DIY turbo idea for cheap? LOL
Old 03-07-2016, 05:28 PM
  #321
6spd-GERCO's Avatar
https://www.techflex.com/land_hitemp.asp
TechFlex will have what you are looking for
Old 03-07-2016, 06:31 PM
  #322
thisaznboi88's Avatar
You are the man!!
Old 03-09-2016, 05:41 PM
  #323
7th Gear
JacobT's Avatar
So are there no turbo manifolds sold right now? are all of them custom made?
Old 03-09-2016, 06:37 PM
  #324
runnin a little boost
Hi speed's Avatar
Not for the TL. Although he is not doing a TL build since he has an Accord. Very similar build.
Old 03-09-2016, 07:05 PM
  #325
7th Gear
JacobT's Avatar
For making a custom manifold do you think it would be easier to chop up some oem precats? or buy a flange like this and go from there?
https://www.heeltoeauto.com/p2r-j-se...ines-p390.html
Old 03-09-2016, 08:11 PM
  #326
screaminz28's Avatar
That's the type of flanges that Utah used on his. Another option is to use flanges from Prank (or cut stock J-pipe flanges) and make the piping route from the precats to an up-pipe.
If you go through the thread, Ken posted pics of his setup - it bolts to the precats and has an up pipe, similar to how Subarus are done.
That's how I intend to do mine as well, and similar to how Tony the Tiger did a customer's.
Old 03-09-2016, 08:22 PM
  #327
7th Gear
JacobT's Avatar
Okay I think I understand what you are saying. So after the precats meet the j pipe and it goes down to one you cut it there then run a new pipe to the turbo. that seems way easier then making a custom manifold
Old 03-10-2016, 06:12 AM
  #328
You could do it that way, or just cut off the pipes right at the mating flange and use the flanges with your own pipe. Like Ken's:
Using the stock J-pipe is just a method to have free flanges. The set is only 60 bucks from Prank Parts for brand new stainless flanges.
Old 03-10-2016, 03:23 PM
  #329
7th Gear
JacobT's Avatar
okay thanks alot man! I think it would be easier at least for me to just cut the pipe after they meet and then run it to the turbo. Then I only have to weld one pipe and I don't have to weld 2 pipes into one.
Old 03-10-2016, 09:13 PM
  #330
get a second car if you plan to turbo. A lot of things need to be hashed out..
Old 03-11-2016, 12:12 PM
  #331
I might be putting up the turbo kit for sale. Issues came up with the wife CRV so it is going to need some major repairs done...
Old 03-11-2016, 02:36 PM
  #332
just bought 5 tires for the crv since I had a puncture 1/4 mile from my apt... Spare tire was also shot... Tire couldn't be repaired since it was too close to the side walls. Thank god discounttiredirect is having a 100 off 400 deal...
Also I will be closely monitoring the crv engine. Had an overheating issue when the upper coolant hose blew off. Didn't know how long it had occurred since I was driving for over an hour before I stop... Temp gauge didn't go up until I parked the car. So far no coolant mixed into the oil. Going to need to flush the coolant and install another thermostat just for preventative measures. hopefully it won't need the head milled and a new headgasket. (cross finger). If it comes down to that then I am going to put in a low millage k24a1. car has over 215k on it and it rusty.
Old 03-11-2016, 04:57 PM
  #333
teh CL's Avatar
Old 03-11-2016, 05:42 PM
  #334
Originally Posted by teh CL
tell me about it... Just this week alone I spent 1k. I did ss lines, front and rear rotors, all new calipers and brakes, pads, fluid, a/c compressor, a/c lines, freon, and a bunch of other crap. Then another 400 for tires and probably 300 bucks for lifetime alignment and mount and balance... A/C still isn't 100%...
Old 03-11-2016, 07:19 PM
  #335
well battery light on the CRV just came on... So either the alternator or battery... It just gets better and better. I haven't even touch my car yet.
Old 03-11-2016, 08:16 PM
  #336
Damn, I'm feelin it for ya. I have a 25% off coupon at Advance if you need it. Not a ton, but if you're getting a battery or alternator it can save a few bucks. I also have a $20 off $40 speed perks if you can use it. PM me or hit me up on FB.
The following 2 users liked this post by screaminz28:
teh CL (03-12-2016), thisaznboi88 (03-11-2016)
Old 03-12-2016, 08:49 AM
  #337
Got it off now pray for me that the exhaust shop can weld on the nut and break it out.
Old 03-12-2016, 12:13 PM
  #338
4 shops , 20 buck, and 4.5 hours later.... The car is kinda sorta put back. Had then punch out all 3 studs. The unbroken one had jacked up threads. So the j pipe is held on with 2 bolts in the rear and the cat back is also held on with 2 bolts.. Yeah I am done with this bull shit. Going to be until may or if not next year. All the fucken cars decided to break all at once. I was so close to getting a rental
On the flip side. The rear cat looks good even though the media was kinda loose. I give it a hard smack and now it stays in place again. There was some Ca deposits or something. Could be from when I was using wiper wash for water/meth. They just flaked right off after I touched it
Old 03-12-2016, 12:36 PM
  #339
teh CL's Avatar
Was the CRV ever maintained?
Cars make and break dreams..
Old 03-12-2016, 01:35 PM
  #340
I bought it used so I have no idea. Just the regular fluid and stuff. But for sure the timing chain was never touched. the coolant was still green when I got it. So I replaced it with honda type 2 and did a bunch of maintenance. Its just rusty.
