almost $4000 worth. I have the injen and r planing on buying the comptech catback, and thats it for power mods, 3 to 4 hp gain w/ elect. stabalizers, if any, no thanx. Now just want some handling and ext. mods. I got a SSM 6speed, the only way to go if U really like driving cars. lip spoiler, silver oem 18's w/ 245/45/18 michelins. Yellow PIAA fogs from japan. now for the near future, will get a-spec susp, tint, catback, and whatever else might come out, its been almost 2 years since the new TL came out, but not much out there, my last car was a VW R32, and for that car theres a ton of stuff.
thanks!!!
Originally Posted by pepsiman
can you please post base dyno graph
https://acurazine.com/forums/showthread.php?t=112685
BASELINE:
HP = 208
TQ = 195
HP = 230
TQ = 212
not bad...
BASELINE:
HP = 208
TQ = 195
HP = 230
TQ = 212
not bad...
I MUST HAVE WED MOTOR BECAUSE I MADE 233.9WHP WITH JUST A DROPIN K+N MY DYNO WAS POSTED LAST YEAR!!! 3PUTT THAT IS A 6 SPEED? LOOKS LIKE AUTO TRANNY NUMBERS TO ME ANY WAY GOOD GAINS FOR THOSE BOLT ONS. I JUST GOT ANOTHER FREAK FROM THE FACTORY
Turbo Magazine Dyno Dash Comparison Chart of 350Z...Clayton is much higher!!!! See
www.turbomagazine.com/tech/0306tur_dynodash/
Dyno HP TQ
Dynapack 249.4 242.8
DTS 257.6 556.5*
Dynojet (Win) 235.8 227.8
Dynojet (DOS) 243.7 237.2
Clayton 265.7 240.6
Super Flow 228.9 226.6
Ford Ranger Aug '04 issue of SCC
Dynapack @ A'PEXi - 157hp/179lb-ft
Dynamic Test Sytems @ XS Engineering - 155hp/181lb-ft
Maha @ AMS - 105hp/120lb-ft
Dyno Dynamics @ Vishnu - 102hp/142lb-ft
Dynojet @ HKS - 152hp/193lb-ft
Dynojet @ K&N - 156hp/196lb-ft
