Dohc
Originally Posted by IlovemyAcura
so this is a SOHC
In a sohc, the cam is on top of the head and is directly actuating the valves, both the intake and the exhaust. A DOHC has a cam for the intake valves, and one for the exhaust valves.
A good way to think about it is if you've ever seen a SOHC honda civic motor. It only has one head and one cam. Makes sense, right? Think of our motor as 2 of them in a V configuration, with one cylinder chopped off of each head.
It's more complicated than that, and a lot more efficient, but that's a good way to think about it.
A SOHC motor with 1 head will have 1 cam, while a SOHC motor with 2 heads will have 2 cams.
A DOHC motor with 1 head will have 2 cams, while a DOHC motor with 2 heads will have 4 cams.
Now, think about how GM is going to have a Dual cam-in-block V8. Not sure if they are still pursuing it, but they thought about it.
13.2@ 107 on Street tires
so this is a SOHC
gavriil
07-31-2007 06:16 PM