Old 03-13-2016, 10:52 AM
  #341
looking for an oil pan again... I think this time I will just buy new, and do the none welding oil return
Old 03-13-2016, 04:13 PM
  #342
UTAH TSX's Avatar
Those things always seem to leak, just weld the hole up and install a new one saves $$$$ also
Sorry to hear of the problems, that's just the way it goes, don't get discouraged or bang your head on the wall just take your time and it will come together
thisaznboi88 (03-13-2016)
Old 03-13-2016, 09:27 PM
  #343
What is the non welding oil return? I know back in the day we could punch a hole through the steel oil pans on B series, but with these aluminum ones..
I guess you could drill a hole and thread it and then jb weld that. Seems to be a common method without issues.
Old 03-14-2016, 06:55 AM
  #344
KN_TL's Avatar
I used a AN bulkhead fitting. Cut off the shorter end and used two teflon washers and hondabond/red locktite. I peened the nut/threads in several places to make sure it doesn't come off.
Rodney's kit came that way and I haven't had any problems with it leaking or loosening up.
thisaznboi88 (03-14-2016)
Old 03-14-2016, 07:52 AM
  #345
I was looking for something like this
http://www.ebay.com/itm/Turbo-Oil-Pan-Oil-Return-Drain-Plug-Adapter-Bung-Fitting-10AN-no-Weld/301795904211?_trksid=p2050601.c100085.m2372&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20140211132617%26meid%3Db750fa26541643fe93c017e28a706e1a%26pid%3D100085%26rk%3D3%26rkt%3D4%26sd%3D251669833365%26clkid%3D3986516097609560020&_qi=RTM2247627
Old 03-14-2016, 02:57 PM
  #346
UTAH TSX's Avatar
I don't think it is long enough for an aluminium pan look for bulk head fittings like KN suggested they have longer threaded section for thicker pass through
Old 03-14-2016, 04:41 PM
  #347
KN_TL's Avatar
Utah is right. It looks like that one is made for a steel pan.
Old 03-14-2016, 09:34 PM
  #348
J-series addict
yungone501's Avatar
I've seen many successful oil drain fittings using the straight-cut NPT threads for the pan on one side and the male AN on the other for the drain tube. This is generally done using black RTV as sort of a "thread sealant" as the black is less susceptible to oil deterioration than all other sealants. Just make sure there is absolutely no oil residue on the pan when installing the fitting. Rarely will this setup leak if the fittings hex is held stationary when tightening the line onto it. Once the fitting is moved after being installed, the RTV's seal is broken and will begin to leak. Some people even install the drain line before the RTV dries to prevent this from happening but if you're careful enough, you will be fine.
Old 03-22-2016, 09:27 PM
  #349
I think I am just going to cut off the AN fitting and weld the hole, then relocate the drain nozzle. Doesn't look like this oil pan will sell and I hate to trash it
Old 03-31-2016, 06:37 PM
  #350
bought a new oil pan for 60 shipped. Just need another bung and pay more labor to get it welded again because I want boost!!
Old 03-31-2016, 09:45 PM
  #351
also just realized that rv6-p sells those studs way cheap than honda. Honda chopped me @ 12 bucks a stud...
So new j-pipe gasket and a few extra studs are on order
Old 03-31-2016, 10:11 PM
  #352
UTAH TSX's Avatar
12 bucks a stud ouch that's why I'm a hoarder at work and strip all the bolts off of cores and junk parts I can't think of the last time I had to buy a bolt it's been years,
When are you going to re-start the install ?
Old 04-01-2016, 06:37 AM
  #353
I am shooting for first Thursday of may.
The following 2 users liked this post by thisaznboi88:
screaminz28 (04-01-2016), teh CL (04-01-2016)
Old 04-01-2016, 01:36 PM
  #354
Oil pan shipped today. Not sure if April fools joke or actually shipped
Old 04-03-2016, 10:45 AM
  #355
Bought another 10An oil return fitting. Just going to get it welded again. Going to double check it on the car first so I can make a reference on where I want it on the new oil pan
Old 04-14-2016, 02:10 PM
  #356
Contacted Paul about installing everything and fabricating the brackets for the intercooler. Hopefully I can get it all done and under budget by may.
I also acquired an LSD from a Tl to put in my accord tranney.
teh CL (04-14-2016)
Old 04-14-2016, 08:01 PM
  #357
J-series addict
yungone501's Avatar
Wait, youre paying someone else to do the install for you? Seems to me like you have plenty of knowledge and capability of doing this yourself. You would be surprised how easy it all really is. Sometimes i wonder which part of it all i truly enjoy the most. Sure, i enjoy daily driving a 450 horse Accord. But man, theres really something about the build and construction that gets me amped up. Maybe thats why ive had damn near every displacement known in the j-series family in the car in roughly 3 years or so? Lmao.
I say at least make an attempt at it. YOU CAN.DO IT!!!
Old 04-14-2016, 08:57 PM
  #358
lol fine Ill try to do it. It might be a little half ass with mounting the intercooler. I actually want to have all the intercooler piping welded so that I don't have to worry about it blowing off the coupler during boost. Its also a pain in the ass to work in front of my Apt parking lot. The concrete isn't even straight and slanted at a small angle. I wish I had a rack that I could rent out for a day or two like they do back home in Cali
yungone501 (04-14-2016)
Old 04-15-2016, 06:44 AM
  #359
Hairspray on the IC pipe before putting the coupler on. Sticks like glue.
I vote for diy as well. I don't care who does the work, but a turbo kit install isn't like a supercharger where it's a known time to install, so there will always be unexpected things. Unexpected means more time, which means more money. If you were quoted a flat price for these install, I wouldn't trust it, even if it was from your best friend.
Old 04-15-2016, 07:15 AM
  #360
Alright diy it is!
Quick Reply: DIY turbo idea for cheap? LOL
