DBW to Cable Conversion?
Old Oct 5, 2009 | 07:24 AM
KN_TL's Avatar
Instead of hijacking the Sprint booster thread, I figured I'd start a new one.
Are there any conversion kits for a 3G TL?
Would a conversion kit eliminate the cruise control function?
Old Oct 5, 2009 | 12:14 PM
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
dude ^^^^ this i what i wanna know too. i believe Paul from has done the dbw to cable conversion because i remember the pictures he posted in his thread about the 80mm throttle body.
Old Oct 5, 2009 | 12:17 PM
1fsthatch's Avatar
would this really help out that much ?
Old Oct 5, 2009 | 01:05 PM
Majofo's Avatar
^ possible but not for the faint of heart.. the reason we have DBW is for stability control & cruise control.. you have to bypass those modules and then do the actual modding.
Old Oct 5, 2009 | 01:08 PM
Black_05_TL_6SP's Avatar
Ryan Christopher
DBW is linked to everything, the before mentioned is just a few, it is also part of the ABS system that is used in conjunction with the stability control. It adjusts throttle accordingly during a problem. Eliminating the DBW would require some serious rework of the electronics system in the car as well as the safety features.
Old Oct 5, 2009 | 01:32 PM
KN_TL's Avatar
I totally forgot about stability control.....crap. I guess I'll just live with it as is. No way am I going to drop $300 for an amplifier (Sprint Booster).
Old Oct 5, 2009 | 06:20 PM
damn man i guess i will have to spring for a sprint booster after my tl-s 6speed swap, pauls j36 build, and Eaton Supercharger!!! next year will be a big year!!!! 400hp here i come!!
Old Oct 5, 2009 | 06:21 PM
too bad the tl-s 3.5 liter engine doesn't bolt up to my 7th gen accord or else i would be doing that! oh well i guess gotta get a 3.6 then
Old Oct 5, 2009 | 11:53 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
you'd literally have to convert the entire car to an 02 tl and prior...
Old Oct 6, 2009 | 12:09 AM
NAiL05's Avatar
What people have said...The good part about the cable setup is that we would be able to run a stand alone!
Old Oct 6, 2009 | 10:42 AM
94 DC4 RS LSV/Turbo
^ true yes... but a standalone in a car with so many features... mmmmh... that would cancel, abs, vsa, heater, ac, nav it goes on...
unless you do what I've always said would work... AEM EMS... running 90% of the car, the TL ECU running the other 10%... ignore the check engine light
Old Oct 6, 2009 | 12:28 PM
Opel's Avatar
theres no longer a need for a stand alone....greddy and aem f/ic have proven to work good enough...the few parameters that you can control and change with the 2 units are good enough to get a good tune....
you couldn't just get rid of the DBW completely...you can however have a cable operated TB, and at the same time, your accel pedal still has to turn that APP so the ECM can get feedback.
Old Oct 6, 2009 | 01:37 PM
NAiL05's Avatar
True if you wanted a good tune the FI/C and so on is a good option but if you were one of those that wanted to go all the way the stand alone would be the best bet. Plus it would be great for a turbo application with more settings and more outputs so you can monitor more things.
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
HondoGermany
23
Jan 8, 2016 03:01 PM
ValdezQ26
Oct 1, 2015 04:48 PM
tndirtdauber
Sep 23, 2015 03:00 PM
