DBW to Cable Conversion?
Instead of hijacking the Sprint booster thread, I figured I'd start a new one.
Are there any conversion kits for a 3G TL?
Would a conversion kit eliminate the cruise control function?
^ possible but not for the faint of heart.. the reason we have DBW is for stability control & cruise control.. you have to bypass those modules and then do the actual modding.
DBW is linked to everything, the before mentioned is just a few, it is also part of the ABS system that is used in conjunction with the stability control. It adjusts throttle accordingly during a problem. Eliminating the DBW would require some serious rework of the electronics system in the car as well as the safety features.
94 DC4 RS LSV/Turbo
^ true yes... but a standalone in a car with so many features... mmmmh... that would cancel, abs, vsa, heater, ac, nav it goes on...
unless you do what I've always said would work... AEM EMS... running 90% of the car, the TL ECU running the other 10%... ignore the check engine light
theres no longer a need for a stand alone....greddy and aem f/ic have proven to work good enough...the few parameters that you can control and change with the 2 units are good enough to get a good tune....
you couldn't just get rid of the DBW completely...you can however have a cable operated TB, and at the same time, your accel pedal still has to turn that APP so the ECM can get feedback.
True if you wanted a good tune the FI/C and so on is a good option but if you were one of those that wanted to go all the way the stand alone would be the best bet. Plus it would be great for a turbo application with more settings and more outputs so you can monitor more things.
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
HondoGermany
23
01-08-2016 03:01 PM
